Incredibly stupid dealer comment on fluid changes.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zooks527, Apr 20, 2017.
  1. Apr 20, 2017 at 5:50 PM
    Zooks527
    Zooks527 [OP] Active Member
    Mansfield, MA
    2005 Tacoma TRD Sport Access Cab
    DDX3 BT radio, tailgate cam, heated seats
    OK, fair cop and all, this is somewhat off-topic, as it concerns a comment from a dealership service adviser on my car. Still, it's so incredibly stupid that I have to share it.
    My Tacoma has become my daily driver, and my car gets used mostly on weekends. I have a 2015 BMW M235i with xDrive (BMW's AWD system), just crossing 34,000 miles (I was doing 2000 miles per month until I got the Tacoma last fall, now down to 300 - 400 per month and almost only on the weekends). BMW gives you "free maintenance" for the warranty period of the car, and, for some reason, the recommended maintenance is a really short list (I know, you're shocked, shocked!)
    In any event, I do more maintenance than the book calls for. One thing I like to do is change the driveline fluids. Unlike the Tacoma, they're an event to change. The differentials don't have drain plugs, requiring you to go in through the fill hole with a suction tube. Accessing the transfer case fill plug apparently requires dropping the front drive shaft and part of the exhaust system, and requires a specialty reset of the internal clutches that's possible only using a dealer's programming system. Ground clearance is minimal (I need to use mini-ramps to get it onto my main ramps to do an oil change) and I don't have a lift, so that means these 3 fluids tend to get done at the dealership.
    The first dealership I spoke to had wildly high prices ($170 per axle for the differentials, $850 for the transfer case), so I started calling around. I had an interesting call at the third one I spoke to.
    I got a fair amount of pushback from the adviser about not having the work done. It included this direct, as best as I can be accurate, quote:
    "Well, sometimes you don't want to change fluids too early. For example, in an automatic transmission, the fluid builds up those little metal shavings and particles, and they help it shift better."
    o_O
    timbobzimbob, Rambo54 and ChadsPride like this.
  2. Apr 20, 2017 at 5:52 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 16MX5Turbskie 17GT350
    Anyone seen my wallet?
    Better delete before third genners start dropping metal shavings into their trans
  3. Apr 20, 2017 at 5:58 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Show how much of these metal shavings does he expect to build up on a newish car?
    I have heard from some people, that if you have a slushbox with 100k+ with original fluid, don't bother changing the fluid at all.
    ChadsPride likes this.
  4. Apr 20, 2017 at 7:09 PM
    rjlem
    rjlem Well-Known Member
    Rick
    Franksville, Wisconsin
    2011 Reg Cab 4WD 2.7 A/T Bought used
    Int. Wipers, OEM Cruise, Fiamm Horns, Access Cover, Bed Mat, WeatherTech Floor Mats,
    On my Golf R, VW recommends 3yr/30K miles on the Haldex (transfer case) and 40K miles on the DSG.
    Not sure why BMW would not have a recommended service interval.
  5. Apr 20, 2017 at 7:14 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    The dealership part of the story doesn't surprise me. The reasoning for owning a vehicle with such fucked up maintenance procedures is what shocks me. o_O
    Rambo54, ChadsPride and TacomaMike37 like this.
  6. Apr 21, 2017 at 4:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no reasoning to justify it.
    This is too much Bull Shit for anyone. It is also a very good reason to stick to the manufacturers recommended schedule.
    I actually hate BMW's just for their stupid maintenance procedures along with the maintenance and repair costs.
  7. Apr 21, 2017 at 4:50 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    European cars are different.
    As I read this, I'm having my morning coffee and am preparing to work on a 26 yr. old Mercedes I've owned for the last 20 yrs.
    I just happen to have a 1/2 cup of metal shavings standing by.
  8. Apr 21, 2017 at 4:54 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    There is a reason most of the luxury euro cars we see on the road are leased; 1) people can't afford to buy them, and 2) they turn into nightmares after three years.
    Having to deal with all that bullshit just to change some fluids would make me want to sell it.
    ... and yet another reason the Tacoma is great. Everything is real easy maintenance wise.
  9. Apr 21, 2017 at 5:11 AM
    Zooks527
    Mansfield, MA
    There is no schedule for the differentials (effectively, drive it until it breaks) and the only recommndation on the TC is to wait until it tells you the clutch is about to fail.
    No argument on the maintenance point. I "over maintain" them according the manufacturer. Still, I sold my last one after 135000 miles with no major fails (ok, there was a recall issue in there) and I know it was going well 30k miles later.
    Now that the Tacoma's my DD, the use (and thus maintenance) on the BMW is dropping sharply. Once it's out of warranty, I DIY much of it and have a solid pair of indys to keep the costs reasonable.
    It does qualify as the easiest to maintain vehicle that I have owned to date.
  10. Apr 21, 2017 at 9:26 AM
    replica9000
    2019 T4R ORP
    Could be so people are more likely to return for service rather than do DIY maintenance. :notsure:
  11. Apr 21, 2017 at 9:38 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    I've heard something similar but it sounds like the guy has it backwards. Many people say that you don't want to change the fluid too LATE as the suspended particles may be providing the friction necessary to keep the system functioning.
  12. Apr 21, 2017 at 3:45 PM
    Justinlhc
    "The reasoning for owning"
