Ignition Light Ring Mod help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by KerlyQ, Jan 29, 2013.
  1. Jan 14, 2016 at 7:15 AM
    #121
    amkaos
    amkaos Well-Known Member
    im confused here. does this mod need 2 parts (ignition ring, bezel) or 3 (ignition ring, bezel and or "little black plastic ignition ring cover" thing)??
  2. Jan 14, 2016 at 9:25 AM
    #122
    amkaos
    i use a remote starter all the time. when i remote start, then enter car, the dome light turns off before i put in the key. i spose cuz the motor is running, idk ... can i just put in the delay relay and wire it to the door switch indepently?
  3. Jan 14, 2016 at 8:53 PM
    #123
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I'm wondering the same thing. I'm pretty sure the clear ring (key lamp) and the black bezel are all that's required.
    There are several key rings and bezels though so it will take some checking to find the right one.
    http://www.trdshop.com/?p=catalog&mode=search&search_in=all&search_str=toyota key lamp
  4. Jan 15, 2016 at 6:29 AM
    #124
    amkaos
    from this page, it looks like 81870-35020 and 81870-35050 to choose from for key ring..
    Toyomonkey59 says 81870-35050 didnt work for 03 truck.
    im looking for part # confirmation for '01
    i found a fitment guide. #
    81870-35020 fits my 01
    55408-35010 is matching bezel
    dealer confirmed the keylight part number
  5. Jan 15, 2016 at 11:09 AM
    #125
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Cool. Thanks. Hopefully it is the same for 2003 (81870-35020 and 55408-35010).
    It looks like the "bezel" is a small piece of dash panel that includes the black ring like this. I have the larger dash panel that includes the clock but it shouldn't matter since I can just pull the black ring.
  6. Jan 15, 2016 at 12:22 PM
    #126
    amkaos
    I went to the dealer. He found part numbers for my year.. Key lamp, bezel the works...
    His bezel part number is 550408-04064.. This new bezel number is the larger that includes the clock cutout.. Seems like this gives me something concrete to go on..
    So key lamp is 81870-35020
    Bezel is 550408-04064
  7. Jan 15, 2016 at 1:48 PM
    #127
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Just curious, so "for your year" meaning the same year 4-runner? Or did he mean it was an actual Tacoma part? Maybe some of the Tacomas had it as an option.
  8. Jan 15, 2016 at 1:51 PM
    #128
    amkaos
    Yeah he found these parts listed for my Tacoma for my year, 01. I was surprised but I saw it myself.
  9. Jan 15, 2016 at 2:01 PM
    #129
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
  10. Jan 15, 2016 at 5:10 PM
    #130
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  11. Jan 15, 2016 at 5:26 PM
    #131
    amkaos
    Idk he checked 02 and the key lamp wasn't listed and didn't check any deeper.
  12. Jan 15, 2016 at 5:49 PM
    #132
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Yeah I checked 2004 Tacoma & 4Runner, 2000 4Runner & 2002 4Runner and couldn't find the key lamp. I got a HVAC Unit out of an 02 4Runner that fit perfectly in my 04 Tacoma. But that is a different story with this lighted key ring mod for my 04 Tacoma. I'd love to know the part# that would fit in my truck. I know some 4Runners are compatible with Tacomas depending on the part
  13. Jan 15, 2016 at 7:01 PM
    #133
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Well I'm gonna order the part numbers @amkaos mentioned from Camelback.com. I might not install for a couple of months tho if you want to wait for me to test it out. I'm pretty sure it will fit it just wasn't a factory option so it is not listed.
    Key lamp is 81870-35020
    Sicyota04[QUOTED] likes this.
  14. Jan 15, 2016 at 8:00 PM
    #134
    amkaos
    I think I misread my own writing.. I think the bezel is 550408-04060
  15. Jan 15, 2016 at 10:04 PM
    #135
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Alright
  16. Jan 15, 2016 at 10:07 PM
    #136
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I have a clock so I'm thinking I don't need the bezel. Just the key lamp. I couldn't find it on toyotapartsdeal.com
  17. Jan 15, 2016 at 10:23 PM
    #137
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    You don't need the bezel but you need the black ring that comes with it. The original one is too small
  18. Jan 15, 2016 at 10:47 PM
    #138
    Chris D.
    Chris D. Well-Known Member
    Eagan, Minnesota
    2002 Tacoma RZN150 turbo
    2RZ-FE Turbo Intercooled, standalone........... Exactly 150% more power to the wheels than stock at the wheels. Supra transmission, 4 linked rear, QA1 coilovers all around, S-Runner rear sway bar, Corbeau bucket seats, forged 5 spoke 17x9 wheels, Wilwood 12.19" 4 piston brakes, Ford 9" rear end (early bronco) 31 spline, full floater, big bearing, 3.50 gears, trac-lock. fully functioning air conditioning and cruise control....
    I just put a little hair around it, I always find it in the dark.. ;)
    Sicyota04 likes this.
  19. Jan 16, 2016 at 1:47 PM
    #139
    amkaos
  20. Jan 16, 2016 at 2:50 PM
    #140
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Thanks. I looked it up and is this for just the key ring light? Or the small black plastic ring also? I see that key ring light was an option for my 04 Tacoma although mine doesn't have it obviously. My truck must've been specially ordered since it has leather but no sunroof. It is color matched from the factory. Bumpers, grill surround and fender flares. Thanks for the part #'s
