Idler Pulley Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Flo_TRD07, Feb 23, 2022.
  1. Feb 23, 2022 at 8:32 AM
    Flo_TRD07
    Flo_TRD07 [OP] Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    Hey all. So I’m currently working to diagnose a weird vibration sound that I think is coming from either my idler pulleys or water pump pulley/bearing. I’ve been doing some research and found that the water pumps tend to go bad but my truck isn’t overheating or leaking coolant from there… I took my serpentine belt off and noticed some play in my idlers as well as a lot of play from my water pump pulley. At the moment, I have found the idlers on the Toyota OEM website but there’s two different ones (part numbers). I know I need to get two idlers of the same size and then a third being a different size. I’m just not sure which ones to get. If that doesn’t fix the issue I’ll be getting a new water pump so fingers crossed. Any help is appreciated.2C967BAB-ABC5-415E-BFE0-3E04A20B6D46.jpg
  2. Feb 23, 2022 at 12:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There should be zero play in the water pump bushing. I'd start there
    Flo_TRD07[OP] and Too Stroked like this.
  3. Feb 23, 2022 at 4:08 PM
    Flo_TRD07
    Ben
    Truck things
    I kind of figured as much. I'll go ahead and replace that as well. However I still want to replace the idlers because like I said there's play in those as well.
    Steves104x4 likes this.
  4. Feb 23, 2022 at 4:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Feb 23, 2022 at 4:25 PM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    The toyota parts website is pretty vauge on this.
    https://parts.lynchtoyota.com/oem-parts/toyota-accessory-drive-belt-idler-pulley-166030p030?c=Zz1jb29saW5nLXN5c3RlbSZzPWJlbHRzLWFuZC1wdWxsZXlzJmw9NSZuPVNlYXJjaCBSZXN1bHRzJmE9dG95b3RhJm89dGFjb21hJnk9MjAwOSZ0PWJhc2UmZT00LTBsLXY2LWdhcw==
    Pretty sure you need 2
    Accessory Drive Belt Idler Pulley - Toyota (16604-0P011)
    and one
    Accessory Drive Belt Idler Pulley - Toyota (16603-0P030)
    If your water pump bearings are loose at all, you need to replace it immediately. Better to replace it when its convenient for you, rather than have it strand you or worse yet overheat your engine.
    Flo_TRD07[QUOTED][OP] and [KD] like this.
  6. Feb 23, 2022 at 4:34 PM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    This is correct, I just replaced one of my uppers
    Edit: you can also just press out the bearing and replace that - for the uppers it's a 6302-2RS and you can get them on Amazon
    Flo_TRD07[OP] and vtown[QUOTED] like this.
  7. Feb 23, 2022 at 4:44 PM
    Flo_TRD07
    Ben
    Truck things
  8. Feb 23, 2022 at 4:44 PM
    Flo_TRD07
    Ben
    Truck things
    Gotcha, yeah I’ll be replacing that first now, thank you!
  9. Feb 23, 2022 at 4:46 PM
    Flo_TRD07
    Ben
    Truck things
    Anything special I need to press out the bearings? I’ve never done that before:confused:
  10. Feb 23, 2022 at 11:45 PM
    Flo_TRD07
    Ben
    Truck things
    Well, I feel entirely stupid. I meant my POWER STEERING PUMP not my water pump... I just ordered a new power steering pump and will hopefully have it replaced this Saturday. Still racking my brains about what pulleys to buy. I.E. I still don't know which idler part numbers go with Idler 1 vs Idler 2 since there is a 16603 and a 16604 pulley.
  11. Feb 24, 2022 at 2:23 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Just put your VIN # in and correct #s come out for you.
    First step is remove belt and check all then proceed.
    Yes 2 the same and 1 diff plus and don't forget the tensioner pulley. If high miles go ahead and bite the bullet and replace the whole assembly (mine was weak so allowed belt slip at full throttle - feel and yes smelled it - pain to change assembly as alternator has to come out and AC compressor unbolted and moved some - many posts and that. more info:
    Idler pulleys, tensioner, belt, and alternator replacement | Tacoma World post #7 has part #s for my 09. If doing only the tensioner pulley it is reverse thread to remove off assembly. Idlers are all normal direction.
    A note that I used ToyotaPartsDeal.com but their filling of orders has become very slow if at all so beware.
    Flo_TRD07[OP] likes this.
  12. Feb 24, 2022 at 6:37 AM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Hydraulic press would be ideal but most people don't have one of those sitting around.. Bench vise would be the next best thing but I don't even have that - I would use a hammer and a piece of pipe or a deep socket the same outside diameter as the bearing. Results may vary lol...
    Flo_TRD07[QUOTED][OP] likes this.
  13. Feb 24, 2022 at 8:13 AM
    Flo_TRD07
    Ben
    Truck things
    Yeah the tensioner feels strong and I haven’t noticed any belt slip but I’ll see about tackling that next. I’m just trying to go from worse outcome of not being done to “eh i’ll just go ahead and replace it”
  14. Feb 24, 2022 at 10:59 AM
    TnShooter
    Deogee
    STOCK
    Hammer, 2 blocks of wood, and a deep well socket.
    Wood is for not damaging the pulley.
    Lay the pulley on the 2 blocks wood. Drive the old bearing out. It won’t hurt to drive the bearing out on the center race. It old, you won’t be reusing. No need to worry about damaging it.
    Then use the old bearing and deep well socket to drive the new bearing in. You use the old bearing because it is the same diameter as the new one. I still like to use a deep well socket as close as I to the the same size as outside race when driving back the bearing in.
    Just remember, lay pulley on the wood.
    That way you don’t damage it.
    [KD] and Flo_TRD07[QUOTED][OP] like this.
  15. Feb 24, 2022 at 4:53 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    From what I have read it is normal to have some end play at the PS pulley, I recently checked mine and I have about 1mm end play. There is no side-to-side play; only in and out.
    There are many videos on youtube on how to replace the bearings if you don't have a press. If you don't do it right, you can damage the bearing. You can remove the bearing by pressing it out from the back of the pulley. But, when pressing it onto the pulley, you have to press on the outside of the race so you don't damage the bearing.
    Easy way is to replace the pulley/bearing items. You need one #1 idler pulley (Gates/AC#36174) and two #2 idler pulleys (Gates/AC#36173). Last time I checked, only Febest makes a pulley/bearing for the tensioner, 0187-GRJ200.
    To replace just the bearings in the idler, you need 4, size 10X42X13; bearing type 6302RMX. The #1 idler pulley (next to the AC) takes two bearings. Tensioner bearing size is 17X40X17.5; bearing types 5203-2NS, 5203-2NSL, or 5203-2RS.
  16. Feb 24, 2022 at 5:11 PM
    Flo_TRD07
    Ben
    Truck things
    Appreciate the info. My PS pulley moves forward backward left right. You tell it move a certain way and it goes! I think I'm just going to buy all new pulleys/bearings and call it a day.
  17. Feb 24, 2022 at 6:23 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Then, save your old pulleys and replace the bearings at your convenience, and you now have some backups. PS pump does sound shot if it has side play.
  18. Feb 24, 2022 at 8:04 PM
    Flo_TRD07
    Ben
    Truck things
    WILCO, thanks for all the advice!
