Icon vs. OME
Discussion in 'ICON Vehicle Dynamics' started by Griff 99 TRD, Jan 13, 2013.
  1. Jan 19, 2013 at 2:09 AM
    #41
    Griff 99 TRD
    Griff 99 TRD [OP] Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp Hybrid Audio Speakers Pioneer Head Unit ARB bumper Eagle 15x10 wheels Odyssey battery
    FOR NOW, I'm going with the OME Suspension Lift Kit. My thought process is that I'd rather not drop the money now if I'm not going to become an avid off-roading enthusiast. I figure if I start getting more into the off-roading scene I can always upgrade to Icon front and rear reservoir shocks. I don't know if I'll (also) need to get the coil over(s), too since I'm getting the OME 883 HD springs in order to compensate for my future after market winch and front bumper. Thoughts?? Also, how do you like the Timbren bumps? I saw those tonight on Wheelersoffroad.com and, since I don't have much automotive knowledge, I didn't want to invest in a product that is unnecessary. Also, what's the difference between a diff drop and a beafed carrier bearing drop?
  2. Jan 19, 2013 at 7:57 AM
    #42
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    If you are going to upgrade later to Icons you have to get the coil over. It is one piece. OME is a strut set up. Meaning you can change the springs (yes you can with the Icon as well but there is a large difference).
    If you are going to possibly upgrade save your cash and just do the Icons the first time.
    I'm running the Wheelers Super bumps and am happy with them. They are half the cost of the Timbrens.
    A Duff drop drops the front differential where a carrier barring drop drops the rear driveshaft about half way down. If you look under the truck you'll see where the driveshaft gets lowered.
  3. Jan 19, 2013 at 8:12 AM
    #43
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    I freakin hate the timbrens....damn things are harsh as hell! I'll be upgrading to the Icon hydraulic bumps soon hopefully! I ditched the diff drop after figuring out that it doesn't do anything on the 2nd gen (05+) tacomas. All it does is rotate it forward and causes more issues than resolves...plus my cv's look great. The beefed taco carrier bearing drop was designed by a fellow tw member (beefed taco) and it works a lot better than the ones offered by companies like toytec.
  4. Jan 19, 2013 at 8:13 AM
    #44
    bridgcat
    Alabama
    I have to reiterate what Mitch says. Don't buy a lift just because it's cheaper if you plan on upgrading in the future. Just save some extra scratch and get what you want. Thats what I did and I couldn't be happier.
  5. Jan 19, 2013 at 8:23 AM
    #45
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If you do that math...its only marginally more for a full on set of coilovers.
    Once you buy the OME struts, the coils, new bushings, new coil isolators (trust me, those will be worn out), and ultimately new studs for the top plate, because they will end up being fucked up.
    Then if you dont have a spring compressor you will have to (in order to do it safely) pay for someone to put the shocks/coils together for you.
    I was going to get OME for my truck...but I ended up getting some 2.0 sway away coilovers because the coilovers are $750...
    While the OME struts are about $300, the coils are $150 a pair, new bushings $30, isolators $20, studs $20 (because my truck currently has a top plate spacer w/ extended studs)
    Then shipping, I was less than $200 away from the 2.0 saws....so fuck it...why spend that much when for just a little more I can have the ideal setup I really want.
  6. Jan 25, 2013 at 7:34 PM
    #46
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    All Over CA
    MGM 2012 4x4
    I'm thinking of going with ICON coilovers and want the lift to be about 2.75" in front but am afraid the ride might be too harsh...That's why I thought having a 700#spring with less pre-load might make the ride better than a 650# spring cranked up super high?!
  7. Jan 25, 2013 at 8:14 PM
    #47
    TacoMX
    Jonathan
    Deltona, Florida
    Icon's are digressive valved, and will ride stiffer than every other suspension kit out there, anyways.
    My sway aways are cranked to almost 3'' and I think the ride is fine.
  8. Feb 10, 2013 at 4:12 PM
    #48
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Is it true you need to re-build them every 50k mi max ? that seems to get a little expensive as well...
  9. Feb 10, 2013 at 7:45 PM
    #49
    TacoMX
    Jonathan
    Deltona, Florida
    any suspension system with a prudent owner will need attention at 50k anyways. So its either rebuild, or replace the shocks completely.
  10. Feb 11, 2013 at 6:47 AM
    #50
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    That makes sense. Have to keep them tuned up. Ty
  11. May 25, 2013 at 7:24 PM
    #51
    Griff 99 TRD
    Post lift, my CV Boots are spewing grease...any thoughts on how to fix this? I didn't do a diff drop or carrier drop...but, I stopped driving my truck altogether because I didn't want to cause any damage. There also seems to be whomp type of noise coming from the wheels. I put 15x10 wheels on my truck with 31x10.50...I hope that helps with any kind of recommendations from you automotive sages....
