Icon Stage 5 install for '12 DCSB + Write up & Pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Two Tall, Mar 23, 2014.
  1. Mar 23, 2014 at 5:04 PM
    Two Tall
    Two Tall [OP] Well-Known Member
    Jim
    Ohio
    2018 TRD Off Road DCSB 4x4
    Retrax MXPro bed cover, Gentex Homelink mirror, TRD exhaust
    Finally, after at least a year of research, analysis and review, the Icon Stage 5 is finally installed. Well, it was done last month but I had to wait for a sunny day to clean it up and take some pictures. I did pay a professional shop to do the install and there were some bumps along the road - no pun intended.
    All washed up:
    Before lift (and bumper, and sunroof):
    I had ordered the kit in January and after being promised a week delivery, it turned into about 5 weeks. Install was supposed to be a day, but they had it 3 days. Let's just say in the end, I was happy, and they took quite a bit of the cost off because of the headache. The kit was about $3,500 and the install about $400. I debated forever whether or not to get the billet UCA's - $600 more for something I won't need, but look cool. I opted for tubular and happy with the choice:
    Instead of getting the billet UCA's, upgraded to Stage 5 for the 2.5 shocks in the rear:
    I also looked into getting CDC valving - at about $150 per shock. This would allow for adjusting the ride since I'm mostly on paved highway. In retrospect, I'm glad I didn't. The ride, especially after it has settled after a couple hundred miles, is extremely smooth. Of course, I did not spend $4,000 to keep it on the road, I'm looking forward to getting it dirty. With several hundred miles since the upgrade, there are absolutely no vibrations at any speed or any creaking noises anywhere. There was an issue with a loose body mount that was discovered but it was unrelated to the lift. The shop did have to adjust the reservoir location in the front because it was rubbing on the fender liner. The liner had been previously trimmed because of the Fab Fours bumper install. I did remove the front mud flaps, even though they could have stayed on.
    Ride heights
    Unfortunately, I did not get measurements before the bumper (160 lbs.) and winch (40 lbs.) was installed nor the S/C (about 30 lbs.?) So, these were my pre lift numbers (center of hub to bottom of fender lip):
    Pre-lift
    Drivers front: 19.25"
    Passenger front: 19.75" (Taco lean)
    Drivers rear 21.75"
    Passenger rear: 21.75"
    Post-lift
    Front: 22" (Taco lean corrected)
    Rear: 24.5" (has settled .25" already)
    I did adjust the front coil overs because there was too much rake - I like some rake. Once the rears settle more, I'll have to adjust the front accordingly. I did buy the Icon wrench - not sure why they don't include the $25 wrench when you buy a kit like that.
    Spidertrax
    Until my new wheels get ordered (which will be another year of research:eek:)
    and a set of 285's (current 265 65 18), new Spidertrax 1.25" adaptors were put on. I've already checked them 4 times and all are holding fine at 85 ft. lbs.
    Alignment
    The shop that did the lift did an alignment, but "their printer was broke" so I did not get before and after numbers. Tomorrow, I'm going to Firestone, which has a guy at the local shop that specializes in lifted applications, to get the lifetime alignment deal for like $179.
    Rear 1.5" AAL
    I've got a steel Fab Fours bumper on the back so I was concerned about sag. I've read some members take out the overload spring (?) when they add the AAL. I've got a Sport so it has the TSB. The shop did not remove mine, here are pics of both sides:
    and the passenger side:
    More pics from Picture Day:
    One thing I did not clean yet was the engine bay:
    The TRD skid plate was modified to fit with the Fab Fours bumper:
    Don't hate on my factory chrome rims :):
    At the shop:
    This was a picture pre-lift:
    Next up this summer is cleaning the undercarriage and undercoating....let the research begin!
  2. Mar 23, 2014 at 5:23 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    That's friggin SEXY! :bananadance::bananadance::bananadance:
  3. Mar 23, 2014 at 5:40 PM
    martinh
    martinh Well-Known Member
    New Jersey
    2018 MBP Limited
    The farkles have started and on order
    Truck looks good. Did it come with the sun roof? I wanted in mine and they told me it ws not an option. Is yours electric?
  4. Mar 23, 2014 at 5:56 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    good lookin truck!!
    though never really understood the DCSB sport.... at that point buy the off road and get the locker and atrac.
  5. Mar 23, 2014 at 5:58 PM
    Two Tall
    Jim
    Ohio
  6. Mar 23, 2014 at 6:00 PM
    Two Tall
    Jim
    Ohio
    I know....wanted the skewp, color match handles, turn signal mirrors, etc. though...but got rid of the color match bumpers for steel.
  7. Mar 23, 2014 at 6:02 PM
    smd3
    smd3 Well-Known Member
    Unless you want color matched mirrors, hood scoop, and plan to go for ARBs?
  8. Mar 23, 2014 at 6:33 PM
    Datsik
    Datsik Well-Known Member
    Anthony
    San Diego
    Not much.
    Looks good man.
  9. Mar 23, 2014 at 6:40 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Your AAL is installed wrong but looks good otherwise
  10. Mar 23, 2014 at 6:41 PM
    Eggbert
    Eggbert Well-Known Member
    PA
    '14 dcsb TRD OR Supercharged
    TRD Supercharger, MBRP DualCatback, DT Shortie Headers, Regeared with 4.56 ECGS 3rd and Clamshell, URD 2.55" Stealth pulley, AEM Methanol 5 gallon kit, URD Perf Thermostat, NST Lightweight crank pulley, URD 61lb injectors, Mishimoto Oil Catch Can, URD Fuel Pump upgrade, AEM Boost and Wideband gauges, OEM FPR Mod, RBP Black Exhaust Tips, Icon Stage 6, Fuel Octane wheels, Nitto Terra Grapplers 285/70/r17, Color match rear bumper, Color match hood with skewp, Color match grill, Color match valance, Derped grill emblem, Derped Tuffbar bullbar, OEM Skidplate, AVS Ventvisors, Bodyside Moldings, RBP RX3 nerf bars, Color Match Bushwacker Pocket Flares/Rivets, Undercover LE Tonneau, Katzkin heated leather, Bel Stir-Plus Radar, Sprint Booster, Dynamat/Hushpad, Polk dxi691 - front, Polk dx1651 - rear, Alpine KTP-445U Power Pack, Front tint 35 percent, Weathertech front mats, Smoked tail lights, LED DRLs, Coupe TRD Battery tie-down, Coupe TRD CAI Cover
    Nice truck! Anymore pics of the leather seats?
  11. Mar 23, 2014 at 6:46 PM
    Two Tall
    Jim
    Ohio
  12. Mar 23, 2014 at 6:57 PM
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
  13. Mar 23, 2014 at 7:01 PM
    loco
    Phil
    Virginia Beach, VA
    Who makes these? I like them!
  14. Mar 23, 2014 at 7:40 PM
    Two Tall
    Jim
    Ohio
    Thanks for the feedback Monster Coma and Loco, I'm glad I posted the pics. Loco, I checked your thread, could you please verify it is clamp noted "C" that needs removed in the picture below:
    P.S. Ohio salty winters stink....lot of clean up to do on the undercarriage this spring!
  15. Mar 24, 2014 at 4:57 AM
    Monster Coma
    Corey
    Yes C is the clamp that needs removed. And yes I can verify the squeaking. My truck currently sits like that (I need to fix it) and it squeaks over ever tiny bump
  16. Mar 24, 2014 at 5:30 AM
    sdoheny
    sdoheny Well-Known Member
    Seth
    Tampa, FL
    Sport
    N-Fab Text black 3 main tube, led interior lighting, sylvania ultra head lamps, led map/dome/license plate, rail mounted bed lights, trd skid plate, Aero Turbin muffler swap, MRBP Black Exhaust Tip, weather tech, fuel trophy, duratrac 265 70 17, plasti dip badges, Icon stage 4 suspension, TRD shift knob, AFE CAI, Raptor Light MOD.
    I put on stage 4 system and i cut that bracket off so everything sits properly.
  17. Mar 24, 2014 at 12:23 PM
    loco
    Phil
    Virginia Beach, VA
    Yes that clamp labeled "C" is correct. Good luck!
  18. Mar 24, 2014 at 12:33 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, time to get out the angle grinder and get rid of that clamp. FWIW, I had the same AAL and it never made a peep. I loved the ride also but I only had Bilstein 5100's.
  19. Mar 25, 2014 at 6:22 PM
    Two Tall
    Jim
    Ohio
    The seats are made by Katzkin. TW member JHuey8947 (John) can take custom orders. There are many options including two tone, contrast stitching, perforated, heat, embroidery, etc.
    http://www.katzkin.com/
  20. Mar 25, 2014 at 6:38 PM
    Two Tall
    Jim
    Ohio
    Took it back to the shop for my 500 mile checkup post-lift. They agreed they should have taken those clamps off - and did - all fixed. Just need to clean them up now when the weather breaks. Thanks again Monster Coma and Loco!
