In Cab Fuse Box
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Frogsauce, Dec 30, 2016.
  1. Dec 30, 2016 at 4:13 PM
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I put a small fuse box under the dash, back up on the firewall for all my inside mods and extras. I don't like wiring things into the truck if I can avoid it, plus it's nice to have all my DIY installed stuff fused in one spot.
    This is the fuse box I used:
    https://www.amazon.com/gp/product/B00QMTAZ1W/ref=od_aui_detailpages00?ie=UTF8&psc=1
    And this is the relay:
    https://www.amazon.com/gp/product/B00C0SATHE/ref=od_aui_detailpages00?ie=UTF8&psc=1
    I wired it as ignition switched by tapping into the cig lighter. But you could leave it constantly powered if you preferred. I ran a separate power wire from the battery, through the grommet in the firewall and put an inline fuse on it.
    I used shallow screws to mount it to the firewall material (it's actually fairly sturdy) since I didn't want to drill holes in the metal. It's on there really well so I don't expect I will have an issue with it falling off.
    For external mods and extras, I'll add a separate fuse box in the engine bay:
    https://www.tacomaworld.com/threads/wiring-an-aux-fuse-block-relays-and-switches-in-a-2016.401253/
    Or maybe even this:
  2. Dec 30, 2016 at 7:18 PM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    This is the relay wiring I did. But keep in mind not all relays are the same, so you need to find the wiring diagram for your specific relay.
    This is where you can tap an ignition switched power wire. It's under the center console (easy to remove). I forgot which one is the positive wire though, so test that with a pen light or multi-meter.
    For the battery wire, I ran that through the grommet in the firewall pictured below:
    JoeCOVA likes this.
  3. Dec 30, 2016 at 9:41 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    What types of stuff do you have running to this?
  4. Dec 31, 2016 at 6:07 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Only the dash cam right now, soon a glove box light, and I'm looking into powering the remote start device off it instead of wiring it directly into +pos power. I'm sure in the future there will be other stuff. I'll just need to make sure everything combined is less than about 20-30 AMPs.
    JoeCOVA likes this.
  5. Dec 31, 2016 at 8:49 AM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Wise, and clean install.
    I installed a TacomaPros Bussman use box, it provides a battery lead inside the switching bundle. I was thinking about installing one of these for my light bars
  6. Dec 31, 2016 at 8:54 AM
    austinrauh
    austinrauh Well-Known Member
    Nevada
    05 AC OR
    Looks good, I'm putting one in today that I made for all the led's, i hate having all those floating wires...:thumbsup:
  7. Apr 14, 2017 at 10:23 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Looks good. Do you have any pics of the final install? I'm about to remove my rat's nest of wires and replace it with something nice and clean.
  8. Sep 14, 2017 at 6:20 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    I like that relay setup too.
  9. Jan 25, 2019 at 2:38 AM
    airrage
    airrage Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    What a horrible design to leave the Main power wire terminal unprotected like that.
    YodaLovesTacos4x2 likes this.
  10. Nov 25, 2019 at 6:21 PM
    AMC_Unlimited
    AMC_Unlimited For he is limitless (sometimes)
    AMC
    Ironman Tribute Edition
    Mall Crawl Control
    AE82403C-F64E-4CB6-A228-277FF03573CF.jpg I like your idea and might do something similar. I also noticed a hazard, but instead of outright saying it’s a bad design. I’m gonna offer a helpful recommendation from the research I’ve done and the stuff I learned.
    What you’re missing is a circuit breaker that matches your fuse box output.
    Here are detailed threads I’ve been reading through:
    https://www.tacomaworld.com/threads/diy-build-and-install-a-bussmann-rtmr-fuse-relay-block.399454/
    https://www.tacomaworld.com/threads/show-off-your-aux-fuse-panels.308677/
