Idler pulleys bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dianna, Mar 18, 2022.
  1. Mar 18, 2022 at 1:38 PM
    Dianna
    Dianna [OP] Well-Known Member
    Dianna
    Ohio
    -06 Tacoma Sport -77 FJ40 -14 4Runner Trail Premium -19 Tacoma TRD Sport Cement Gray
    2006, 135,000 miles. First belt was replaced at 70,000 miles and it looked fine. A third of the belt shredded away at 135,000 miles. Other than missing a third of it, the belt looks fine. Should I replace these idler’s? https://youtube.com/shorts/AUCssS1Loc4?feature=share
    optifree and wilcam47 like this.
  2. Mar 18, 2022 at 2:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Absolutely. You should replace those idlers.
    Kind of wondering if you are serious here. Lol?
    Those things are bad, really bad.
  3. Mar 18, 2022 at 2:07 PM
    Dianna
    Dianna
    Ohio
    Yes, being serious. All of them are bad? And thank you for responses!
    Steves104x4 likes this.
  4. Mar 18, 2022 at 2:09 PM
    Dianna
    Dianna
    Ohio
    Is this why my belt shredded?
  5. Mar 18, 2022 at 2:16 PM
    TnShooter
    Deogee
    STOCK
    Possibly.
    The 2nd one you spin in the video, is the “best”.
    But it is still noisy, you might as well replace it. It’s on it’s way out.
    The other 2 are shot.
    The idlers as a unit are expensive.
    You could just buy the bearings.
    https://www.tacomaworld.com/threads...arings-in-the-idler-tensioner-pulleys.480961/
    Remember the tensioner pulley is LEFT HAND thread.
    So you’ll be “tightening it” to loosen the bolt.
    Dianna[QUOTED][OP] and Hook78 like this.
  6. Mar 18, 2022 at 2:33 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Yeah that is the sound of a bad bearing. Change them. I will need to check on mine as well
  7. Mar 18, 2022 at 4:27 PM
    Dianna
    Dianna
    Ohio
    Love this forum, thank you!!!
    Not a golfer and TnShooter like this.
  8. Mar 18, 2022 at 4:33 PM
    Dianna
    Dianna
    Ohio
    Is there anything aftermarket that is remotely close in quality to OEM? I’m not sure I want to attempt trying to press in new bearings. Those OEM belts aren’t cheap either, lol I already purchased that and don’t want to shred it.
  9. Mar 18, 2022 at 4:40 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The bearings sound like the grease has dried out. Spin each one slowly - they should spin smoothly, with no gritty feel. Also, try and move each pulley/bearing up/down, side-to-side, and fore/aft; there should be no play. Also check the bearings in the water pump, PS and alternator. Note that the PS may have some fore/aft play - from what I’ve read, about 1-2mm play is normal, but only fore/aft.
    Dianna[OP] likes this.
  10. Mar 18, 2022 at 4:40 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I always replace all idler pulleys and the tensioner pulley when replacing a serpentine belt.
    OP, those all sound horrible!
    mquibble and Dianna[OP] like this.
  11. Mar 18, 2022 at 4:49 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Before I started replacing just the bearings, I always got good service life out of Gates pulley/bearing assemblies. See diagram below for part #s, which also used by AC Delco. The tensioner pulley/bearing is the only one not offered by Toyota nor most vendors. Last time I checked, only Febest offered a pulley/bearing - # 0187-GRJ200.
    Dianna[QUOTED][OP] likes this.
  12. Mar 18, 2022 at 4:55 PM
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
    2 Week ago when my local 4x4 shop did my front suspension, i asked them to check the belt and the pulley. The belt had some time but was still surprisely good but all the pulley however where done. 3 idler was still moving freely with some play and some noise they can grenade anytime soon. The tensioner pulley was shoot bad, hard to move even with my finger, the cage inside where probably destroyed. Replaced all of them with Gates pulley with a new belt. 224 000 km not bad for original stuff.
    I still have a faint bearing noise at cold start, disapearing quickly. We rotated the AC, alternator, ps and water pump and they had no play so still good i will monitor and inspect when thing get noisier.
  13. Mar 18, 2022 at 5:03 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I just noticed the fan and fan clutch are removed in OP’s video. Its not necessary to remove that nor the fan shroud to access the pulleys. It is easier to access from below. Remove engine guard and the two brackets.
  14. Mar 18, 2022 at 5:37 PM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Yup, Gates. That's what I use on my 1st Gen.
    Good stuff.
  15. Mar 18, 2022 at 8:00 PM
    Dianna
    Dianna
    Ohio
    When my belt shredded part of it ended up behind the fan, it also pulled off the oil cooler hose so I took that off to get a better look at what other damage might have been done. I also have a pinched nerve in my neck, looking down right now is a hell of a lot easier than looking up!
  16. Mar 18, 2022 at 8:01 PM
    Dianna
    Dianna
    Ohio
    Awesome help... thank you!
  17. Mar 18, 2022 at 8:03 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Shouldnt hear any noise, id change tensioner too
  18. Mar 18, 2022 at 11:51 PM
    Alealexi
    Houston, TX
    You won't be pressing them in since they are already preassembled. You just need to bolt them back on.
  19. Mar 18, 2022 at 11:53 PM
    Alealexi
    Houston, TX
    Best to go OEM with the tensioner. Part number is 16620-31013.
  20. Mar 18, 2022 at 11:53 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Gotcha. My back makes it easier for me from the bottom. Lol. Hopefully, the belt shredded from old age and not due to misalignment of a pulley. Check that harmonic balancer as some are known to separate. Turn on engine for a minute or two and check that the HB doesn't wobble.
