in cab winch control
Discussion in 'Off-Roading & Trails' started by j83soldier, Jan 16, 2011.
  1. Jan 16, 2011 at 9:06 PM
    j83soldier
    j83soldier [OP] Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    I know I have seen it on here but have been searching for an hour and cant find it. I am looking for a detailed write up on how to wire a winch to in-cab control switches. I suck at wiring and was hoping to find a decent write up. My orginal idea was to just run the stock controller from warn through the firewall to an empty switch and call it good but there is no way in hell that fat wire will fit through the firewall. Thanks
  2. Jan 16, 2011 at 9:11 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I wired one up. What kind of winch do you have? I have a Warn M8000
    The way I ran it was the 12v to activate the solenoids to a switch first then to momentary on/off double pole double throw switch.
    The switch(s). The controller is between the cup holder and 4WD shift lever and the 12v switch is the black switch on the right under the ash tray.
  3. Jan 16, 2011 at 9:26 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    Search for barlowrs build
  4. Jan 16, 2011 at 9:46 PM
    j83soldier
    joshua
    Colorado
    05 tacoma
    yea I have a warn M8000 do you have a write up on it
  5. Jan 16, 2011 at 9:57 PM
    j83soldier
    joshua
    Colorado
    05 tacoma
    found it yea like I said fucking with electrical worries me and because of that I shy away from it, thus suck at it. I am hopping to find a write up that shows step by step. As in taking the selinoid apart, running the wires ect. Thanks though.
  6. Jan 16, 2011 at 10:07 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    The good thing is you don't have to take the solenoids apart. You can take the cover off of the controller box and have access to the electrical connections. Let me get on it tomorrow and I can get a writeup for you.
  7. Jan 17, 2011 at 6:02 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Check out 12voltguy.com. He has install kits to wire your winch inside.
    click here
  8. Jan 17, 2011 at 6:17 AM
    coppert
    coppert Mall Krawler
    Travis
    916
    I was looking into this as well, but ended up going with the Warn wireless controller. So you have the best of both worlds, can control from inside the vehicle or outside when the need arises. Couldn't be happier with the choice.
  9. Jan 17, 2011 at 8:41 AM
    j83soldier
    joshua
    Colorado
    05 tacoma
    awesome man thanks a million. thats why this site is awesome.
