IFS removal
Discussion in 'Solid Axle Suspension' started by tlevan03, Aug 9, 2015.
  1. Aug 9, 2015 at 6:24 AM
    tlevan03
    tlevan03 [OP] Well-Known Member
    tad
    Whats the trick here? Is it easier to unbolt everything or try and be a badass and cut it out all together? I put my truck up on stands last night. Ill make a build thread shortly. Just wanted to know some of the techniques used. Thanks.
  2. Aug 10, 2015 at 4:13 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    If you have access to a plasma cutter, that will make life easy.
  3. Aug 10, 2015 at 7:13 AM
    tlevan03
    tad
    Yeah I've got a plasma. I think I've come up with a way. I will take plenty of pics for future reference
  4. Aug 10, 2015 at 10:18 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Cut the frame off in front of where it bends in and up. Make sure the engines supported and unbolted first.
  5. Aug 10, 2015 at 4:05 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Like slander said, cut it off and start fresh. I'll never do it the "old" way again
    ZUK and Large like this.
  6. Aug 11, 2015 at 8:41 AM
    tlevan03
    tad
    That would work, but I'm using leafs not links. I think I have a pretty good method of attacking it. It will be one night this week
  7. Aug 11, 2015 at 8:53 AM
    slander
    Hickory, NC
    It works with leafs as well! This is what I'm planning on doing. It takes less time to build a front frame then to cut and grind all that bull crap off, and then weld reinforcement plates on. Plus you can run the front end lower by not having to deal with the stock front frame horns, and can build your front spring or shackle hangars into the front cross-member, not needing to buy a pre made one.
    Large likes this.
  8. Aug 11, 2015 at 9:20 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Unbolt anything you plan to sell, after that have the truck lifted up on stands/ car lift and start cutting and watch the parts fall.
    Did this using a cutoff & sawzall
  9. Aug 11, 2015 at 5:31 PM
    tlevan03
    tad
    Yeah you're right. I'm too close to go get metal. I'm just going to let the plasma eat. I have some buddies that will grind for beer
  10. Sep 1, 2015 at 5:48 PM
    ZUK
    ZUK Gearinstalls.com
    Ken
    Chandler AZ
    2001 white Taco TRD 3.4L auto (SAS FJ60 flip) 35" KO2 5" AllPro leafpacks front and rear,
    SAS,1985 FJ60 flipped axle, 35" KO2,5" AllPro leafpacks front and rear,
    That is the way I wish I had done it. See this post #39 here in my long thread
    http://www.yotatech.com/f152/2001-t...onsiderations-283930/index2.html#post52235838
    Right after I torched off all the front bracketry, I took a closer look and it seemed so much neater to just cut where you did on the frame and let the whole thing come out as 1 big piece of crap. :)
    Hope the SAS suppliers read that.
