Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jul 10, 2014 at 7:22 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  2. Jul 10, 2014 at 7:25 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    where and when??? I have a wheeing trip planned atm for aug 27th through September 6th I think I can extend a couple days to hang with yah :p
  3. Jul 11, 2014 at 8:19 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
  4. Jul 11, 2014 at 8:43 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    It is my understanding they are all very expensive. :D
  5. Jul 11, 2014 at 9:01 AM
    BradyT88
    BradyT88 Well-Known Member
    Rocky's was pretty cheap. He's only like $5K into his entire rig (that includes buying it) and he put front and rear axles on it plus a motor swap to the 3.4L.
    Although after all his carnage in Moab it went up a bit.
  6. Jul 11, 2014 at 9:34 AM
    rctoy
    konstantenos
    Pocatello Idaho
    you cant include that in his build. trail dammage never counts.
  7. Jul 11, 2014 at 9:35 AM
    rctoy
    konstantenos
    Pocatello Idaho
    Mine could have been a lot cheaper had i chose smaller axles and tires with less lift. i could have just got a toy axle for the front kept my rear and just ran 37's we are talking the diffence between 13K and 4K
  8. Jul 11, 2014 at 10:15 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    What kind of axle are you running?
  9. Jul 11, 2014 at 10:58 AM
    rctoy
    konstantenos
    Pocatello Idaho
    HP dana60 front and a 14bolt rear. 3 link front and chev 63's for the rear. probably gonna run around 10" of lift to clear 42's
  10. Jul 11, 2014 at 11:25 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Bombproof set up! You going to shave the 14 bolt?
  11. Jul 11, 2014 at 11:57 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Wait 10"? For real? That seems like way more than necessary. You will blow the 30" frame height out of the fucking water
  12. Jul 11, 2014 at 12:09 PM
    BradyT88
    But if you went that route you would still be breaking shit like Rocky too though. He needs some tons now too! Wouldn't be too hard to swap them on now I wouldn't think.
    Well 42's will give him approximately 21" (assuming they truly are 42's) and then 10" of lift for a total of 31" give or take. Then he'll air down and by the time those 42's get a little flex in them he'll likely drop a couple inches. So he may be right at 30" frame height when aired down.
  13. Jul 11, 2014 at 12:19 PM
    rctoy
    konstantenos
    Pocatello Idaho
    i will trim the housing a hair but im not going to cut the ring gear if i was going to do that i would just run the 35spline sterling 60 i already have.
    Basicaly something like this vvv might be a bit taller than 30" frame height but i can adjust as i go and make it more more of a droop suspentions as i go if need be.
    hence the reason i did not go that route.
  14. Jul 12, 2014 at 7:20 AM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  15. Jul 12, 2014 at 9:00 PM
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    Went to Bloomington lake the fun way on some forest service roads and flexed the truck out so had to take a truck selfie, right?
  16. Jul 14, 2014 at 12:41 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    So I did end up getting an internship with simplot, it's actually at the food production plant not at the corporate office like I wanted. but hours are plenty and pay is good. It's about the most inconvienet location imagineable, but it's a good company with tons of opportunity after graduation.
    But Ben, you would have a field day here. I just got a tour of the boiler room, with the 3 1800 hp state of the art boilers that produce all of the steam for the plant. Shits pretty crazy and right over my head. I'll look around and ask if they have any engineering internships or positions that they know about if you want.
    I'm also getting a kick out of the fact that when I started they gave me a white hard hat,some shirts and said to wear tan/khaki pants. That also happens to be the dress for managers and supervisors. So I'm walking around, or eating lunch and most people think I'm a manager or supervisor, and I don't have a fucking clue what's going on :laugh:
  17. Jul 14, 2014 at 1:08 PM
    rctoy
    konstantenos
    Pocatello Idaho
    Very nice sir. im way pumped for you..
  18. Jul 14, 2014 at 3:16 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Congrats dude! Not gonna lie I chuckled at the last part lol
  19. Jul 14, 2014 at 3:47 PM
    SconnieHailer
    Marc
  20. Jul 14, 2014 at 4:20 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Thanks guys!!
    It's a pretty good opprotunity all around. Its a good company, and There are a ton of potential full time positions available upon graduation. The other big reason I like simplot is that they are one of the local KPMG branch'a biggest audit clients. So the internal experience from simplot is a big leg up if I wanted to go work for kpmg
