Im new help lol! Starting issues
Discussion in '3rd Gen. Tacomas (2016+)' started by LumberJake, Jul 22, 2021 at 5:22 AM.
  1. Jul 22, 2021 at 5:22 AM
    LumberJake
    LumberJake [OP] New Member
    Thursday
    Jacob
    Gray 2016 tacoma TRD sport
    So, just over 72 hours ago i purchased my dream taco (2016 trd sport) it runs great and i have almost no complaints.
    the one complaint i do have is that there are Definetly starting issues coming to light.
    to begin. It is never consistant. Up until yesterday it would start relatively easily every time. Since yesterday i have started it multiple times one of which took 10 seconds on the second attempt for the engine to catch.
    It will roll over but take varying lengths of time to catch. I have power and upon inspection of the battery everything seems to have proper connections (nothing loose or damaged). Any insight as to what i may need to try next?
  2. Jul 22, 2021 at 5:29 AM
    Taco2022
    Taco2022 Well-Known Member
    2017 TRD Sport DCSB 4x4
    Bilstein 6112, SCS SR8, Grabber ATX 275/70/17
    Welcome to TW! How many miles on the truck? Have the spark plugs been inspected/replaced? I changed my plugs last year on my 2017 at 60k and found that #3 was not fully torqued so there was a fair amount of carbon build up around the ignition coil. I wasn't having starting issues, but left unchecked, this could've started to cause problems later on.
    LumberJake [OP] likes this.
  3. Jul 22, 2021 at 5:43 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Also the battery could be on it's way out.
    Welcome to TW bro!
    Mark77 and LumberJake [OP] like this.
  4. Jul 22, 2021 at 5:58 AM
    LumberJake
    Thursday
    Jacob
    88,000 on the truck. Spark plugs have not been checked. I was thinking if buying a new battery today and seeing if it was that simple. Still unsolved.
  5. Jul 22, 2021 at 6:02 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Check the battery and a simple thing would be to make sure the battery connections are tight. They can come loose and mess ya up.
  6. Jul 22, 2021 at 6:06 AM
    boogie3478
    boogie3478 Tacomaholic & Hollywood
    Northern Virginia
    14 TRD Off-Road V6
    All the mods
    This. OP you can also have any car parts store check to see if you battery is ok before going out and buying a new one.
  7. Jul 22, 2021 at 6:08 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4
    Cooper Discoverer AT3 4S (kind of a mod)
    Does it seem like it's cranking slowly or just cranking longer before it starts?
  8. Jul 22, 2021 at 6:08 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    go to the dealer for free fuel pump.
    stu8319 likes this.
  9. Jul 22, 2021 at 6:08 AM
    RedWings44
    Michigan
    OP stated everything was tight and undamaged
  10. Jul 22, 2021 at 6:10 AM
    Lphonzy09
    Lphonzy09 Active Member
    Wednesday
    this is a key question. Sounds like your battery may be on its way out! A simple fix. Let us know what happens after you replace your battery! Given it’s age, average 5 years (depending where you live/environment) is how long a battery lasts from my tech experience.
    RedWings44 likes this.
  11. Jul 22, 2021 at 6:28 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Stick as stick can be.
    2016's do not get a fuel pump under the recall. If he was having a fuel pressure issue it would set the CEL.
