Icon stage 4 installation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wyatt45, Feb 2, 2022.
  1. Feb 2, 2022 at 3:07 PM
    wyatt45
    wyatt45 [OP] Member
    2019 TRD OR DCLB
    Getting ready to install this on my 2019 quicksand. Question; anything else I need? diff drop or extended brake lines? I might do the brake lines at a later time but as far as immediate need, am I missing anything?
  2. Feb 2, 2022 at 3:12 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Preventive ECGS bushing while you have it all apart.
    Is your alignment scheduled?
    Aptaco272 and skeletron like this.
  3. Feb 2, 2022 at 3:25 PM
    wyatt45
    wyatt45 [OP] Member
    2019 TRD OR DCLB
    Hmm., I didn't plan on taking all that apart down there. Perhaps I'll wait and see if that needs to be replaced later. No alignment scheduled yet.
    Montana_Actual likes this.
  4. Feb 2, 2022 at 4:18 PM
    eurowner
    eurowner Duke Sky
    Scoty
    You will have the coilover out of the truck and it's a lot less work from there. Remember to put the bushing in the freezer and keep the driver-side front corner higher than the passenger side so you have very little fluid escape.
  5. Feb 2, 2022 at 8:01 PM
    justinm2431
    justinm2431 Well-Known Member
    19 TRD OR
    Get the bushing done. About 8,000 on mine and it’s not happy. Goes in for bearing replacement and 5.29’s next week
  6. Feb 2, 2022 at 9:42 PM
    Montana_Actual
    Montana_Actual ;)
    A lot of people have reported no needle bearing issues. I am lifted 3" and have 5.29's going in. I see no need to replace it unless it causes an issue. Would it be easier to do since you are right there? Sure. But given the fact that half the people here on the forums put tons of miles on theirs with no issue, and others do it to prevent it, with the minority actually having issues, I'll wait.
  7. Feb 2, 2022 at 10:21 PM
    Aptaco272
    Aptaco272 TRASH PANDA
    Unspecified
    L5P Duramax
    Some
    This^^
    And be prepared to spend $120 at Toyota to have your TSS recalibrated after the alignment. Dash gonna light up like a Christmas tree after the alignment.
    At least that was my experience.
    Good luck! Jealous of your lift:thumbsup: much better than mine.
  8. Feb 2, 2022 at 10:24 PM
    Aptaco272
    Unspecified
    L5P Duramax
    Some
    I had that issue after my lift install. Cycling vibration from the front end. 20k miles. Guess it just happens to some but I wish id have known it was a possibility while I had the front end pulled apart. Would have just done it while i was that far along after learning about that issue.
  9. Feb 2, 2022 at 10:34 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Better to spend $99 on a code reader and clear the codes yourself. It takes one with ABS functions. The INNOVA 5210 handles it with ease. The light comes on due to needing a zero point calibration.
  10. Feb 2, 2022 at 10:41 PM
    Aptaco272
    Unspecified
    L5P Duramax
    Some
    Good to know, didn't find that info when researching it. All i could find was "only the dealer can recalibrate" after the tire shop spent 2 hrs trying to fix it.
    Thanks!
    Superdave1.0[QUOTED] likes this.
  11. Feb 3, 2022 at 6:56 PM
    wyatt45
    wyatt45 [OP] Member
    2019 TRD OR DCLB
    Hmm! Half say do it and half say don’t. Lol. It looks like a pain in the ass from the videos I’ve watched. How much should I expect to pay for rehearing down the road?
  12. Feb 3, 2022 at 7:48 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Of us who have installed the bushing after our suspension change, we Will ridicule you to the end of time.
    Srsly, to do it during your lift install doesn’t hurt and is way cheaper.
