I'm out of blank spots to put switches, what now?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma SS, Dec 1, 2015.
  1. Dec 15, 2015 at 3:54 PM
    #141
    grichg
    grichg Well-Known Member
    rich
    Laguna Beach
    11 Tacoma 4x4
    Camburg 3.0 Coilovers Camburg A-arms All Pro rear bumper CBI Front Bumper LED Light Bar and PODs and some other misc
  2. Dec 18, 2015 at 6:22 AM
    #142
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    anyone have a write up on the wiring side of the sunglass compartment. PS the 2nd gen changed their overhead somewhere around 2010. The guy who made the new panels had a totally different design than what mine looks like. I know im going to slot out the sunglass panel for the 3 ARB switches, front, compressor and rear locker, but I wanna know how to route the wires. And if I have to tear the ceiling out to do so. Was thinking; cut the case, run wire through the pillar and poke a new hole in my firewall? Also, off-topic but anyone have a good place for that compressor!!?
  3. Dec 18, 2015 at 6:28 AM
    #143
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    running it through the A pillar is what I have read but haven't found a write up. Also there is actually an OBA thread
    https://www.tacomaworld.com/threads/oba-on-board-air-mega-thread-bs.299523/
    this is @THE CALICO 's https://www.tacomaworld.com/threads/calicos-2014-build-thread.333640/
    ACB02E57-DA00-4708-AFD3-ED3897A99893_zps_ba647de7e3f9cd2b9c243e79945b82967e4ea213.jpg
    59AD6BAA-6558-4A65-B63F-BB97879EDCEF_zps_eb871a0b617a1bfdcf8ffa3110f9dd9922a4e07c.jpg
    DDFC83FF-8EAA-419D-B5A9-890C2106ABF3_zps_5a1e85eb026451d51770ed3716de17d35385180d.jpg
    Tacoma SS[OP] and Blackout14 like this.
  4. Dec 18, 2015 at 6:35 AM
    #144
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    I got the mid level compressor, didn't see that nice yellow hose in a box yet, still at the shop where I bought it trying to find a worthy installer. But im having trouble locating where all of these pictures are on the truck.
  5. Dec 18, 2015 at 6:55 AM
    #145
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    you can save a lot of work by getting an S-Pod with adapter for the ARB. You'll eliminate a bundle of wires and make install so much easier. You'll be running one cable into the headliner instead of 6 individual wires, or go with a fancier spod and run no wires. You can also add you lights and stuff, allowing you to get rid of those breakers and wiring mess
  6. Dec 18, 2015 at 6:56 AM
    #146
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    1st picture - along the bedside
    2nd picture - in cubby storage in bed
    3rd picture - under bed above rear leaf spring hanger
  7. Dec 18, 2015 at 6:59 AM
    #147
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    ok, makes sense. I live in Canada though where we use heavy amounts of road salt. Anyone mount this in the interior? my truck is caked right now so I would cringe if my compressor got salted
  8. Dec 18, 2015 at 7:00 AM
    #148
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    yes people keep it in their cab, did you look at the OBA thread?
  9. Dec 18, 2015 at 7:07 AM
    #149
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    Trying to work my way through it *sigh*
  10. Dec 18, 2015 at 7:17 AM
    #150
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    BohlaaH[QUOTED] likes this.
  11. Dec 18, 2015 at 9:27 AM
    #151
    Tacoma SS
    Tacoma SS [OP] Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Rattletrap66[QUOTED] likes this.
  12. Dec 18, 2015 at 9:40 AM
    #152
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Wow... Some pretty sweet setups here. Makes my low tech solution seem, well, low tech
    6885DDB4-6208-4F75-AE76-A02955FCE7F3_zps_f507290aa303746b2c54bd49238578aae94fe900.jpg
    3A9204A0-F163-4384-B825-7A5A84B6EE38_zps_22776b9c02191c9c458cd48c0cd48a55342c9d34.jpg
  13. Dec 18, 2015 at 9:45 AM
    #153
    xjoey dubsx
    xjoey dubsx Curb Crawler
    Joe
    Cleveland, Ohio
    2015 Taco TRD Sport 6" Coil Overed
    6" PC Coil Over Lift, 35s, 18s, Extang Bed Lights, Garage Door Opener Hack, Bullydog GT Tuner, BHLM, 8300 Tinted everything else, Raptor Lights, Bakflip G2
    How is this tank mounted??
  14. Dec 18, 2015 at 9:47 AM
    #154
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  15. Dec 18, 2015 at 10:59 AM
    #155
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    I used the switch pros panel in the Sunglass holder and ran the loom up the A-Pillar into the holder. Didn't drop the whole ceiling just enough to tuck the cables in. Didn't hook up the switch pros to the compressor either, that damn things pulling too many amps I believe anyway.
    What's the mid level compressor? Is that the normal one not the twin? The hose I got was a Viair one.
    Bingo
    1st is in the driver side bed space above the long cubby
    3rd is under bed right below the same cubby
    The tire deff clears it. Tank is behind the rear wheel well.
    It's mounted with bolts through the bed. I believe I have pics on my build page.
    Blackout14 likes this.
  16. Dec 18, 2015 at 11:17 AM
    #156
    Tacoma SS
    Denver
    So you can put the tank there even with the spare tire underneath?
  17. Dec 18, 2015 at 11:34 AM
    #157
    THE CALICO
    Colton
    Nashville
    Yeah I have the spare under there and the tank. It's not in the spare tire spot just to the left.
  18. Dec 18, 2015 at 11:36 AM
    #158
    Tacoma SS
    Denver
    Your set up is so cool that I plan on doing the exact same thing, hope you don't mind haha
    I might also run an additional line off of the tank so I can power a train horn :devil:
  19. Dec 18, 2015 at 11:51 AM
    #159
    THE CALICO
    Colton
    Nashville
    It is a cool set up! I can't take full credit though I saw where CBI off road put their gauge and hose there in the cubby and then just kinda ran with it.
  20. Dec 24, 2015 at 7:29 PM
    #160
    Elmexicano21192
    Elmexicano21192 Well-Known Member
    DFW TEXAS
    15 Tacoma TRD Off Road
    Does anyone have an external panel that one could maybe just Velcro onto a desired area?
