Idler Pulley Tensioner
Discussion in '1st Gen. Tacomas (1995-2004)' started by NegroTundra, Nov 26, 2010.
  1. Nov 29, 2010 at 8:52 PM
    mortuusangelus
    mortuusangelus Well-Known Member
    Michael
    Slate Hill, NY
    no truck now :(
    Could be the tensioner pulley for the A/C.. or it could the be timing idler pulley(s)... those you do not want to fuck with, just replace 'em.
  2. Nov 30, 2010 at 4:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    :rolleyes: Ok then...whatever you want to believe. I work on machinery for a living - and I know what a tensioner is and bearings & such. I did this work myself many many years ago and I don't own the truck anymore.
    I did go to a bearing shop (Brown Bearing). Gave them the old bearing and told them what I needed it for. So - perhaps the doofus at the counter gave me the wrong bearing for the application. I pressed it in and it oozed & squeeled. I bought an OEM unit after that.
  3. Nov 30, 2010 at 7:23 AM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    no need to get your panties in a knot. I was just asking what that bolt was because it looks just like the adjustor bolt on the newer 3.4s.
  4. Nov 30, 2010 at 8:15 AM
    NegroTundra
    NegroTundra [OP] Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    I have to agree with quattrokiwi...that 5 o clock bolt he mentions is the same one that relieves the tension on my a/c belt....AFTER you loosen the bolt in the tensioner pulley itself.
  5. May 27, 2013 at 12:33 PM
    Coma 1
    Coma 1 New Member
    96 Toyota Truck
    Help!
    I have a 1996 Toyota Tacoma truck 4 cylinders - Automatic transamission
    I need to replace the Upper Pulley, Front of the radiator (not the bottom one, close to the engine block)
    but behind the pulley there is a long bolt, kind like in a small metal frame box, just don't know if is that what will loosen the tension of the belt, (which I already remove and nothing happend to the belt)
    or just have to remove the bolt that is in the center of the Pulley?
    (wich I already try and it is hard to remove with the tension belt on, bolt starting to get worn out, so I stop)
    What or How will lose the tension of the belt and how to remove bolt of the pulley?
    Thanks, I appreciate your comments!
  6. May 27, 2013 at 1:02 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
  7. May 27, 2013 at 2:46 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Which belt are you trying to loosen? The upper pulley may be the PS pump pully?..
    The Ac idler pulley was 6301 I believe (bearing p/n)
  8. Jun 3, 2013 at 9:41 AM
    Coma 1
    Coma 1 New Member
    96 Toyota Truck
    Help! I have a 1996 Toyota Tacoma truck 4 cylinders - Automatic transamission
    I need to replace the Upper Pulley, the one in front toward the Radiator,
    (not close to the block engine bottom), but behind the pulley there is a long bolt, kind like in a small metal frame box, just don't know if is that what will loosen the tension of the belt? (which I already took out and nothing happend to losen the belt)
    It is hard to remove and getting almost worn out so I stop to remove the bolt center of the pulley
    What or How will lose the tension of the belt or how to remove the pulley?
    Thanks
  9. Jul 26, 2013 at 2:39 PM
    LAnaya
    LAnaya New Member
    new mexico
    toyota tacoma
    My adjusting bolt broke on the bracket to my pulley. Anyone know where to get another?? Toyota says they don't sell it???
  10. Jul 27, 2013 at 2:00 AM
    Janster
    Jandy
    Lancaster, PA
    Do you have the pieces of the bolt?
    Go to your local hardware store and pluck around at the nuts to find out what thread/size it is. If you can measure the broken one or someone here can measure theirs..... to get the length.
    If its a specialty size...might need to order it online like McMaster Carr.
    http://www.mcmaster.com/
  11. Dec 26, 2013 at 5:03 PM
    Darrell Duncan
    Darrell Duncan New Member
    Do you have to buy a new belt when you replace idler bearing? and do you use sealed bearings or the plastic covered ones?
  12. Dec 27, 2013 at 6:43 PM
    Darrell Duncan
    Hi Everyone,
    does a tranny whine like idler bearings?
  13. Oct 13, 2015 at 5:02 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Yep... another revival.
  14. Oct 13, 2015 at 6:26 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    I will help revive it again. Not all tensioner pulleys are easily serviced by means of inserting another bearing. The later ones have a metal plate over the bearing.
  15. Sep 19, 2018 at 7:29 PM
    #35
    BenSkiv
    BenSkiv Well-Known Member
    Ben
    Maine
    2019 Tacoma TRD-off-road DCLB
    Was the whine you got similar to the sound of a power steering pump failing? Mine sounds like a bad power steering pump but the noise doesn’t change when I turn, and I used an automotive stethoscope and am pretty sure it’s the bottom pulley. I just want to make sure I am correct before I replace it or the bearing. Might just replace the whole pulley, the one on it is pretty rusty.
  16. May 6, 2019 at 11:28 AM
    #36
    DimeGirlTX
    DimeGirlTX Member
    Marie
    Spring Tx 77373
    1997 Toyota Tacoma Extended cab 2.4, RWD
    Trying to keep it in shape and running nicely.
    I don't know if I should buy another tensioner and idler pulley that looks just like the one on it or buy one that is sealed and red.
    GQ7227 likes this.
  17. May 7, 2019 at 9:08 AM
    #37
    GQ7227
    GQ7227 mw survivor
    J A Y
    would this part(s) going bad in any way send a sharp rattle into the passenger side of the cab
    it only seems to happen after the A/C has been on for awhile then turned off while still driving
    then whenever I accelerate there is some annoying rattle coming from passenger side,
    I suppose the 2 silverish tubes coming through from the engine compartment go somewhere
    ... don't know beans about this A/C stuff
  18. May 7, 2019 at 11:04 AM
    #38
    DimeGirlTX
    DimeGirlTX Member
    Marie
    Spring Tx 77373
    Yes, I am replacing all pulleys I see that some are sealed red/green in color and some have the O-Ring on it as the original one have.
  19. May 7, 2019 at 11:07 AM
    #39
    DimeGirlTX
    DimeGirlTX Member
    Marie
    Spring Tx 77373
    I wanted to know if one store brand is better then the other. I think I am going to go with the sealed pulleys.
