Ignition switch? key is acting up in ignition
Discussion in 'Technical Chat' started by irwin billiot, Jun 23, 2012.
  1. Jun 23, 2012 at 10:32 AM
    irwin billiot
    irwin billiot [OP] Member
    irwin
    gretna
    extended cab pre-runner
    I have a toyota tacoma pre-runner.
    when i put the key into the ignition and turn it the truck does not turn over.
    For a few months the key has started to act up when i start. sometimes the key can be removed from the ignition without the truck stopping, if i pull it out without turning it counter clockwise.
    last night when i tried to start up the truck the key would not turn all the way clockwise, as such the truck would not turn over. the lights will come on so i doubt it is the battery. also usually when it is the battery the truck will turn over but only make clicking sounds. i am thinking i can just replace the switch that my key goes into.
    any thoughts?
  2. Jun 23, 2012 at 12:33 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Sounds like the switch is messed up.
  3. Jun 23, 2012 at 12:36 PM
    irwin billiot
    irwin
    gretna
    can i just use a screw driver and jamb it in there to start it up? just till i can afford fixing it at dealership.. i might try..
  4. Jun 23, 2012 at 12:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It sounds like a mechanical problem, not so much a key problem.
    If a screwdriver would work, so would the key.
