I'm questioning tire shop answer...
Discussion in 'Wheels & Tires' started by flyfishinMT, Apr 14, 2011.
  1. Apr 14, 2011 at 8:17 PM
    flyfishinMT
    flyfishinMT [OP] Active Member
    AK
    2011, AC, 4wd, auto, 4cyl
    K&N filter, Leer 180, WeatherTechs, PopnLock, OEM knock off fogs, Duratracs, 16" FJ Wheels, Avid Lightbar, KC Daylighters
    so I asked a shop for a quote on some Eagle Alloy 140's and some 265/75/16 Duratracs. Tire guy says Eagle Alloys wont fit a toyota tacoma due to some problem where the center cap wont fit the hub or some such. I know there are plenty of folks on here with Eagle alloys, but I havent seen anyone with 140's. Have any of you guys run across this??
    I wish there were more options for a CLEAN looking black wheel with machined lip...
  2. Apr 14, 2011 at 8:22 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    steel rims.
  3. Apr 15, 2011 at 5:42 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Plenty of people on here run eagles, like you said.
    The only issue I could see is that some models of 16" rims won't clear the tacoma calipers.
  4. Apr 15, 2011 at 10:35 AM
    AtomicAge
    AtomicAge Active Member
    AA
    Baltimore, MD
    2008 BLACK 6spd 4x4 AC
    Cooper Discoverer ST's 265/75/16, Eagle 186 16x8's, 3" Toytec Ultimate Lift Kit, + more... Still sitting in the box: LR UCAs
    I run 16" Eagles 186s.. no problems.
  5. Apr 15, 2011 at 10:46 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Apr 15, 2011 at 1:43 PM
    flyfishinMT
    AK
    Thanks - this helps. I know 17's will work. The tire price goes up 30 each going from 265/75/16 to 265/70-17 Damn... Your truck sparked my interest in the 140's.
    Does anyone know if a 140 series 16" will fit properly?? I am waiting on a response from AE...which may or may not ever show up.
  7. Apr 17, 2011 at 9:15 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    what generation truck you running?
    your info under your screen name doesn't say, and that is half the battle...
    if your truck is a 2nd gen, and it came with 16s, then the 140s in 16x8 should fit as the backspace is .5" out from stock... the wheels are not hub centric so the center bore should fit...
    a lot of times, when you run into shops who will tell you a certain size wheel will not clear a tacoma, they are basing their information on generic info they have heard elsewhere...
    if for example, someone brought in a 2nd gen that has the bigger calipers, thus coming with 17s, that shop will blanket tell everyone with a tacoma that 16s wont work...
    i have seen shops tell folks that 16s won't fit on a first gen tacoma... then when i show them my truck parked outside, they tell the customer that i probably have wheel spacers or custom calipers...
    or that 15s won't clear a first gen...
    all based on a certain tacoma that has come into the shop in the past...
    that being said, you should not have any issues if your calipers can clear a 16" wheel...
    if your truck is a second gen and came with factory 17s, then no way to guarantee fitment, in which case, your best bet is to try and test fit a 16" wheel on your truck...
