Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Dec 24, 2011 at 11:01 AM
    #921
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Fap fap fap
  2. Dec 24, 2011 at 12:27 PM
    #922
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    I wish it was snowing down here..
  3. Dec 24, 2011 at 1:47 PM
    #923
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    No snow here :(
  4. Dec 24, 2011 at 5:12 PM
    #924
    Manwithoutaplan
    ID
    where is the snow :notsure:
  5. Dec 24, 2011 at 5:32 PM
    #925
    Manwithoutaplan
    ID
    supposed to snow in cottonwood sundy night :D
  6. Dec 24, 2011 at 6:03 PM
    #926
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Hope you guys have a good Christmas tomorrow for those who celebrate!
    If you don't... Don't read the previous line.
  7. Dec 24, 2011 at 6:05 PM
    #927
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Thanks dude! You see see you when you get back for mini install day
  8. Dec 24, 2011 at 10:00 PM
    #928
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Merry Christmas guys!
  9. Dec 24, 2011 at 10:33 PM
    #929
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Merry Christmas you 'mericans!
  10. Dec 24, 2011 at 10:37 PM
    #930
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
  11. Dec 24, 2011 at 11:13 PM
    #931
    Digiratus
    Roaming the PNW
    The RedHead
    Very nice. Is the strap so you can save Monte? :rolleyes:
  12. Dec 25, 2011 at 6:24 PM
    #932
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well shit the starting problem is still there. i have reasoned that it is some wire connection problem somewhere between the starter and the battery. sometimes i will turn the key and it fires right up, other times i turn it 5 times, it clicks each time, then it eventually fires up. its pretty much hit and miss as to when it starts first try...:( so tomorrow i guess im going fishing through wire to try to find where its loose or not 100% connecting.
  13. Dec 25, 2011 at 6:47 PM
    #933
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    like.....oh ya i believe so. i must have loosened something when i was putting in the lights and now its being finecky
  14. Dec 25, 2011 at 7:02 PM
    #934
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ya thats what i started with, i replaced the power connector and moved around/cleaned the negative connector. so tomorrow im replacing the negative one also and just doing a full wire check, crossed fingers its not a PITA
  15. Dec 25, 2011 at 7:37 PM
    #935
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    no, but after the first time it happened i disconnected the lights and they have not been connected since and it is doing the same thing, so somewhere while installing the lights something got hit and became loose.
  16. Dec 25, 2011 at 8:33 PM
    #936
    Digiratus
    Roaming the PNW
    The RedHead
    Sounds like you've been pretty thorough with all the work you have done around this problem so far. However, this latest description make me think starter solenoid.
  17. Dec 25, 2011 at 9:14 PM
    #937
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Would thoes symtoms be caused by a starter solenoid? I mean it clicks every single time, and when it didn't start one of the times I loosened the connecter on the battery terminal and shifted it and tightened it back down and it started, and when it wants to start it fires up instantly.
    What are typical symptoms of a bad starter
  18. Dec 25, 2011 at 9:25 PM
    #938
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    So what I have been noticing (just did this literaly 60 seconds ago) is that when it does not fire up the first time, and it just clicks, all I have to do is just turn the key 3 to 5 times, ( it clicks each time) and it starts...so is the starter just going bad? Again like I said this problem didn't happen before I disconnected the battery to put in lights.
  19. Dec 25, 2011 at 9:48 PM
    #939
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    It's typical of the 4 banger cold starting mine does the same thing from time to time
    Check the forum there are a couple of threads on the issue.
  20. Dec 25, 2011 at 9:56 PM
    #940
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    This is different than a cold start issue
