In the middle of Diff Fluid Change HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rs5, Nov 24, 2012.
  1. Nov 24, 2012 at 12:07 PM
    rs5
    rs5 [OP] TACOLIFE
    Tampa, FL 33578
    05 DC PreRunner SR5 V6 TRD Off-Road
    K&N Air Intake
    I just bought this truck about 3 weeks ago with 122k miles I'm going by Chris4x4's tut here http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
    Problem is I was expect to drain out about 3 quarts but only drained half a gallon, in the tut mentioned above it calls to refill with 3 quarts what should I do am I missing something?
    UPDATE: Ended up puttin it on a downward incline to pour the 3rd quart in ill know that I fucked up because either it will start leaking or one of you will tell me so
    So far took it for a drive and all seems good also I changed the spark plugs and cleaned the throttle body tomorrow ill be installing my new bull bar, I know gaaaaayyy, shit I like how it looks on other tacos so I'm going for it
  2. Nov 24, 2012 at 12:09 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    when i did mine it was low to...3.1quarts is the correct amount i believe.
  3. Nov 24, 2012 at 12:10 PM
    rs5
    rs5 [OP] TACOLIFE
    Tampa, FL 33578
    K&N Air Intake
    Alright well I guess ill go ahead and start pouring in the new fluid
  4. Nov 24, 2012 at 12:11 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Just fill till it starts to run out of the fill hole.
  5. Nov 24, 2012 at 12:12 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Also if it is a LSD diff you need the additive.
  6. Nov 24, 2012 at 12:12 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    so you drained 2 quarts, and the manual says to refill with 3?
    You need to take into consideration that the fluid runs down the axle tube. IF you want, jack the truck up on each side, one side at a time, and see if you can get the extra quart out.
  7. Nov 24, 2012 at 12:13 PM
    jandrews
    '09 FourDubDee TRD OR
    Low factory fills are not uncommon, unfortunately.
  8. Nov 24, 2012 at 12:17 PM
    blakes09
    Blake
    Deep South
    4x4
    i dont know about an 05 model, but my 09 says to fill to 5mm lower than the fill hole.
  9. Nov 24, 2012 at 12:18 PM
    jandrews
    Potato Potahto.
    Truth be told though, my '09 doesn't like to be overfilled. If I do, the pinion seal leaks out the excess until it's down to about that 5mm level, then it stops seeping.
    That extra bit won't hurt anything though. Just could get messy.
  10. Nov 24, 2012 at 1:01 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Bad Seal, clogged breather. needs to be fixed
  11. Nov 24, 2012 at 5:21 PM
    jandrews
    Nah. Breather's fine, I checked it, and it only does it when overfull, then stops completely. I have a new seal and pinion nut, but I'm waiting for it to be worth the trouble to do anything about it. Right now it's not enough of a problem to care.
    The seal is brand new (the diff was rebuilt this past June), and while it's possible ECGS screwed up seating the seal, again, it's not enough to matter at the moment.
  12. Nov 24, 2012 at 5:42 PM
    rs5
    rs5 [OP] TACOLIFE
    Tampa, FL 33578
    K&N Air Intake
  13. Nov 24, 2012 at 6:42 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Can't get any simpler. Fill it until it starts spilling out.
