Idler Pulleys / Tensioner Pulley / Serpentine Belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CIAGDDS, Jun 2, 2013.
  1. Oct 10, 2018 at 4:45 AM
    #161
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I guess the inside diameter is the hole size. I’ll have to measure that. I can’t tell if it’s 12mm or 17mm from the pics.
  2. Oct 10, 2018 at 5:18 AM
    #162
    TheDevilYouLove
    Marylandistan
    What is the reason that a Gates lower idler pulley (36174) wont also work as a tension pulley? Sounds like just the offset is slightly different but the belt still fits. I’m reading online that folks have used them as tension pulleys.
  3. Oct 10, 2018 at 9:16 AM
    #163
    Smoke2
    Smoke2 Well-Known Member
    Tacoma
    07 DC 4X4 LB
    Rear TSB, Firestone Air bags
  4. Oct 28, 2018 at 3:20 PM
    #164
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    The Gates tensioner does not use 36174, it uses a different pulley with a shallower offset. The 36174 will stick out too far and, as far as I know, there's no fix for that. Per threads on this forum I ordered the Febest for my '06 Tacoma and installed it today. It (and the other idlers) fixed my squealing and chirping. Third vehicle I've done this to, two Tacomas and my 4runner.
    07 sport 4x4 likes this.
  5. Oct 28, 2018 at 4:25 PM
    #165
    zach101
    zach101 Mr.Ph1lip
    Zach
    2005 Tacoma DblCab TRD Sport
    X2 on just swapping out the bearings. Super easy and very cost effective.
  6. Oct 28, 2018 at 5:00 PM
    #166
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Because of the offset, the bolt will engage with half the threads. Yes, folks have used them; it's a gamble I wouldn't recommend when it's so easy to just replace the bearing or get the Febest pulley if your pulley is damaged.
  7. Dec 15, 2018 at 11:39 AM
    #167
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    Just went through replacing mine, i thought id have to replace the entire tension assembly, but it turns out that the bearing itself can be replaced in like 10 mins. 15/10 easy job. I bought the 36174 and realized thats for the bottom idler pulleys, so i went back and got the 36173 and it didn't fit the idler pulley but it fit the tension pulley (both needed to be replaced anyways).
  8. Dec 26, 2018 at 5:17 PM
    #168
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    So I replaced all the idler pulleys and the tensioner pulley with advice from this thread. I was noise free for about six months there. Lately on cold nights, I started to get a squeak again for about 5 minutes. I used a stethoscope to track down noise. I'm not getting any noise from the new pulleys, power steering or the alternator. I can't find a non-moving part to listen to the water pump but that's my guess. Here's the video. At 134,000 miles any ideas as to which is the next likely culprit? Would it sound like this?
    https://youtu.be/s-PYXL5wJnM
  9. Dec 26, 2018 at 7:01 PM
    #169
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    check your heat shields on the exhaust.
    Benny123[QUOTED] likes this.
  10. Dec 27, 2018 at 9:58 AM
    #170
    Benny123
    Ben
    South Charlotte, NC
    Thanks for the advice. Im going to try that tomorrow. And also try spraying water on the belt from video by ChrisFix. My noise does sound a bit like that, so maybe its the belt or pulley misalignment. 6000 miles on a new belt.
    https://www.youtube.com/watch?v=AEUe6uKxTv8
    Also, anyone good with photos should probably update the serpentine belt image/diagram and put at the top of the thread to reflect new knowledge in the tensioner pulley area.
  11. Dec 27, 2018 at 1:50 PM
    #171
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    I am not too far away for replacing my idler pulleys, belt, and tensioner bearing. From what I gather on this thread is there is not direct pulley replacement for the tensioner ? My tensioner is good but I want to change the tensioner bearing if I'm going to replace all the pulleys. I was going to get the gates idler pulleys and get the Nachi 17x40x17.5 bearing to use in the tensioner pulley. Is there a write up on how to replace the bearing only in the tensioner pulley ? TIA
  12. Dec 27, 2018 at 3:12 PM
    #172
    Fullboogie
    Dave
    Houston
    You didn't look very hard, because the answer to your tensioner pulley question is 7 posts up.
  13. Dec 27, 2018 at 3:38 PM
    #173
    06TXED
    Tony
    Aurora CO
    I did see the post about the FEBEST pulley but don't know the quality of the bearing compared to the NACHI bearing ? How's the FEBEST bearing holding up ?
  14. Dec 27, 2018 at 3:45 PM
    #174
    Fullboogie
    Dave
    Houston
    Good so far, and I bought it based on others' recommendations. I am looking to get the Nachi bearing as a backup since I have three trucks with the 4.0.
  15. Dec 28, 2018 at 5:16 AM
    #175
    Benny123
    Ben
    South Charlotte, NC
    Fwiw Using Chris fix video I figured out it was the belt. Noise stopped as soon as I sprayed it with water. Pulleys are fine. For reference, you can hear the noise in my video from an earlier post (#169). New Dayco belt with 5000 miles. On the hunt for a gatorback belt now. Word to the wise, the noise may not be your pulleys.
  16. Dec 28, 2018 at 7:02 AM
    #176
    Newfiebruh
    Tom
    DONT get the gator back they're garbage
  17. Dec 28, 2018 at 7:52 AM
    #177
    Benny123
    Ben
    South Charlotte, NC
    Good to know.
  18. Dec 28, 2018 at 12:19 PM
    #178
    TheDevilYouLove
    Marylandistan
    TOMB and Benny123 like this.
  19. Jan 5, 2019 at 9:13 AM
    #179
    sbu249
    sbu249 Well-Known Member
    Rhode Island
    2012 Pyrite Mica TRD Sport
    Has anyone tried Dorman brand pulleys? Looking to replace the three idlers when I do my serpentine belt just as a little PM while in there... got an OEM belt from stealership for $50. Quoted $89/pop for upper pulleys and $101 for single lower :crazy:
  20. Feb 26, 2019 at 8:04 PM
    #180
    LolaRacerT440
    LolaRacerT440 New Member
    2013 DoubleCab TRD
    Firestone airbags, 5100s, heavier front springs
    Hey folks, I went the OEM parts route today. My local Toyota dealer actually had the parts better priced than any of the other places listed. Not all parts on hand, but they had them within 24 hours and local pickup was sure nice.
    https://parts.stevinsontoyotawest.com/
    A few comments about the OEM route - and yes this may be mentioned above, but as I was first reading all this on my phone rather than with a computer, I may have missed it - when using OEM parts with the stock tensioner, neither the type 1 nor type 2 pulley fits on the tensioner; also Toyota does not sell the tensioner pulley alone, just with a new OEM tensioner. Toyota has a boss on the tensioner the pulley bearing ID rides on, so it is bigger ID than the other 2 types of pulleys.
    Which pulley was bad you ask? The very bottom one, which makes sense given its location and exposure to the elements. The belt? It looked pretty darned good for 100K miles, with just a few cracks. I'll be more confident taking it on the road with the new belt.
    Now let's just hope it wasn't one of the accessories that was squeaking at sub 40 degree temps; we have cold weather coming so I'll test it this weekend.
    Lastly, because of the aforementioned details re: the tensioner pulley, I have an extra brand new 16603-0P030 pulley sitting here in the box that needs a home, and I'm too humiliated to return it to the parts guy who told me three times it would not work :)
    Would anyone like this one for $55.00 shipped CONUS? My newbie status won't let me post it for sale in the BST forum. PM me please if interested. Thanks.
