in need of brake rotor advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by disputantatacoma, Feb 6, 2016.
  1. Feb 6, 2016 at 2:43 PM
    disputantatacoma
    disputantatacoma [OP] Member
    Doug
    Prince George Co. Virginia
    2004 black dc sr5 trd 4x4
    Bilstein 5100s
    I'm looking to replace my brake rotors and pads on my 2004 double cab TRD four by fourd does anyone know the stock rotor diameter size and any opinions on a good quality rotor
  2. Feb 6, 2016 at 4:57 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    looks like youre just going to have to take the wheel off and measure it. or try and measure it through the rim.
    if you want, just get napa brakes and rotors. most trusty aftermarket there is. had a set of their ADO pads, a racing style, went 3 years before i crashed my 2006 prerunner. no idea how much longer they would have lasted though
  3. Feb 6, 2016 at 5:02 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
  4. Feb 6, 2016 at 6:34 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Upgrade to the tundra brakes. Best mod for the buck imo. And yes they do clear the stock 16" TRD wheels.
    MR2 and Sicyota04 like this.
  5. Feb 6, 2016 at 9:17 PM
    CodeSeven
    Serge.
    Coachella Valley
    but it must be said :jerkoff:, even though i TOTALLY am for this upgrade, that you don't need this unless you plan to do some heavy towing. there, i said it. now ignore me and go do it :-D
    keakar likes this.
  6. Feb 6, 2016 at 9:22 PM
    68dave
    Dave
    I agree. I tow a small fiberglass camper or i'm towing my 4x4 quads so this upgrade was a must for me. I also did this upgrade to my lifted 4runner, tired of rotor warpage. But i install larger brakes on everything i own, just installed 2002 corvette brakes onto my chevelle!
    MR2 and CodeSeven[QUOTED] like this.
  7. Feb 6, 2016 at 9:50 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    so whats involved in doing this? I know you need the calipers, rotors, and pads, but
    what part numbers do I need to buy?
    because if im doing it, im buying the replacement calipers and not bothering with salvage ones unless they are stupid expensive to buy from local auto stores.
  8. Feb 6, 2016 at 10:03 PM
    68dave
    Dave
    I have the larger 231mm on my tacoma and 199mm on my 00 4runner. This is a pic of my 199mm kit i have sitting at work waiting for me to install on my wife's 02 4runner.
    keakar and angry john like this.
  9. Feb 6, 2016 at 10:37 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    Well not just for towing but larger wheels and lifts also need and benefit from this mod. I personally Have to have this mod to even stop my truck with 37's on it. I personally only use cross-drilled and slotted rotors in black zinc so they do not rust.
    I have also upgraded the brake line from the master cylinder down to the calipers on the entire frame of the truck to metal hard lines and then steel braided lines at the calipers, I need serious brakes!
    I like www.brakeperformance.com for my source for brake rotors and i use my different pad combinations on these rotors.
    68dave likes this.
  10. Feb 6, 2016 at 10:55 PM
    preybird1
    Russ
    Salt lake city Utah
    2002 taco s\c
    Parts are from a 2001 tundra. caliper # 13WL This number will stamped on the caliper and sometimes the "L" is partially machined off where the mounting hole is. The core charge on this caliper is $70-77 alone they are very expensive calipers. I would get steel braided brake lines also for a nice pedal feel.
  11. Feb 7, 2016 at 6:24 AM
    68dave
    Dave
    I agree, i bought my stainless steel braided hoses, both front & the one rear, from Wheelers Offroad. Their hoses also come with the banjo bolts.
  12. Feb 7, 2016 at 6:25 AM
    68dave
    Dave
    Are you calling me a jerk off?!!!
    Tucker771 likes this.
  13. Feb 7, 2016 at 9:07 AM
    keakar
    karl
    louisiana
    ok, so its not like going buy $40 repop calipers is an option then.
    guess salvage yard is the only "reasonable" option for those who don't have lots of $ to burn
    what are the right year classes to go get salvaged calipers from?
  14. Feb 7, 2016 at 11:34 AM
    CodeSeven
    Serge.
    Coachella Valley
    :confused:o_O:crazy::der:
  15. Feb 7, 2016 at 11:39 AM
    68dave
    Dave
    Just messin' with ya!:)
    CodeSeven likes this.
  16. Feb 7, 2016 at 12:10 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Will this work for 15" wheels?
  17. Feb 7, 2016 at 12:50 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I do not tow but can tell you that the tundra brake is one of the best I've done. You instantly get results and for 150$ why not do it.
    68dave likes this.
  18. Feb 7, 2016 at 1:02 PM
    keakar
    karl
    louisiana
    I saw a few posts saying it only works with 16" rims or a very few "special" after market 15" rims that the calipers still "almost" rub on with literally 1/16" clearance, so if you have 15's this isn't a mod for you to try unless you plan to swap rims to do it.
    Clay_916[QUOTED] likes this.
  19. Feb 7, 2016 at 1:05 PM
    n0ms
    Angel
    San Diego
    2000-2003 is the window I think. Go by the part number stamped on them.
    I found a crashed Tundra with 80k miles,grabbed the calipers, OE rotors, and autozone brake pads for 120$ , went to get the rotors resurfaced for 30$.
    keakar[QUOTED] likes this.
  20. Feb 7, 2016 at 1:07 PM
    keakar
    karl
    louisiana
    so im looking to get the:
    Front, 231mm length (casting 13WL), LH
    Front, 231mm length (casting 13WL), RH
    but as for rotors, isnt it better to just buy new rotors anyway?
    even though it doesn't matter here any way because turning rotors is no longer done anywhere due to insurance costs of legal liabilities
