Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 5, 2013 at 7:27 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  2. Jun 5, 2013 at 7:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    :thumbsup:
    On another note , I flew over Idaho , Montana and North Dakota today , all looks the same
  3. Jun 5, 2013 at 7:31 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    PNW?
  4. Jun 5, 2013 at 7:34 PM
    OZ-T
    Peter North
    British Columbia
    Not
  5. Jun 5, 2013 at 7:36 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    bahhahaha
  6. Jun 5, 2013 at 7:37 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    I knew I felt a creepy presence today.... :cool:
  7. Jun 5, 2013 at 7:39 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    waves are supah nice nao gaiz, lets go surf bu!
  8. Jun 5, 2013 at 9:41 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  9. Jun 5, 2013 at 10:03 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Mike,
    Remember when you asked me about my caster setting being so high? I started noticing it wander to the right on the highway and when i would apply brakes it would start veering right too. Well, turns out my LCA bushings are shot to the point where he couldnt get the caster aligned... Looks like im replacing those.
    Anyone know how bad of a job that would be? I hear its a bitch to press them in
  10. Jun 5, 2013 at 10:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Most don't bother. Even Jace recommends just putting in new Moog LCAs with the bushings in them already.
  11. Jun 5, 2013 at 10:10 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    You mean put new LCA's!? How much are those? Bushings are like $30
  12. Jun 5, 2013 at 10:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. Whole new LCAs.
    No idea,,85 I think each?? Lisa will know. She did it.
    Also you need to keep a part of the old bushings to use with the new ones. Silas found that out the hard way.
  13. Jun 5, 2013 at 10:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have read that replacing the bushings in the LCA is so much work it isn't worth it.
    Replace the whole arm, they come with new bushings. Not sure about the cam adjusters. I think some have had to replace those as well but it may be because the were frozen/corroded . Not sure.
  14. Jun 5, 2013 at 11:16 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  15. Jun 5, 2013 at 11:17 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :D
  16. Jun 5, 2013 at 11:45 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    wow ben
    good luck
  17. Jun 5, 2013 at 11:45 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rofl: wtf is wrong with you. dont you have any marketable skills lol?
    be a waiter, you were already a bartender or something. if you work hard they make bank. or shit, work at a grocery store. you dont make bank but they work around school well.
    dont even tell places you are in school. tell em you are looking for full time and need a week or two in august. then when school starts put in your two weeks and go bye!
  18. Jun 5, 2013 at 11:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    FWIW my bio department is looking for another lab prepper to work with me..........
    :cookiemonster:
  19. Jun 5, 2013 at 11:54 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    true, I would be too busy potatoing if I went up to udaho
  20. Jun 5, 2013 at 11:56 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    fuck pretend it is! go apply to every bar and restaurant lol
    :rolleyes: you couldn't potato if you tried
