Im about to something stupid!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grizzlytravis, Jan 14, 2010.
  1. Jan 14, 2010 at 7:46 PM
    grizzlytravis
    grizzlytravis [OP] Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    i have an 08 5lug and the damn shift boot will not stay put it always falls down no matter what i will mash it into the little clip things and a few shifts later... there it is all up in my tranny area. im soo fed up with this and im about to zip tie the some bitch but... i wanted some ideas first so enlighten me:confused:
  2. Jan 15, 2010 at 7:20 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If you posted a pic I'd have an easier time envisioning this. I have an auto so I'm not familiar with the "clip things" you are talking about.
  3. Jan 15, 2010 at 7:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is your truck still under warrantee? Take it back to the dealer and let them deal with it.
    Otherwise...nothing wrong with zip ties. Make sure you use BLACK.;)
  4. Jan 15, 2010 at 7:53 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...I'd take a run at the dealer for a fix. But my Scion has two zipties in the shift boot....It happens.
  5. Jan 15, 2010 at 8:08 AM
    alpineski26
    alpineski26 Active Member
    Boston
    05 SR5 TRD
    Warranty as said if your covered, if you dont like the ziptie route...On my old car, a black rubber washer, and some superglue on each side of the boot and shift knob. Strong enough to stay on while shifting, easily remedied with unscrewing the shift knob and a sharp razor blade.
  6. Jan 15, 2010 at 8:21 AM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    I did something similar when I got a shorter shift knob:
    I just used a nylon spacer under the shift boot.
  7. Jan 16, 2013 at 12:24 PM
    BIGGRED94
    BIGGRED94 New Member
    i have an 06 exactly like yours with the same problem. what i did was take the wire in the shift boot and bent it out so it forces itself into the clips and it holds great i havent had a problem with it since
  8. Jan 16, 2013 at 12:50 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    if you can pop off the botton side then flip it in side out, then put a zip tie tight that will help. (if that makes sense)
