Icon vs. OME
Discussion in 'ICON Vehicle Dynamics' started by Griff 99 TRD, Jan 13, 2013.
  1. Jan 13, 2013 at 11:00 PM
    Griff 99 TRD
    Griff 99 TRD [OP] Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp Hybrid Audio Speakers Pioneer Head Unit ARB bumper Eagle 15x10 wheels Odyssey battery
    Mitch,
    I just put my numbers in as per your request. At this point everything is stock and, to be honest, I have no idea what to measure for the other areas.
    Right now, I have $1,800 to spend on a 3" suspension lift. But, I can throw in a few hundred more to get the right products.
    I don't do much off-roading at this point in time. I never wanted to cause any damage to my truck since it's my daily driving vehicle; therefore, I was hoping with this 3" suspension lift I could start doing more.
  2. Jan 13, 2013 at 11:07 PM
    Griff 99 TRD
    My current plan is to have a maximum lift of 3". Will Icon give me a 3" lift? Have you noticed any vibrations with the 650lb front springs? I think my '99 TRD already has a plate covering the transfer case, but I plan on installing an after market front bumper and winch.
  3. Jan 13, 2013 at 11:11 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I did an Icon Stage 1.5 from DownSouthMotorsports. Its the Icon Stage1 with their AAL. I did not do any remote reservoirs which kept the cost down. Then I installed LR UCA's instead of Uniball UCAs again to keep cost down. You can get that same kit installed by yourself for under 1800
  4. Jan 13, 2013 at 11:11 PM
    Griff 99 TRD
    I'd like a 3" suspension lift. I want to be able to go through all types of terrain: mud and snow. I currently have $1,800 to put toward the project.
  5. Jan 13, 2013 at 11:12 PM
    Mitch
    Mitch
    Spokane, WA
    Oh shit. I just realized that you have a Gen 1. My stats and experience is 2nd Gen only.
  6. Jan 13, 2013 at 11:15 PM
    Griff 99 TRD
    O.k. forgive my stupidity here, what does "AAL" stand for? I know UCA is upper control arm, however what does "LR" stand for? I plan on doing the project myself along with a buddy who is a certified mechanic. I do know that Icon comes with three different stage systems, but I don't know what the benefits are of having a reservoir shock...
  7. Jan 13, 2013 at 11:20 PM
    Mitch
    Mitch
    Spokane, WA
    AAL stands for Add-A-Leaf for the rear leafs. That is where you gain your real lift.
    LR is Light Racing, its a company that is about half the cost of the uniball UCAs since it is a Ball Joint UCA.
    If you have a remote reservoir, you have more oil that is able to keep the shock cooler. This helps in long distance runs at high speeds. Keeps the shocks cooler during operation.
  8. Jan 13, 2013 at 11:20 PM
    Griff 99 TRD
    No worries, man!! So, does your opinion differ now that you know I have a Gen 1 Tacoma?
  9. Jan 13, 2013 at 11:36 PM
    Griff 99 TRD
    Gotcha!! Thanks for acronym lesson lol.
    I normally don't drive over 75 mph, so I don't know if a remote reservoir is necessary. I'm pretty sure you don't need an aftermarket UCA with the OME system. But the Icon Stage 3 sounds pretty awesome!! If I were to get that then I guess I would have to get a heavy duty front spring to support a winch and an aftermarket front bumper.
  10. Jan 13, 2013 at 11:50 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    You may not even need a heavier spring for a bumper and winch. If you have a 4 cylinder the 650lb coils can hold a winch and bumper no problem.
    The Icon stage 3 kit is great. In No way a bad choice.
  11. Jan 13, 2013 at 11:59 PM
    Griff 99 TRD
    I've got a V6. Will the stage 3 kit provide a 3" suspension lift?
  12. Jan 14, 2013 at 12:17 AM
    TacoMX
    Jonathan
    Deltona, Florida
    Yes, the stage 3 kit will give a 3" lift. Most coilovers are adjustable for 0-3" of lift. But with a v6 you may want to eventually upgrade the coils because av6, winch, and bumper may cause the existing coils to sag.
  13. Jan 17, 2013 at 9:43 PM
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    We are actually about to release our own ICON engineered 14 x 700lb coil as a second option when heavier weights are added to the front half of the vehicle. This coil will be best when you have a heavy steel bumper, winch, heavy skids that push additional weight up in the 250+ over stock range, otherwise it may stiffen up the front a little more then most would desire. Because our standard 13 x 650lb coil does not coil bind in the useable travel range of the shocks, you can adjust them to compensate for a decent amount of weight and still work as designed.
  14. Jan 17, 2013 at 9:50 PM
    Mitch
    Mitch
    Spokane, WA
    Hell yes! Any plans on a 14" 650 lbs coil for people who don't have the extra weight but want less preload?
  15. Jan 18, 2013 at 6:29 AM
    #35
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    :popcorn: I need more ICON :popcorn:
  16. Jan 18, 2013 at 10:09 AM
    #36
    adrn1986
    adrn1986 Well-Known Member
    Adrian
    Riverside Ca
    04 Pre-Runner
    -Icon Coilovers and Bypasses -LT Front and Rear -Supercharged
    Not sure if a 14" x 650lbs will ever be made.
    There aren't any benefits to be gained from a longer 650lbs. Our 13" x 650lbs and threaded cylinders are made to complement one another. The cylinder threads end before you can coil bind the spring. Adding 1" to the overall length without changing the rate can, in theory, reach coil bind if crank too much preload into the spring.
  17. Jan 18, 2013 at 12:10 PM
    #37
    Mitch
    Mitch
    Spokane, WA
    But it would allow you to have the same height of lift with less preload on the spring.
  18. Jan 18, 2013 at 12:20 PM
    #38
    adrn1986
    Adrian
    Riverside Ca
    04 Pre-Runner
    Correct.
    Less preload but run the risk of some customers cranking the adjuster to coil bind. That's why the spring was designed to be 13" rather then 14" and the threads on the cylinder end where they do currently. There are some people that may not be as mechanically savy and/or would ignore a written warning to not cant more then (whatever length it may be)" of thread showing. That would lead to broken coil buckets, broken shock tabs and spring sag at an unimaginable rate.
    There really is nothing to gain from running less preload, other then less threads showing.
  19. Jan 18, 2013 at 12:22 PM
    #39
    Mitch
    Mitch
    Spokane, WA
    Okay
  20. Jan 18, 2013 at 12:37 PM
    #40
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    I went with Icon and I have 0 complaints! Even after I adjusted mine to be level with the rear end the ride is still fantastic! I went with the extended travel coilovers with resi, rear resi shocks, camburg UCA's, dakar leaf springs and timbren bumps and a diff drop and carrier bearing drop (ended up not using the diff drop and got a beafed carrier bearing drop so I didn't use the one I bought first). Total cost me about 3400 shipped.
