Ignition light ring
Discussion in '1st Gen. Tacomas (1995-2004)' started by ZrowGz, Mar 18, 2018.
  1. Mar 18, 2018 at 5:28 PM
    ZrowGz
    ZrowGz [OP] I'm a n00b.
    SLC, UT
    97 4x4 LT/Cantilever
    I’m going to be attempting the ignition light ring mod sometime soon and am wanting it to fade to off after a moment once the doors close, so I have some time to find the ignition.
    If I wired up a small capacitor into the circuit, would it do that as the voltage dropped off? Anyone have any thoughts on what size capacitor to use? What does their ignition ring draw in terms of power (mA, minimum voltage to ignite a led)? That way I could plan how long it’d be lit for.
  2. Mar 18, 2018 at 5:33 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    If you wired it to the dome light would it not take a minute before turning off? At least that’s sort of how the 3rd gen 4Runner works. And that’s how the 1st gen diy describes it I think.
    Matic likes this.
  3. Mar 18, 2018 at 6:17 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You would want to get some kind of off delay relay. that will de energize after a set time. Generally a pretty cheap part like 5$ and come in different delays i most common see 10 seconds
  4. Mar 18, 2018 at 6:21 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    In agreement with tapping into the dome light.
  5. Mar 18, 2018 at 6:52 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  6. Mar 18, 2018 at 8:11 PM
    ZrowGz
    SLC, UT
    So that’s for AC power it looks like? Right? As an option down below it I saw this! Looks like exactly what I was hoping for! Although the gentle fade to off would be fun as a capacitor discharged...
    https://www.amazon.com/dp/B01HNDOCKK/ref=cm_sw_r_cp_awdb_t1_FMYRAbAEGA974
    My dome light definitely just turns off as soon as the doors close. There’s been some wiring modifications to this vehicle. Still figuring them all out!
  7. Mar 18, 2018 at 8:18 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah i was just showing you what we use in hvac for doing what you want. There are tons of different styles of those relays. You just need a off delayed relay that will work for your application
    ZrowGz[OP] likes this.
  8. Mar 18, 2018 at 9:37 PM
    ZrowGz
    SLC, UT
    Thanks for the input! Time to research this!
  9. Nov 19, 2019 at 9:44 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    @ZrowGz There must be a delay already built into the circuit. Tested my new light and it stayed on for a period after the door was closed.
    Installed the ignition ring light mod today and I got lucky. This for a 2000 ExtraCab SR5 Pre-Runner.
    Behind the dash I discovered the proper connector, just waiting for me to plug in my light. No need for special wiring.
    And it worked immediately!
    jdmstuff and SwampYota like this.
  10. Nov 20, 2019 at 6:41 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    My 1999 SR5 3RZ Pre-Runner Ext Cab had the plug as well.
    I have a feeling that all 95-00 (or some year range within that) has this plug. The light ring did come on certain models.
    I've attached the wiring diagram for the interior lights. You can see that it comes from the integration relay. That's where the delay circuit comes from.
    TRD= Totally Rad Dude likes this.
