im so lost some help would be great
Discussion in 'Suspension' started by buxton, Oct 29, 2009.
  1. Oct 29, 2009 at 9:10 PM
    buxton
    buxton [OP] Member
    jacob
    south mississippi
    Black Tacoma SR5 4x4
    31x10.50 bfg mud terrains
    ok guys im a idiot at this stuff so if someone will please take the time to help me i would love it....
    i have no idea what type of lift i want all i know is i want bfg km2 33's and everyone says that cant be done with only 3 inches but my buddy has a single cab tacoma with skyjacker 3 inch lift dont know what kind all i know is skyjacker suspension lift with 33 inch bfg m/t and dick cepek rims that are 16 or 17 x 10
    now i don know what add a leaf is or blocks or coilover or struts or rear lift springs are i jus want 3 inches of lift with out spending tons of money and capable of being put on at the house (not by me my friend is a mechanic) i liked the toytec ultimate lift
    my friend was looking under my truck and he said something bout a leveling kit that it has a rubber bushing on the coil over and he thinks a add a leaf because there is one leaf spring thicker than the rest and it curves down so if anyone would please break all this down for me i would be so thank ful cause this shit confuses the hell out of me
  2. Oct 29, 2009 at 9:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The ultimate lift is a good choice. The spring that is turned down is your over load leaf. You will still need to trim a little if getting the 33's.
  3. Oct 29, 2009 at 9:14 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
  4. Oct 29, 2009 at 9:16 PM
    buxton
    buxton [OP] Member
    jacob
    south mississippi
    but what the is the 4 choices on the rear lift for the ultimate lift can someone explain to a dummy what all those do and how high my truck will actually be lifted in the front and back with the ultimate lift
    the choices are
    2 inch add a leaf
  5. Oct 29, 2009 at 9:17 PM
    buxton
    buxton [OP] Member
    jacob
    south mississippi
    choices are
    2 inch addaleaf
    2 inch shackles
    1.5 inch lift blocks
    ome 2 inch lift springs
  6. Oct 29, 2009 at 9:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A 2" AAL adds to the rear springs 1 spring arched to give 2" lift...
  7. Oct 29, 2009 at 9:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The shackles give lift by lowering the back of the spring 4", to give 2" lift. the blocks are exactly that. A 1.5" block under the leaf springs, and over the axel.
  8. Oct 29, 2009 at 9:20 PM
    buxton
    buxton [OP] Member
    jacob
    south mississippi
    which ones are the best to do..... Blocks?
    what are the ome 2 inch lift springs
    and why the hell is a 3 inch lift if the back only gets 2 inches
  9. Oct 29, 2009 at 9:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Blocks are bad. They break. Get an AAL. The OME lift, iirc, is a multi leaf AAL. Most 3" lifts lif the rear less, as the back is at a slight rake forward, and the kits are designed to maake the truck close to level
  10. Oct 29, 2009 at 9:25 PM
    buxton
    buxton [OP] Member
    jacob
    south mississippi
    and is there any thing special i need to know about the front?????
    what exactly would i have to trim to get 305/70 r 16x8 bjg km2
  11. Oct 29, 2009 at 9:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On what wheels?
  12. Oct 29, 2009 at 9:29 PM
    buxton
    buxton [OP] Member
    jacob
    south mississippi
    dick cepek tourque, mickey thompson sidebiter or xd hoss series im really like the xd's but i here they look bad in 16's that they need to be at least 20's if thats so then will prob get the torqe's
  13. Oct 29, 2009 at 9:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your gonna rub on a lot of stuff...No telling what until they are installed. Personally, a 285/75/16 is a better size, and even at that size, your gonna have a little rub.
  14. Oct 29, 2009 at 9:34 PM
    buxton
    buxton [OP] Member
    jacob
    south mississippi
    well what could i do to get some wide tires that fill up my fender wells
  15. Oct 29, 2009 at 9:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 285's will fill it up fine.
  16. Oct 29, 2009 at 9:36 PM
    buxton
    buxton [OP] Member
    jacob
    south mississippi
    well whats your personal opinion on rims i jus want some thing black and not plain i am gonna black out my truck eventually
  17. Oct 29, 2009 at 9:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your best bet is to see what other people are running, and find out what lift, tire size, etc. There are a few threads with truck pics. Search for truck pics, and see what you come up with
