Improve ride quality
Discussion in '2nd Gen. Tacomas (2005-2015)' started by willimatic, Apr 15, 2011.
  1. Apr 15, 2011 at 10:08 AM
    willimatic
    willimatic [OP] Well-Known Member
    Will
    Rancho Murieta/Folsom, CA
    06 Tacoma AC 4x4 Sport
    I have done some research and came up with a few ideas. I prefer my truck to sit level although not mandatory. I just want an overall better ride.
    So, I was thinking of adding 5100's all around originally. Then I decided, maybe I should add new springs to the front as well? Have heard good things about OME. Then thought, maybe I should add an AAL to the rear?
    So, my question is, what would 5100's upfront set at 0 with OME springs due to the front of the truck height wise? I don't want to have to add UCA's or anything. My main concern is ride quality.
    And same with rear, will 5100's and a AAL require any brake line stuff etc.
  2. Apr 15, 2011 at 10:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A 2" AAL wont require new brake lines, and the OME 884's on your truck should yeild about 2.5" lift.
  3. Apr 15, 2011 at 10:12 AM
    MX81
    MX81 Well-Known Member
    Dallas
    2014 TRD Offroad PreRunner
    If your main concern is ride quality, dont mess with springs and an AAL. Go with 5100s set at .85. It will be close to level if you still have the factory 3leaf rear. Ride quality was better than factory on mine with this setup.
  4. Apr 15, 2011 at 10:14 AM
    willimatic
    Will
    2.5, wow. Mmm, wonder then if it would look dumb with stock rims and tire size?
    Will that amount of life require anything with UCAs etc.?
  5. Apr 15, 2011 at 10:15 AM
    willimatic
    Will
    Yes, have the factory 3leaf rear. I've thought about this option many times! How did the rear end change feel wise to you with this set up. Mine rear end feels so harsh when going over bumps and what not.
  6. Apr 15, 2011 at 10:28 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    I'd personally go with 5100 all the way around with Eibach springs. Leave them set at 0, keep the 3 leafs and call it a day.
    *edit* Wait. I forgot how much lift Eibachs give with billys set at 0. Someone pls remind me.
  7. Apr 15, 2011 at 10:30 AM
    willimatic
    Will
    Yeah, could someone fill me in on the above about Eibachs and lift amount?
  8. Apr 15, 2011 at 10:33 AM
    LEX
    Houston, Texas
    100 Series LC
    I think its 1.6".
  9. Apr 15, 2011 at 10:34 AM
    willimatic
    Will
    Ok. I think with the stock 3leaf rear that will make me nose high? Do you have this set up?
  10. Apr 15, 2011 at 10:36 AM
    LEX
    Houston, Texas
    100 Series LC
    Actually, I think it would level you out.
    I have 5100s with Eibachs, but I have mine set at .85 with 2" aal.
  11. Apr 15, 2011 at 10:37 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Buy a car...
  12. Apr 15, 2011 at 10:38 AM
    willimatic
    Will
    How is your ride with that? Do you have aftermarked rims and tires? Any pics?
  13. Apr 15, 2011 at 10:47 AM
    LEX
    Houston, Texas
    100 Series LC
    The ride is awesome. I had a spacer lift on my last truck and this truck rides like a Cadillac compared to it.
  14. Apr 15, 2011 at 11:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The Eibach springs are supposed to be 1.6" of lift but people have reported closer to 2" in some cases. You'd be fine with stock UCA's but would probably want to do something out back to help out because you'll probably be a little nose high.
  15. Apr 15, 2011 at 11:28 AM
    willimatic
    Will
    Anyone know the difference between Eiback and OME as far as ride for just street driving?
  16. Apr 15, 2011 at 11:40 AM
    Pugga
    Massachusetts
    I've heard Eibachs are better suited for street driving although I have no personal experience with the OME coils. The Eibachs are supposedly designed to work with the 5100's also where as the OME's are supposed to be paired with their own shocks.
  17. Apr 15, 2011 at 11:40 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I beleive the Eibachs have a spring rate of #620 and OME springs have #590 spring rate.
    i've rode on both and couldnt tell a difference. i personally have OME springs with 5100's set at .85 and it rides a lot better then stock.
  18. Apr 15, 2011 at 11:47 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    x2
  19. Apr 15, 2011 at 11:52 AM
    willimatic
    Will
    Why the hell would I buy a car if I bought my Tacoma? Just because you want to improve your ride quality doesn't mean I'm not trying to have a truck, or don't want a truck ride.
    Why mod a lot of shit in our trucks when you can get it stock in other vehicles, that's like saying you want Nav or HIDs or leather so go buy a car that has it already.
    If you don't want to contribute to this thread like the other helpful people have so far, why bother posting stupid crap!
  20. Apr 15, 2011 at 11:55 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Do the 5100's all round , set the fronts at .85 , don't get an AAL or the TSB springs .
    That's the best you can do to keep a plush ride .
    Haters gonna hate , don't worry about it
