Igor: Double Cab 4x4. Frankenstein's Helper
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, Sep 8, 2015.
  1. Sep 5, 2016 at 7:55 PM
    #61
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Up to you. I don't really sleep in so whatever works for you.
  2. Sep 5, 2016 at 7:57 PM
    #62
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Haha okay. I'll make the trip this Saturday!
    @SconnieHailer gonna be around to join? Or still in Wisconsin?
  3. Sep 5, 2016 at 8:15 PM
    #63
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Fawk! Great week to be told I'm maybe working Saturday lol. Poor planning on someone else's part is not in my favor this week. I'll be working on an I-25 interchange all week near Loveland. I'll hope to be home Sat but who knows. Be home Sunday for sure.
    Willbeck likes this.
  4. Sep 5, 2016 at 8:19 PM
    #64
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well. Ripping out ac may take a while and brake lines..haha
    Could still be there :p find you.
    SconnieHailer[QUOTED] likes this.
  5. Sep 13, 2016 at 12:26 PM
    #65
    Blackdawg
    Monte
    Wyoming/St. Louis
    Update time!
    Ive had these parts for about 3 months now and it seemed like it was time to get them in. I installed a Bussman Relay box and some ditch lights. Gonna try and do a write up as usual but may be missing photos. Oh well.
    This being the 2nd tacoma build and the thousandth time ive done wiring on a tacoma. I REALLY wanted to do it 100% right and be super clean. So I went all out on this.
    I did very little if not any fab work of my own. Bought stuff from places mostly. Was expensive compared to how i usually operate, but worth it I think. Here is my list of components I purchased.
    On too the photos. Sorry I skipped some as some things are obvious or ive covered it in my other build thread.
    The bussman unit looks great and is made just like in the writeup which was helpful to refer to on how it was wired.
    Thread is here: https://www.tacomaworld.com/threads/diy-build-and-install-a-bussmann-rtmr-fuse-relay-block.399454/
    [​IMG]BussmanDitchlights-4.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-5.jpg by Monte Nickles Photos, on Flickr
    Riley even labeled the outputs.
    This is for Fused Relay
    [​IMG]BussmanDitchlights-8.jpg by Monte Nickles Photos, on Flickr
    and just fused
    [​IMG]BussmanDitchlights-9.jpg by Monte Nickles Photos, on Flickr
    The round yellow terminals are all grounds while the multi pinned plug is for the switch harness.
    The Paranoid Fab stuff was great too. I ended up scuffing up the face of the switch panel and putting about 5 coats of black paint on it. I didn't paint the bussman bracket, they are aluminum so won't rust and didn't want to bother with it.
    Cool logo :alien:
    [​IMG]BussmanDitchlights-2.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-3.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-6.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-7.jpg by Monte Nickles Photos, on Flickr
    Spare circuit breaker we had lying around. The Bussman box i guess is only rated for 80 amps though. Oh well.
    [​IMG]BussmanDitchlights-10.jpg by Monte Nickles Photos, on Flickr
    This was the only "major" problem i found with the bussman box Riley made. He had not only crimped all the ends, but had soldered them. On this connector he used a bit too much and it flowed up to the tip which means the male pins couldn't slide in. I was able to break it loose though with a small screw driver. He took the problem well and learned something and I didn't mind.
    [​IMG]BussmanDitchlights-11.jpg by Monte Nickles Photos, on Flickr
    If you go through the whole writeup on how to make a Bussman, you see he bolts two ground buses to the outside of the Bussman box. Well the Paranoid bracket for us 1st gens doesn't have the room.
    But i noticed the buss bars mounting holes are pretty much identical. So i figured i could mount them on the same spots.
    But the Bus bars holes are bigger so i just decided to step up to a 1/4'' bolt. That meant pressing the brass fittings out of the bussman.
    [​IMG]BussmanDitchlights-12.jpg by Monte Nickles Photos, on Flickr
    Had to drill out the bussman a bit and the bracket
    [​IMG]BussmanDitchlights-13.jpg by Monte Nickles Photos, on Flickr
    These are the bus bars.
    [​IMG]BussmanDitchlights-14.jpg by Monte Nickles Photos, on Flickr
    Now im not a big fan this wiring setup because that means i have to ground everything right here AND i have to run power and ground wire to my accessories. But, whatever. It turns out good.
    Went and got some 1/4''x1'' bolts and nuts. Should have gotten 1/4''x3/4'' though. But everything lined up and fit.
    [​IMG]BussmanDitchlights-15.jpg by Monte Nickles Photos, on Flickr
    Then i ran the ground wires across to the opposite sides. Would have been much nicer if the wires could have gone to the same side but the wires where just a touch short for that to make the angles work.
    [​IMG]BussmanDitchlights-16.jpg by Monte Nickles Photos, on Flickr
    Drilled two holes for the relay and cut up and crimped up some 4ga wire for power and ground.
    Came out nice.
    [​IMG]BussmanDitchlights-32.jpg by Monte Nickles Photos, on Flickr
    You can barely see it but i have a small chunk of 4ga running from ground bus 1 to the bus 2
    [​IMG]BussmanDitchlights-33.jpg by Monte Nickles Photos, on Flickr
    And here are the parts for the output harnesses. I used some 2 pair wire and made a nice harness for my LED pods and put the connector on the other side.
    [​IMG]BussmanDitchlights-17.jpg by Monte Nickles Photos, on Flickr
    Now for the LED install and brackets. I won't go into major detail on these as i did with Frankenstein. But i do want to show how to do part of it as these fenders are much different. The 01-04 front fenders are a bitch to totally take off, i guess. So the easiest thing is to just pull the top part up.
    Take the three bolts on top of the fender out.
    [​IMG]BussmanDitchlights-20.jpg by Monte Nickles Photos, on Flickr
    And then this guy inside of the door
    [​IMG]BussmanDitchlights-21.jpg by Monte Nickles Photos, on Flickr
    Then grab the fender a pull up, it works well to wedge something under the lip about where the middle bolt is to hold up the fender. I used a screwdriver.
    [​IMG]BussmanDitchlights-22.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-23.jpg by Monte Nickles Photos, on Flickr
    Should be able to access the two hood bolts nowwith a ratchet and 3'' extension and shallow 12mm socket.
    [​IMG]BussmanDitchlights-24.jpg by Monte Nickles Photos, on Flickr
    Then its pretty simple. Undo the bolts, set the brackets on, start trimming the cowling till the bracket fits. Then use the CBI supplied bolts and bolt it up.
    Don't put the fender back yet, you'll want it open to get the wiring harness out.
    I ran the harness through these holes into the fender well and the pulled it up to the top. There is a hole on each side in the exact same spot.
    To help pull the harness up to the top i came up with kind of a cool trick. Otherwise its a major PITA with the fender skirt still in.
    Get some magnets, we have a stack of small super powerful earth magnets, some electrical tape, and a magnetic extension rod.
    [​IMG]BussmanDitchlights-25.jpg by Monte Nickles Photos, on Flickr
    Tape the magnets to the end of the wire harness
    [​IMG]BussmanDitchlights-26.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-27.jpg by Monte Nickles Photos, on Flickr
    Waalaa!
    [​IMG]BussmanDitchlights-28.jpg by Monte Nickles Photos, on Flickr
    However....they are magnets...and the fender is..steel...but with just a little bit of fanageling, a hell of a lot less then without the magnets, you'll get it attached. I put the extension magnet in from the door side.
    [​IMG]BussmanDitchlights-29.jpg by Monte Nickles Photos, on Flickr
    Plus then it holds the harness while i get the lights :D
    [​IMG]BussmanDitchlights-30.jpg by Monte Nickles Photos, on Flickr
    Then i bolted the lights on. They mount nicely with a cool and simple mounting setup. However the bolt is super super small compared to the hole the CBI brackets are drilled for. So i used two stainless fender washers and all was well.
    I like the lights.
    [​IMG]BussmanDitchlights.jpg by Monte Nickles Photos, on Flickr
    Here is a shot of the trimmed cowling.
    I have lots more photos on the install of these brackets in Frankensteins build thread if you are interested found here: https://www.tacomaworld.com/threads...rail-rig-and-bs.159436/page-535#post-10417256
    Just becareful, that link is a huge build update and tons of hi res photos. The CBI photos are about 3/4 of the way through the post.
    Connected up the harness and pulled back the slack into the fender but left the quick release within reach. Then bolted up the fender again.
    Cut a slit into the stock grommet on the driver side and pushed the molex end of the switch harness through. Pulled it all the way through till the three other wires came through.
    [​IMG]BussmanDitchlights-31.jpg by Monte Nickles Photos, on Flickr
    Then its time to remove the dash a bit.
    This is a good video to show how to do a 01-04 center section.
    https://youtu.be/9pAGomsyUHA?t=3m30s
    Its the same as my 1996 except for this lil bastard behind the ashtray.
    [​IMG]BussmanDitchlights-34.jpg by Monte Nickles Photos, on Flickr
    Then it just pops off.
    [​IMG]BussmanDitchlights-35.jpg by Monte Nickles Photos, on Flickr
    Also helps to remove the cover under the steering wheel. Just 4 10mm bolts and one screw. then you can pop the clock out too.
    Then its time to hook up wires. I started with the single wire coming out of the harness. This is the power wire for light that turns on when you flip the switch on and provides the power for the coil side of the relays. I used a simple fuse tap for this.
    [​IMG]BussmanDitchlights-45.jpg by Monte Nickles Photos, on Flickr
    I tapped into ECU-B fuse because it has constant power. That way I can turn the lights on without have the ignition on.
    [​IMG]BussmanDitchlights-46.jpg by Monte Nickles Photos, on Flickr
    I can the main switch harness and the two pair wires up under the steering column with the stock harness.
    [​IMG]BussmanDitchlights-37.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-38.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-39.jpg by Monte Nickles Photos, on Flickr
    The two pair wires stop right at the clock, which at first i though was perfect but ended up not being, ill explain that later. I kept running the main switch harness to the center. Its like the little cut was made for it.
    [​IMG]BussmanDitchlights-40.jpg by Monte Nickles Photos, on Flickr
    You could say i had some..slack
    [​IMG]BussmanDitchlights-41.jpg by Monte Nickles Photos, on Flickr
    Not bad though. Probably could have run it into the headliner if i had an over head switch panel.
    Luckily the PO wasn't an asshat and the stereo install was very clean and there wasn't a rats next of wires. Which meant there was plenty of room for the spare wire.
    [​IMG]BussmanDitchlights-42.jpg by Monte Nickles Photos, on Flickr
    I just looped it up and zip tied it up.
    [​IMG]BussmanDitchlights-44.jpg by Monte Nickles Photos, on Flickr
    Attached the switchback end of the harness and was done with that.
    [​IMG]BussmanDitchlights-43.jpg by Monte Nickles Photos, on Flickr
    Next was wiring up the two pair wire i had left. This is a ground and power wire that is also for the switches. Its for the independent light though that lights up the lettering of the switch. I wanted for it to be dimmable with the stock interior lights. I thought the clock would be perfect but thats where i fucked up. But im going to show this anyways as its when i took photos of splicing the wires.
    But DON'T DO THIS. I'll show you the right place to splice in a bit.
    I thought this would work because of the back of the clock
    I saw ILL which means Illumination and figured that had to be there....shoulda tested with a volt meter first.
    Anyways i was too stoked on how the wires where the perfect length and went for it.
    [​IMG]BussmanDitchlights-36.jpg by Monte Nickles Photos, on Flickr
    Stripped the end of the wire and also a section out of the stock wire.
    [​IMG]BussmanDitchlights-47.jpg by Monte Nickles Photos, on Flickr
    Used a small screwdriver to split the stock wire to make an eyelet.
    [​IMG]BussmanDitchlights-48.jpg by Monte Nickles Photos, on Flickr
    Then put the other wire end into the eyelet and twist it to wrap around.
    [​IMG]BussmanDitchlights-49.jpg by Monte Nickles Photos, on Flickr
    [​IMG]BussmanDitchlights-50.jpg by Monte Nickles Photos, on Flickr
    Do to the other wire
    [​IMG]BussmanDitchlights-51.jpg by Monte Nickles Photos, on Flickr
    i added a bit of solder
    [​IMG]BussmanDitchlights-52.jpg by Monte Nickles Photos, on Flickr
    Used some electrical tape
    [​IMG]BussmanDitchlights-53.jpg by Monte Nickles Photos, on Flickr
    Then realized i fucked up.
    The clock doesn't dim :frusty:
    But the emergency flasher button does. And is right above. But the wires are still too short. So i had to extend them just a bit.
    Tested with a volt meter this time
    [​IMG]BussmanDitchlights-54.jpg by Monte Nickles Photos, on Flickr
    Did the same thing just with spare wire.
    [​IMG]BussmanDitchlights-55.jpg by Monte Nickles Photos, on Flickr
    Then buttoned it up for a super clean look.
    [​IMG]BussmanDitchlights-59.jpg by Monte Nickles Photos, on Flickr
    The just had to connect all the quick plugs and the 4ga wire and install the bussman.
    Cleanest install ive ever done for lights and wiring.
    But who cares. Output shots!
    So this is what i did. I didn't have my tripod with me so they aren't exactly the same. But i basically adjusted my camera settings so that the picture with my low beams on reflected close to what i saw with my eyes. then i just used the same settings for each photo.
    I did NOT edit these photos, they are 100% raw and i did not change the camera settings for any of the photos.
    Low beams.
    [​IMG]BussmanDitchlights-56.jpg by Monte Nickles Photos, on Flickr
    High Beams
    [​IMG]BussmanDitchlights-57.jpg by Monte Nickles Photos, on Flickr
    High beams and 40w pods.
    [​IMG]BussmanDitchlights-58.jpg by Monte Nickles Photos, on Flickr
    Pretty happy with them and even happier with the install.
    Hope that was helpful to some.
    Next mod, brake system overhaul!
    #65
  6. Sep 13, 2016 at 12:58 PM
    #66
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    What size lugs did you use for the circuit breaker?
  7. Sep 13, 2016 at 1:03 PM
    #67
    Blackdawg
    Monte
    Wyoming/St. Louis
    1/4"x 3/4 I believe. 1" long would haven been bette
  8. Sep 13, 2016 at 1:09 PM
    #68
    anthony250f
    Anthony
    San Diego, CA
    I got that same breaker for my battery but all the have is 3/8" hole lugs. Damn
  9. Sep 13, 2016 at 1:11 PM
    #69
    Blackdawg
    Monte
    Wyoming/St. Louis
    Idk. Maybe they were 3/8s. I can't remember. Just take it to the store and get some stainless bolts that fit haha
  10. Sep 13, 2016 at 1:13 PM
    #70
    anthony250f
    Anthony
    San Diego, CA
    Wait what. I was talking about the lugs to attach the cable to the studs on the breaker hahaha
  11. Sep 13, 2016 at 1:15 PM
    #71
    Blackdawg
    Monte
    Wyoming/St. Louis
    ohhhhh ha
    yea okay. I had to use 3/8s too. The lock washer holds it down fine.
  12. Sep 13, 2016 at 1:15 PM
    #72
    anthony250f
    Anthony
    San Diego, CA
    Awesome thanks!
    Keep modding it then I'll trade you :spy:
  13. Sep 13, 2016 at 1:16 PM
    #73
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    I'll think about it haha
  14. Sep 13, 2016 at 1:17 PM
    #74
    anthony250f
    Anthony
    San Diego, CA
    Just watch in a year you are gonna have two long travel expo rigs
  15. Sep 13, 2016 at 1:18 PM
    #75
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh god haha
    probably...
    :anonymous:
    I like the front LT too much.
    If Front Range Offroad release's its custom +2 kit that would be hard to pass up i think.
  16. Sep 13, 2016 at 3:10 PM
    #76
    Blackdawg
    Monte
    Wyoming/St. Louis
    So I got some wheelers super bumps to install. The front is going to take some custom tweaking. I ordered some UHMW a 3.25"x 1'
    It's well known the super bumps work great but aren't designed for 1st gens. So to make mine work I thought I could cut the bottom down at an angle. But that can't work since Id be cutting off the part that the bolt holds down the bump. So to cope I'm goin to make angled spacers and then cut then tops down.
  17. Sep 14, 2016 at 11:28 AM
    #77
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Curious to see what you come up with and how it works out.
  18. Sep 14, 2016 at 3:17 PM
    #78
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have an idea. Hope it works. Figured you'd be interested after our last chat about them.
  19. Sep 14, 2016 at 3:21 PM
    #79
    SconnieHailer
    Marc
    Should work but make sure you have a way to keep the angle block from spinning.
  20. Sep 14, 2016 at 3:23 PM
    #80
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good point. Spider washer may work.
