im an idiot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anotherreject, Apr 7, 2012.
  1. Apr 7, 2012 at 4:51 PM
    anotherreject
    anotherreject [OP] Well-Known Member
    while changing my oil i lost the little black plastic nipple plug thats on the bottom of where the oil filter screws in. do i need the plug, can i drive with out it?
  2. Apr 7, 2012 at 4:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your not an idiot. An Idiot would have drained the tranny, then used the drained fluid to fill the coolant.
    You will be fine without the plug. If its of concern, a local hardware store should have an assortment of those little plugs that you can get for under 2 bucks. IIRC, they are vacuum line plugs.
  3. Apr 7, 2012 at 4:54 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    hahaha thats just Krazie!
  4. Apr 7, 2012 at 4:57 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    You want to know an idiot. We had someone while deployed pour diesel into the hydrolic tank for their trailer hydrolics (trailer gooseneck moves up and down, deck moves up and down, and 8 of the 10 axles all turn by the use of that one hydrolic tank). That was a mess to flush out for them. Glad it wasn't in my platoon.
  5. Apr 7, 2012 at 5:01 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    As long as you got the plug off go buy a few feet of 5/16 ID hose and permanently secure it to the drain nipple (where your plug was) with a hose clamp. Run the hose down through the hole in the skid plate when doing a oil change and tuck it on top of the skid plate when not in use. I use a plastic plug to cap off the end of the line...never had a drop on the driveway.
  6. Apr 7, 2012 at 5:03 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    i lost mine too. you should be fine.
  7. Apr 7, 2012 at 5:10 PM
    Larry
    Larry CARL
    CARL
    If you dropped it...I bet it's laying on the bottom of the fan shroud. And unless you have long and very flexible arms...you will have to remove the skid plate to access it.
    ask me how I know this. :D
  8. Apr 7, 2012 at 5:12 PM
    anotherreject
    ill try this, thx
    i felt more like an idiot because i was scared to drive it with out the nipple, i was thinking it would let oil slowly drip out
  9. Apr 7, 2012 at 5:20 PM
    Larry
    Larry CARL
    CARL
    if oil is dripping from the filter cup nipple...
    loss of nipple cap is not your immediate problem.
  10. Apr 7, 2012 at 5:42 PM
    anotherreject
    i heard it hit metal, i banged on the skid plate to see if it would bounce out and it didnt
  11. Apr 7, 2012 at 5:44 PM
    Asta
    Asta Hold My Beer and Watch This
    Daniel
    Kings Bay, Ga
    2014 DCSB Tacoma TRD OFF-ROAD
    With a title like that how could i not read this?
  12. Apr 7, 2012 at 5:50 PM
    Larry
    Larry CARL
    CARL
    because it may have bounced into the fan shroud...and is lying there still.
  13. Apr 7, 2012 at 5:54 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    All I saw was nipple. I looked.
  14. Apr 7, 2012 at 7:31 PM
    cnew
    cnew Well-Known Member
    Goodyear AZ
    11 DC 4x4 Sport
    If you take it to the dealership for an oil change they will loose it for you.
  15. Apr 7, 2012 at 7:51 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    ^^^^This
  16. Apr 7, 2012 at 8:58 PM
    Larry
    Larry CARL
    CARL
    error #1.
  17. Apr 7, 2012 at 9:37 PM
    1980
    1980 Well-Known Member
    The Dust Bowl
    Back in the 90s I didn't have time to change the oil before a long trip so I ran over to a dealership early in the morning and had them change it. I pulled into a gas station several hours down the road, went to fill my washer fluid, and found oil all over my engine compartment -- they had left the fill cap off.
    I asked the guy at that middle-of-nowhere 7/11 if they had a cap for a Toyota and he said that they didn't but to look along the road as people forgot to put them back on all the time and they usually bounced out within a half-mile or so. Sure enough, I walked the side of the road for a few minutes and finally found one, along with two gas caps that also fit my truck.
