Ideas for oil pressure send unit install?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoinMD, Jun 3, 2009.
  1. Jun 3, 2009 at 11:25 AM
    TacoinMD
    TacoinMD [OP] Well-Known Member
    Tim
    Ft. Lauderdale, FL
    2017 Silver Double Cab Sport.
    Has anyone installed an oil pressure sending unit in / on their 4.0 v6? I would like to install the gauge package, however, not certain where to put the sending unit. I have looked at oil filter sandwiches with the send unit ports built in, but I’m fearful of this method?
    Any ideas?
    Thank you!
  2. Jun 3, 2009 at 2:25 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    ^ I have the same set-up, Works good.
  3. Jun 3, 2009 at 3:41 PM
    TacoinMD
    Tim
    Ft. Lauderdale, FL
    I'll use the sandwich method...thank you
  4. Jun 3, 2009 at 5:26 PM
    daleclough
    daleclough Well-Known Member
    Portland, OR
    18 TRD Off Road Double-Cab Short Bed
    None... yet
    sandwich plate from who? p/n? pictures of the gauge(s)?
  5. Jun 4, 2009 at 5:08 AM
    TacoinMD
    Tim
    Ft. Lauderdale, FL
  6. Mar 4, 2014 at 3:46 PM
    keninsb
    keninsb "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    OK, reviving an OLD thread here, but have the same question. I would rather not install a "sandwich" because I like the little oil drain thingy on the bottom of the oil filter mount. I would rather do the install like JeffH1199 did here:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/117896-diy-oil-pressure-sending-unit-install.html
    I also found what appears to be a very cool sending unit Tee on the Pguses Racing site that looks like this:
    I just need to make sure it will fit our Tacos. Any ideas guys?
    BTW, I don't think those gauge pods will work on some of the newer Tacos because there are side curtain airbags in those pillars. If you got hit with those gauges when the airbags went off, it would definitely leave a mark (in the words of Tommy Boy).
    Ken
  7. Mar 4, 2014 at 6:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    why does one need an oil pressure guage....
  8. Mar 4, 2014 at 10:32 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    So you can read what pressure the oil pump is making.
  9. Mar 4, 2014 at 10:55 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  10. Mar 5, 2014 at 4:48 PM
    keninsb
    Ken
    Goleta, CA
    Thanks MaxaMillion. I saw that thread and tried to look up the part number, but it showed that it was no longer available. They showed the same part number with a -001 at the end and that was the part I posted the pic of above. I am hoping that part will thread right in place of the factory sender and them I can thread the factory and aftermarket senders into it.
    Ken
  11. Mar 5, 2014 at 6:55 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I THINK you want a 1/8 bsp male and then the T to be 1/8npt female
  12. Mar 5, 2014 at 7:07 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Never mind I think that's exactly what you want. Sorry. Believe that factory sending unit is 1/8 bsp
  13. Mar 6, 2014 at 10:02 AM
    keninsb
    Ken
    Goleta, CA
    Thanks Max!!!! That is EXACTLY what I have been trying to find out. Rep added bro!
    Ken
  14. Mar 7, 2014 at 6:59 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Everything I've read says it should be 1/8 British standard pipe. Aftermarket gauges will be 1/8 not. I'd order it personally.
  15. Mar 7, 2014 at 9:27 AM
    keninsb
    Ken
    Goleta, CA
    I think you are right. I ordered it yesterday! Thanks again,
    Ken
