idle coasting to a stop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HXC, Apr 26, 2012.
  1. Apr 26, 2012 at 8:41 PM
    HXC
    HXC [OP] Well-Known Member
    Cory
    Houston, Texas
    2011 white Dbl cab 4x4 6spd man.
    I have a TRD off road quad cab 6 speed manual, when I coast to a stop the RPM is stays around 1400 RPMs. What is with that seems like it doesnt really seem to be good for gas mileage.
  2. Apr 26, 2012 at 8:50 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    Learn to downshift.
  3. Apr 26, 2012 at 8:53 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Does it only happen when you first drive? Or all the time?
    If it's the former, then your engine just isn't warm enough yet. On cold mornings, my truck will idle at 1500 for a minute or so until it warms up.
    Oh, and you should not be coasting to a stop, you should be downshifting.
  4. Apr 26, 2012 at 8:54 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    your engine load is actually less when coasting in gear then while in neutral (at a certain point you need to downshift again)
  5. Apr 26, 2012 at 9:06 PM
    HXC
    Cory
    Houston, Texas
    I do downshift its within the last few feet before a complete stop. I understand why it would during a cold engine stop, but not when I am getting home from a 20-30 minute drive home from work.
  6. Apr 27, 2012 at 2:42 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    Oh, and you should not be coasting to a stop, you should be downshifting.[/QUOTE]
    Why should he be downshifting rather than coasting to a stop? If you have to stop, downshifting causes more wear on an expensive clutch than coasting and wearing cheap and easily replaceable brake pads.
  7. Apr 27, 2012 at 2:46 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Why should he be downshifting rather than coasting to a stop? If you have to stop, downshifting causes more wear on an expensive clutch than coasting and wearing cheap and easily replaceable brake pads.[/QUOTE]
    DITTO HERE!!
    BRAKES are cheaper than a CLUTCH
  8. Apr 27, 2012 at 2:53 PM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
    Properly done, downshifting shouldn't cause any more wear and saves on brakes by using the engine. If you're really doing it right, you don't even need to clutch.
    The engine remains engaged and in the correct power band in the event you need to accelerate or maneuver.
    It saves fuel, because the ECU will let the momentum of the truck drive the engine instead of gasoline by cutting fuel flow when appropriate.
  9. Apr 27, 2012 at 5:09 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It takes the stick V6 time to return to idle that's the way it is, does the same thing if you click off the cruze.
  10. Apr 27, 2012 at 5:13 PM
    dpalmer619
    dpalmer619 Well-Known Member
    Derek
    San Diego
    '07 White TRD sport doublecab
    Icon 2.5 coilovers
    What he said!! Its not as safe coasting in neutral to a light or stop sign either. If you needed to get out of the way of something its a lot safer to still be in gear then trying to react and put it in gear
  11. Apr 27, 2012 at 5:29 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    I'll disagree with this statement. If the transmission was non-synchroed I would agree ( I drive truck for a living and other than starting and stopping never use the clutch ). But with synchros and a gas engine you will do more harm than good. Most gas engines ( not our 4.0 because it seems to hold RPM as part of it's programming for a bit ) drop off too quickly to make a good matched shift,and you're forcing the synchros causing wear or damage.
  12. Apr 27, 2012 at 5:46 PM
    ouyin2000
    Arlington, Virginia
    '11 DCSB TRD Sport
    Correct.
  13. Apr 27, 2012 at 7:20 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    i agree with f75 gunslinger,i have over 1.3 million miles safe driving,it is not a peterbilt its a tacoma.
  14. Apr 28, 2012 at 4:20 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    This^ unless you are 100% right all the time you are causing the syncros to force the gears to slow or speed up if it gives you even the slightest resistance it's not matched. It far easier to replace a clutch then the syncros and if you don't abuse your clutch you'll get 200K out of it.
  15. Apr 28, 2012 at 6:23 AM
    mcgiiver
    Princeton, NJ
    Firstly, it's much easier to upshift without the clutch than downshift. I would be very surprised if you could go from 5th or 6th gear down to 1st gear, without using the clutch , and have no gear crunching.
    Secondly, when downshifting, the engine is nowhere near the proper power band needed for acceleration, unless your downshifting at ungodly high engine speeds.
    Thirdly, the amount of fuel you save by having the ECU cut off fuel is well offset by the expensive wear on the trans and clutch disc. Any time the the clutch is used and the flywheel and clutch disc are not PERFECTLY matched in speed, there will be wear.
    From a wear and economy standpoint, the optimum way to slow these trucks to a stop is to first anticipate the necessary stop from way back and let off the gas, in gear, as early as possible. Then let the truck decellerate on its own, in gear, with injectors shut off, until you reach a speed at which the engine would lug. Then depress the clutch and gently apply brakes, which should now be minimally necessary.
    The way these trucks are programmed to hold the RPMs up when decellerating makes it very difficult to downshift properly in the traditional way. As stated, these trucks are very, very different than a Peterbilt.
  16. Apr 28, 2012 at 6:45 AM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
    Well, yeah. It'd be easier yet if there wasn't ~100ms of throttle lag, too.
    But, that's why I said if you're "really doing it right"; I was kind of being a smart ass about it. It' s possible, but only really useful theoretically.
    Point remains, however, that excessive clutch wear is because of the nut holding the steering wheel.
