IFS Axle Tubes
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco, Nov 16, 2009.
  1. Nov 16, 2009 at 1:10 PM
    El Taco
    El Taco [OP] Well-Known Member
    STP MN
    Gents,
    I've already looked the at the FSMs and still need your advices before attempting...
    I have aquired an ADD front IFS diff and have a non-ADD IFS axle tube (jack-shaft). These are all from the same generation trucks. I want to go ALL manual with manual hubs too.
    Can I simply "bolt on" the non-ADD axle tube (jack-shaft) into the ADD front IFS diff without having to do expensive press-work for bearings or whatever?
    thx.
  2. Nov 18, 2009 at 4:00 PM
    El Taco
    STP MN
    DANG...nothin'
  3. Nov 18, 2009 at 5:18 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    All you should have to replace is the tube. you dont need to replace the whole diff. do you have the Manual Spindles? and Hubs?
  4. Nov 18, 2009 at 5:42 PM
    El Taco
    STP MN
    i will get the manual hubs/spindles but just wanted to be sure that i can simply "bolt on" the tube to the ADD diff, that's all.
    thank you.
  5. Nov 18, 2009 at 5:48 PM
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    Try ttora.com for this question.
  6. Nov 18, 2009 at 6:00 PM
    El Taco
    STP MN
    have already, just thought i could get more responses by covering more areas. thanks.
