Inesshell bs and lazy af build
Discussion in '2nd Gen. Builds (2005-2015)' started by inesshell, Aug 2, 2017.
  1. Sep 7, 2017 at 7:05 AM
    #141
    inesshell
    inesshell [OP] blah blah blah
    All stock Superwhite 10' AC
    Hilux 167 snorkel install
    Items needed
    -ebay/Amazon hilux 167 snorkel (STH167RA)
    -3-4" 76-102mm 45 degree transition silicone hose coupler
    -dynomax 41428 aluminized elbow
    -3.5" worm ring clamp
    -4.5" worm ring clamp
    -double sided tape ~30#
    tools
    3.5" hole saw
    8/10/12mm sockets
    paint
    drill and various bits
    ruler/tape measure and sharpie
    dremel
    sharp knife
    Step 1
    take out the stock air tube, undo the clamp on the filter box and two bolts that connect on the fender and pull out the intake tube, tape up the cutting area
    Step 2
    Use the snorkel template to reference where the snorkel will fit and sit, i used a piece of cardboard and traced out the snorkel to get a better idea of where the snorkel curve where it meets the antennae to get a better ideal of where i wanted to customized my placement (i screwed the studs and and pressed them into the cardboard to see where holes were.
    ***the idea of the cardboard template was to replicate the actual snorkel shape and note/mark the notch for the antennae on the snorkel. The supplied template does not do this--- it only provides the placement of the mounting holes and where to start the hole saw***
    Use the template you made and place it over the old template and see where it lines up and move the placement around until you have a desired placement of your snorkel
    - it is very important that you use the top of the hood as a guide to place the snorkel, its better to keep the distant uniform along the hood line, I chose to place it about 3.25" from the edge of the hood to the snorkel.
    Step 3
    Mark your holes, oil, and drill. For the drill saw go at a good speed and just hold the saw steady as it will catch as it enters the fender so be prepared, it will be an ugly sound and jerk when it starts to bite into the metal.
    Step 4
    Use a dremel or hole saw to widen or oval the hole to make it easier to slide in, I used a dremel. I also double dilled the stud holes to allow for some adjustment but this is not needed.
    Step 5
    Paint the edges and wait for dry before assembly, cut the outlet of the snorkel to your desired fit as well as the rubber fitting, I removed around 1-1.5 inches on both
    Step 6 slide the snorkel halfway in and from the fender side (assuming your liners are gone) slide in the rubber coupler with the hose clamp, tighten it down with an 8mm socket
    add double side tape to the mount on the pillar and tighten down the bolts in the fender
    Step 7
    Slide in the aluminized tubing with all the appropriate hose clamps as well as the 4" to 3" coupler and tighten clamps and done......
    here is the fit of the snorkel, it fits well minus the small gap in front
    ****Before snorkel my temperature variance between intake air and outside air was between 8-14*f and now the variance is 1-5*f variance.
    mjp2, SR-71A, Manfred and 11 others like this.
  2. Sep 7, 2017 at 7:12 AM
    #142
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Need more pictures of your engine bay
  3. Sep 7, 2017 at 7:52 AM
    #143
    SlashMTB10
    SlashMTB10 Well-Known Member
    Southeast, CT
    2006 Toyota Tacoma DBL LB
    ICON Stage 4 w/ Tubular Upper Control Arms, Old Man EMU leaf pack, pro comp wheels w/ Cooper STT Maxx's, Pelfreybilt steel plate bumper, RCI skids, 4xinnovations sliders, custom built bed rack, ROAM Adventure CO. RTT and awning.
    Do you believe double sided tape will be enough to hold the snorkel to the pillar?
    MarX and inesshell[QUOTED][OP] like this.
  4. Sep 7, 2017 at 7:54 AM
    #144
    SlashMTB10
    Southeast, CT
    I love the trimming of the fender flares., how much did you take off??
    MarX likes this.
  5. Sep 7, 2017 at 7:58 AM
    #145
    fatfurious2
    David
    Ashburn, VA
    I have professional grade velcro. 3M dual lock
  6. Sep 7, 2017 at 8:12 AM
    #146
    SlashMTB10
    Southeast, CT
    where can one acquire such a thing?
  7. Sep 7, 2017 at 8:13 AM
    #147
    inesshell
    yeah, the bolts are plenty to keep the thing on, the tape is there to keep the bracket from vibrating
    MarX likes this.
  8. Sep 7, 2017 at 8:13 AM
    #148
    inesshell
    i took off about 2.5 inches
    MarX likes this.
  9. Sep 7, 2017 at 8:22 AM
    #149
    fatfurious2
    David
    Ashburn, VA
    MarX and inesshell[OP] like this.
  10. Sep 7, 2017 at 8:23 AM
    #150
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Nice write up John :thumbsup:
  11. Sep 7, 2017 at 3:11 PM
    #151
    inesshell
    Earfarmer, Nimble9, MarX and 6 others like this.
  12. Sep 8, 2017 at 8:31 AM
    #152
    inesshell
    had some extra FIPG and made a bug screen
  13. Sep 8, 2017 at 2:55 PM
    #153
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What's FIPG?
  14. Sep 8, 2017 at 2:57 PM
    #154
    fatfurious2
    David
    Ashburn, VA
  15. Sep 8, 2017 at 2:59 PM
    #155
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  16. Sep 8, 2017 at 3:00 PM
    #156
    BravesRunner
    BravesRunner “Exploration is curiosity put into action”
    Adam
    SC
    2021 GMC Sierra 1500 Denali
    Grandpa steps//Tri-fold Tonneau bed cover
    Flexible insulated pipe grout
    MarX, inesshell[OP] and fatfurious2 like this.
  17. Sep 8, 2017 at 3:00 PM
    #157
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Flaky inverted penis gobbler
  18. Sep 8, 2017 at 3:01 PM
    #158
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That was my next guess.
  19. Sep 8, 2017 at 3:02 PM
    #159
    BravesRunner
    Adam
    SC
    fucking idiots peeing gold
  20. Sep 8, 2017 at 3:02 PM
    #160
    fatfurious2
    David
    Ashburn, VA
    we just cluttered up his build thread. I thought this was the Lair. Sorry @inesshell !
