Idle air Control Valve Probs P0505
Discussion in '4 Cylinder' started by mitymelvin, Aug 17, 2011.
  1. Aug 17, 2011 at 5:50 PM
    mitymelvin
    mitymelvin [OP] Active Member
    Hudson, NC
    01 Taco/2.7/5sp/Ext Cab/4X4/SR5
    Anyone else have a P0505 code and have to replace the IAC? I have removed it twice to clean it but it still gives me the code. I did a lot of research and found a replacment part made by SMP. I hope it is a decent part. I was hoping to go for a while before having to replace it, but it has now started to idle at about 1800 rpms and then suddenly drop to 1000, then back. Just looking for suggestions....................:confused:
  2. Aug 21, 2011 at 7:42 AM
    mitymelvin
    Hudson, NC
    Any help out there?
  3. Sep 13, 2012 at 1:56 PM
    mikey1390
    mikey1390 New Member
    07 TRD SR5
    short ram air intake, performance chip, 2" lift
    did you ever find the problem because i got the same code
  4. Sep 14, 2012 at 8:15 PM
    mitymelvin
    Hudson, NC
    Yes, I replaced the IAC and it hasnt given me the code since then. I bought it from either Rock Auto or on Amazon.com.
