Idiot's FAQs about upgrading stock headlights
Discussion in '3rd Gen. Tacomas (2016+)' started by OilTruck, Feb 21, 2019.
What are you running in your low beams?
  1. OEM Stock Halogen
    34.8%
  2. Performance Halogen
    26.1%
  3. Alternative Halogen (e.g., H9 instead of H11)
    4.3%
  4. HID
    14.8%
  5. LED
    19.1%
  6. OEM HID
    0 vote(s)
    0.0%
  7. "Proper" HID
    0.9%
  1. Feb 21, 2019 at 8:26 AM
    OilTruck
    OilTruck [OP] Well-Known Member
    Peter
    Katy, TX
    2016 SR Stick 4x4 Access Utility
    I have a 2016 SR Utility Package and after hours on TW don't understand / can't figure out if I have projector headlights or reflectors. I would like brighter headlights that travel further than the stock setup.
    Without having to replace the housing(?) or installing relays is there an easy plug-and-play option to increase my headlight output by simply changing the bulb?
    I don't care what type (halogen, hid, led) but I don't want it to burn out next week and I don't want to have to modify anything to get the bulb in.
    Any suggestions? Thanks!
  2. Feb 21, 2019 at 8:38 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Either way you can run the same bulbs, just will get a proper cutoff and with the projector with hid/led. I'd say you have the reflector housing, just do something like this.
    OSRAM NIGHT BREAKER LASER H11, next generation, 150% more brightness, halogen headlamp, 64211NL-HCB, 12V, passenger car, duo box (2 lamps) https://www.amazon.com/dp/B07FXRDJW2/ref=cm_sw_r_cp_api_i_ioTBCbGKDR8YW
    Literally takes 2 min to swap bulbs
    xxTacocaTxx, OilTruck [OP] and WYJH22 like this.
  3. Feb 21, 2019 at 8:42 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
  4. Feb 21, 2019 at 9:19 AM
    OilTruck
    Peter
    Katy, TX
    Seems like the OSRAM is a good alternative for OE swap. Seems like HID might get better lifespan for the price though?
  5. Feb 21, 2019 at 9:22 AM
    King Kermit V
    King Kermit V Well-Known Member
    Kermit
    Miami, FL
    2018 Black Tacoma SR5 DCSB
    Taco sauce
    I switched to GE 130+ H11 Megalight (or ultra light I forgot). The output is by far waaayyyy better and not yellowish. Went on a dark road here and I think I blinded a squirrel crossing the road.
  6. Feb 21, 2019 at 9:25 AM
    OilTruck
    Peter
    Katy, TX
    How long have those GE's lasted? I'm just reluctant to drop cash on halogens that have a short life expectancy.
  7. Feb 21, 2019 at 9:27 AM
    Dmeezy333
    Dmeezy333 Well-Known Member
    2015 White Tacoma TRD Sport
    Auxbeam LEDs. They are plug and play and have Major output. Both fogs and headlights are 6000 lumens. For a 2nd Gen Tacoma the headlights are H4s and fogs are H1120190219_160545.jpg 20190219_160419.jpg
  8. Feb 21, 2019 at 9:29 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    hows the cutoffs with the H4 headlights, set up looks good
  9. Feb 21, 2019 at 9:30 AM
    OilTruck
    Peter
    Katy, TX
    Do you notice focus issues with the beam at distance? It seems like the consensus is that LEDs don't focus as well because they lack omni-directional output.
    Rainoffire and BillsSR5 like this.
  10. Feb 21, 2019 at 9:31 AM
    King Kermit V
    Kermit
    Miami, FL
    Taco sauce
    So far the full 3 weeks I’ve had them lol. They last about a year maybe more depending how often you use them I guess.
  11. Feb 21, 2019 at 9:32 AM
    Dmeezy333
    The lights focus perfectly. I can literally light up signs from 3 blocks away. They light everything up. Especially with the fogs on.
    BillsSR5 likes this.
  12. Feb 21, 2019 at 9:33 AM
    BillsSR5
    bill
    2014 SR5
    don't the 3rd gen trucks have projector style lense low beams and the highs are standard reflector housings? in the low beam projectors I would think they would focus better than standard houisings
  13. Feb 21, 2019 at 9:33 AM
    OilTruck
    Peter
    Katy, TX
    I guess if you're putting out 3k lumens per bulb instead of 1.3k, it doesn't really matter if it's slightly out of focus...
  14. Feb 21, 2019 at 9:35 AM
    BillsSR5
    bill
    2014 SR5
    are those H4s have the adjustable beams where you can unlock a allen screw and twist the bulb till u get the cutoff u want? can use still use the Rubber boots even with the Heat sink?
  15. Feb 21, 2019 at 9:35 AM
    Dmeezy333
    That's also another thing I forgot about. I dont have projector lens. So I guess I wouldn't know what they would look like in those.
  16. Feb 21, 2019 at 9:36 AM
    Dmeezy333
    As far as I know they dont have any adjustment key.
  17. Feb 21, 2019 at 9:39 AM
    OilTruck
    Peter
    Katy, TX
    Any suggestions?
  18. Feb 21, 2019 at 9:40 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Look for h9 swap
  19. Feb 21, 2019 at 9:41 AM
    Vbpiper
    Vbpiper Well-Known Member
    2016 BBP SR5 DCSB 4x4
    AVS Bugflector II, WeatherTech mud flaps, Gentex Homelink/compass mirror, OEM bed mat, SolidFold 2 tonneau
    Xenon Depot Xtreme HID H11 for the low beams. I have had mine for well over a year with zero complaints. I hardly ever use high beams, but stick with a halogen in the high beam reflectors if you feel the need to change them.
  20. Feb 21, 2019 at 9:42 AM
    Vbpiper
    OP didn't want to have to alter the bulb or connector according to his original post, which would be necessary to use H9s in the low beams.
