Idle too high...
Discussion in '1st Gen. Tacomas (1995-2004)' started by xxlap1xx, Oct 9, 2010.
  1. Oct 9, 2010 at 10:17 PM
    xxlap1xx
    xxlap1xx [OP] New Member
    Hi guys... im new to the forum... i just bought a 03 tacoma 2.4liter with 180k... the car runs pretty good... but what happen is that my idle seems to be a bit high than regular cars.... when i put the car to P or N my engine runs pretty loud... i dont have a rpm gauge in my dash board... but i dont think the idling is normal.... also, when i release my brake when im on D gear, my car will go like 17mph... so this makes me wonder that my idling is not right... are there any ways to fix my idle? I already checked my throttle body, it's not the cable that's pulling it too hard....any help will be appreciated... thanks
  2. Oct 9, 2010 at 10:25 PM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    my 06 does the same damn thing
  3. Oct 10, 2010 at 8:19 AM
    Madjik_Man
    Colorado Front Range
    I'll have to look it up but I had the same problem and it ended up being an idle position sensor (or something like that).
    Someone who knows what they're talking about (read: not me) will probably know what part I'm trying to think of. If not, I'll dig through the maintenance records and tell you.
  4. Oct 10, 2010 at 4:41 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    ^ I think you mean Idle Air Control Valve.;) Although not completely sure what it could be. Id just clean out your throttle body/idle air control valve/maf sensor/seafoam and see if it helps. But Idk..:confused:
  5. Oct 11, 2010 at 9:02 AM
    Madjik_Man
    Pretty sure it was a throttle position switch (or something like that)
    First thing we did was make sure the throttle body was clean. It was. Then we found that it was the throttle position switch (or whatever it's called)
  6. Oct 11, 2010 at 9:05 AM
    98tacoma27
    Ben
    Not Beech Creek
    Throttle Position Sensor.
  7. Oct 11, 2010 at 9:16 AM
    xxlap1xx
    thanks for the replies guys... i'll go check out the tps first and see what happen...
