Ignition & Dash Illumination wires?
Discussion in 'Technical Chat' started by pasotaco, Jun 7, 2014.
  1. Jun 7, 2014 at 7:10 PM
    pasotaco
    pasotaco [OP] Well-Known Member
    Central Coast, CA
    2013 4x4 Access Cab
    LCE headers, King 2.5 Coilovers w/ res, TC UCA's, King resi's in rear, Geared to 4.88, rear locker, Timbren Bump stops, All Pro Leafs, Carrier bearing drop kit, ARB onboard air,
    I just installed an ARB compressor and I am wiring the switch. Can anybody tell me which wire is the "Ignition Wire" & which wire is the "dash Illumination Wire"
    I need to T-Tap them for the compressor switch... I have a 2013
    I would thing that everyone putting in aftermarket lights that use illuminated dash switches would need to tap these wires as well?
    Thanks...
  2. Jun 7, 2014 at 10:57 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just Lurking in the Darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    BHLM with amber LED "eyebrow" strips and Angry Red Eyes, Black Depo Tail lights, Knight Rider Hood Scoop Mod, Amber Grill Backlighting, Amber Lamin-X Fog light film, Fog Lights Anytime Mod, Black T-Rex Grill Inserts, Red interior LED lighting, Go Rhino 5" Oval Nerf Bars, Modified side mirror turn signals, Drill-less license plate relocation bracket. OEM Bed mat. Weather Tech floor mats.
    The solid Green wires have +12V whenever the parking lights are on. I have not had a need to find the dash illumination wire ....yet. I hope this helps you out.
    Oh yeah...the plug with the 3 wires below that plug also has constant +12V(Light Blue), Accessory +12v(White/Blue Stripe), and Ignition +12v(Dark Blue) wires.
    Just a suggestion. Get yourself a cheap multi-meter and do your own investigating into what wires do what. Its more fun that way :D
  3. Jul 15, 2014 at 3:06 PM
    manethon
    manethon TTAS
    Toronto
    Many
    this is my project tomorrow,
    I had to build my own harnesses for the Front and rear locker wiring, compressor with relay.
    Hopefully it all works out.
    Ill try publish which ever way i do it and what i find.
  4. Jul 15, 2014 at 8:01 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    The empty fuse location indicated by the red arrow in this picture also has +12v when the lights are on.
    I found this electrical wiring PDF for the 2013 on this forum too.
  5. Nov 19, 2014 at 8:02 PM
    nxrunner
    nxrunner Well-Known Member
    Nick
    Lafayette La.
    2015 Tacoma Double Cab 6 Speed
    Subbed for reference later
  6. Jun 10, 2015 at 8:51 PM
    ptwob311
    ptwob311 Curios Noob
    P
    Colorado Springs
    '15 Tacoma TSS 4x4
    Bone Stock :(
    same
  7. Jun 11, 2015 at 3:28 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Bought, not built:-P
    Sorry to thread jack OP.
    Shadow- by any chance do you know where I could tap into for the dome light? Getting ready to install 4Runner side mirrors on my 2015, and I have to hookup it up to the dome light to get the courtesy light/foot lamp feature to work.
    Thanks.
