Icon Stage 1 - 3" Lift - PICS - Need New Wheels - Offset/Backspacing Advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrPepperMan, Jun 6, 2017.
  1. Jun 6, 2017 at 7:49 PM
    DrPepperMan
    DrPepperMan [OP] I fly planez to pay for my truck
    Daniel
    Fredericksburg, VA
    2011 Pyrite Mica Tacoma TRD Off Road
    Stock
    Hey all,
    Just put a Icon Stage 1 w/ Icon AALs and SPC UCAs on my 2011 TRD Off Road Doublecab Shortbed Tacoma today. Next are BFG KO2s, but I don't have enough backspace/offset to get a 285/75R16 in there.
    New Wheels - How much backspace/offset? Would these work? https://www.tirerack.com/wheels/Whe...coma+Double+Cab&autoYear=2011&autoModClar=4wd
    If you haven't realized it already, I'm very new to all of this, but trying to learn as fast as I can. Thanks in advance for your help!
    Plan on starting an actual build thread, but for now, here are some pics:
    dpele likes this.
  2. Jun 7, 2017 at 8:30 AM
    DrPepperMan
    Daniel
    Fredericksburg, VA
    Stock
  3. Jun 7, 2017 at 8:58 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    If you don't want to plunk down for new wheels, you can just get some 1" spacers, which will give you plenty of room. Though you'll still probably want to consider a cab mount chop if you're going with 285s.
  4. Jun 7, 2017 at 9:07 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Or you can do what I did. Buy some extended studs for a Lexus is300 from summit and buy those cheap spacer plates from advanced auto parts.
  5. Jun 7, 2017 at 9:28 AM
    JaxQuack
    JaxQuack Well-Known Member
    Trey
    2015 Tacoma Crew Cab Prerunner
    I ran 285/70/17 with -12mm offset on wheels. No cabmount chop needed. Simply removed front mud flaps as well as the mudflap looking piece in front of the front tire as well. No rubbing
  6. Jun 7, 2017 at 12:53 PM
    DrPepperMan
    Daniel
    Fredericksburg, VA
    Stock
    Good to hear, I'm hoping a 285/75/R16 will have the same result for me.
  7. Jun 7, 2017 at 1:21 PM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    You will rub the cab mount and the inner fender next to it with some compression. I tried getting away with not doing it but it's tearing up the outer lugs.
  8. Jun 7, 2017 at 4:05 PM
    DrPepperMan
    Daniel
    Fredericksburg, VA
    Stock
    I heard cutting the cab mount will void insurance claims on the vehicle, is there any truth to this?
  9. Jun 7, 2017 at 6:51 PM
    JDRockz
    JDRockz Well-Known Member
    Crestline, Ca.
    12' DCSB
    I have not heard of this issue before.
  10. Jun 8, 2017 at 5:20 AM
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    -10 or -12 offset gives you the best stance in my opinion and you wont need to run a spacer. tire size is a matter of preferance. i run 285's and didnt need to do the cab mount chop....but i also dont do alot of "offroading"...most of my offroading is done on the beach. with a -12 offset you'll have the wheels poke out passed the fender roughly an inch so use that as a guide. the lower the number ie: -10..-5 etc....pushes the wheels into the fender. factory wheels are 0 offset.
    i run a -12 offset with 285's and only have very suttle rubbing on the driverside front when going in reverse and cutting the wheel to the left. doesnt bother me at this point.
  11. Jun 8, 2017 at 5:23 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    it wont
  12. Nov 27, 2019 at 9:59 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    How are you liking the ICONs? How are they holding up?
