Improving the URD Fuel Pump Kit
Discussion in 'Performance and Tuning' started by mike92y, Dec 29, 2013.
  1. Aug 30, 2018 at 9:47 AM
    #61
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    JacksonTacoma[QUOTED] likes this.
  2. Sep 16, 2018 at 1:00 PM
    #62
    BassAckwards
  3. Sep 17, 2018 at 6:34 PM
    #63
    BassAckwards
    @BillDaCat8 thanks again for the fuel bowl buddy! Got it installed this past weekend with @Roostfactor and we used your idea to heat up the end of a screwdriver to make the slits for the clamp that holds the pump. He thought that was a great idea, and it ended up working like a charm to get the holes just small enough.
    nudavinci64 and BillDaCat8 like this.
  4. Nov 3, 2018 at 12:21 PM
    #64
    Blown383
    Blown383 Well-Known Member
    Looks like my sending unit is taking a dump and reading the wrong fuel levels. I might as well piece together my own fuel pump upgrade it if the URD kit doesn't provide the proper tubing. Do I need anything other than the fuel pump, corrugated fuel tube, and a few hose clamps? I know they have an exterior fuel filter too.
    -B
    BassAckwards likes this.
  5. Nov 3, 2018 at 2:57 PM
    #65
    BassAckwards
    Youll need a way to attach the new aftermarket fuel pump to the inside of the fuel bowl as well
    The URD kit uses a hose clamp type thing, except its like a steel electrical tie wrap that tightens down as you pull on it
    Kolunatic likes this.
  6. Nov 3, 2018 at 3:00 PM
    #66
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    A bandit clamp?
    BassAckwards[QUOTED] likes this.
  7. Nov 3, 2018 at 3:03 PM
    #67
    BassAckwards
    I believe that would work! Wish i had pic of the one that came in the urd kit
    Kolunatic[QUOTED] likes this.
  8. Nov 3, 2018 at 3:04 PM
    #68
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Man
    I used to have those
    Haven’t seen them in years, before the move. No telling when I’ll find them again
  9. Nov 3, 2018 at 3:06 PM
    #69
    BassAckwards
    They will turn up right after you need them, cant find em, and go buy some more :D
    Thats how it works for me at least lol
    Norton and Kolunatic[QUOTED] like this.
  10. Nov 3, 2018 at 3:06 PM
    #70
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Yea
    No chit
  11. Nov 3, 2018 at 3:08 PM
    #71
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    You could use the Apollo hose crimp clamps. Home Depot carries them,along with crimped pliers
  12. Nov 3, 2018 at 3:24 PM
    #72
    BassAckwards
    I personally would just get the URD kit. It's a really nice kit, and 100% complete. Way easier than trying to piece everything together and by the time you do, you wont really save much money. The time and research they put into the upgrade kit shows. Just get the racetronix tube to replace the one piece of gates rubber tubing that moves down and has the potential to get pinched. Other than that one piece, the URD kit is a very nice upgrade. Very well thought out
  13. Nov 3, 2018 at 4:47 PM
    #73
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Stainless zip ties? Amazon has them.
  14. Nov 3, 2018 at 4:56 PM
    #74
    BassAckwards
    Yes, i believe that's all it is that comes with the kit. Nothing too special, just not very wide, and very thin so that you dont have to cut a bigger hole in the fuel bowl than necessary to thread it through. Also it being thin makes it easier when putting the hole fuel sending unit/fuel bowl back as it's a pretty tight fit going back into the fuel tank
  15. Feb 14, 2019 at 4:29 PM
    #75
    sawjai526
    sawjai526 Well-Known Member
    vincent
    Bayarea, CA
    15 DCSB OR 6spd
    thanks, just order a tube, and going to order urd pump kit
  16. Mar 11, 2019 at 11:08 AM
    #76
    cbe513
    cbe513 Well-Known Member
    Cory
    Pottstown PA
    2006 TRD Sport Double Cab
    3in pro comp lift Halo 17" Rims 285x70x17 Nitto Terra Grapplers KN Air Access Literider AVS bug and window visors GTA Radio Adapter
    Do you have to strip the wires before you use the butt connectors?
  17. Mar 11, 2019 at 11:56 AM
    #77
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Absolutely. Butt splices do not cut through shielding.
    cbe513 and Biscuits like this.
  18. Mar 11, 2019 at 2:19 PM
    #78
    cbe513
    Cory
    Pottstown PA
    Thx. I had a brain fart and didn’t want to screw it up that far into the project. Anyway! Went flawless. She running better and smoother than ever. (I was getting a hesatation when accelerating moderately) all fixed!!
    Torspd likes this.
  19. Mar 11, 2019 at 4:24 PM
    #79
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The beauty of a clean filter. Ahhhhh. (And good pump)
  20. Mar 14, 2019 at 5:14 PM
    #80
    cbe513
    Cory
    Pottstown PA
    I did the upgrade Monday. Went fine! Runs great! However, today (Thursday) I went to start it and it cranked for twice as long and then started and it did that every time today..... any ideas as to why it would all of a sudden start taking twice as long to start? Runs fine once started.
