Ignition problem tacoma 06
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roadkill1081, Jan 19, 2012.
  1. Jan 19, 2012 at 1:17 PM
    Roadkill1081
    Roadkill1081 [OP] Well-Known Member
    Maryland
    2020 DCSB TRD SPORT CEMENT
    This is my first post in these forums so please excuse me if I posted in the wrong place. I've been having a problem with my 2006 V6 tacoma for the past 2 weeks. When trying to start the engine, sometimes I hear a clicking sound(Like when the battery is dead) and it does not turn over, sometimes it turns over slower than usual and sometimes it just starts normally. I checked the battery and it's properly charged. I'm thinking it's probably a bad starter, does anyone have any other ideas or tests I should probably do before I go out and get a new starter? Any thoughts would be deeply appreciated :)
  2. Jan 20, 2012 at 3:44 AM
    Roadkill1081
    Maryland
  3. Jan 20, 2012 at 4:05 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Sounds like a bad battery. Try to jump start it and see what happens.
  4. Jan 20, 2012 at 6:15 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    With no load, even a bad battery can appear to be fully charged. Put a voltmeter across the battery terminals and have someone else turn the engine over. If the battery is bad, the voltage will drop significantly. A proper battery load tester is the best way to determine.
  5. Jan 20, 2012 at 6:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    Check your connections. It sounds like you may have a bad or loose ground also.
  6. Jan 21, 2012 at 4:43 PM
    Roadkill1081
    Maryland
    This morning it would not start. I just heard a clicking sound when I turned the key. I hit the starter a few times to check if it would turn. And finally it did. I got a new one and replaced it thos afternoon. No more problems so far.
  7. Jan 21, 2012 at 4:53 PM
    FOUR X FOUR DUDE.
    FOUR X FOUR DUDE. Well-Known Member
    Barry
    Mountain Center, Ca.
    Tacoma 4x4
    TRD wheels, BFG tires, factory installed option.
    An '06 with the original battery ? I'd say battery.
  8. Jan 21, 2012 at 4:54 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Very typical.... Almost surely the battery...or possibly dirty battery terminals... or both.
  9. Jan 21, 2012 at 5:40 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My '06 acted up in '08....dirty terminals from the start.... Cleaned them real good, covered them with grease....no more problems...
    You'll note that those terminal connactions DO NOT have much surface area touching the battery.....that's the issue here, I think.
    Good luck
  10. Jan 22, 2012 at 9:50 AM
    Roadkill1081
    Maryland
    I had already cleaned the battery terminals, the battery is only six months old, practically new. The starter was dead and ended up replacing it.
