Inesshell bs and lazy af build
Discussion in '2nd Gen. Builds (2005-2015)' started by inesshell, Aug 2, 2017.
  1. Aug 2, 2017 at 6:40 AM
    inesshell
    inesshell [OP] blah blah blah
    All stock Superwhite 10' AC
    yep, 8 years later and here is a page :pccoffee:
    follow my build and travels on instagram @sliceoforegon
    Stuff for sale:
    Icon UCAs + other stuff for sale
    Recent: @75k miles
    Current Setup:
    Old Setup:
    The truck started out as a pavement king and was never intended to hit the dirt.....that didn't last long and after many iterations of the build it has grown to the truck it has today.
    Old: mall crawling days --- maybe late 2010 ish
    2010 superwhite access cab TRD Sport Tacoma
    Exterior:
    ARB bull bar with fog kit front bumper
    AP rear bumper steel with integrated hidden hitch
    - custom fab'd tire/hi-lift/jerry can swingout
    AP front steel IFS skid
    AP Mid skid
    AP Apex bed rack
    Brute Force front w/ center hoops
    Brute Force rear HC with swingout/table
    Front runner bed rack platform
    Trail Toys - gas tank skid
    Marshal Fab - Sliders with kickout - all tube and bolt on
    Mesojdm Gasshole
    Bushwackers textured finish fender flares
    ATO LCA Skid
    CBI Ditch Light brackets
    Prinsu access roof rack w/ 40" LB cutout
    RCI rear differential skid
    RCI Transfer case skid
    Relentless top light bar brackets
    RB large mudflaps
    SOS mid skid plate
    Factor 55 1.5 Offset Fairlead (for arb)
    Factor 55 flatlink
    Hilux 167 snorkel
    Enginaire 4-150/465
    Flowmaster 4x series exhaust
    Avid front light bull guard
    TRD alumn skid
    Relentless Bed bars 8" rise
    Interior:
    Mirror Riser
    Tech Deck
    Diode Dynamics flasher relay
    Mesojdm map/dome led
    Wheels:
    5x Trail Ready HD 17 Beadlocks with Rock Ring
    5x SCS BR6 17x9
    Yokohoma Geo Mt g003
    Cooper STT PRO
    Mickey Thompson 16" slotted with beauty ring
    Duratracs
    General Grabber At2
    Suspension:
    OME 9000 w/ 886
    Kings 700# front c/o with clickers
    Icon 2.5 non-resi c/o
    Fox 2.5 resi f/r with adjustors 700# king coils
    King 2.0 12" smoothie with res
    LR ver 1 UCA with updated poly bushings
    LSK Double Shear Gussets
    LSK upper control arms
    LSK lower control arms
    Kartek front/rear limiting straps
    AP braided extended brake lines f/r
    AP Expo leafs
    AP ubolt flip kit
    BAMF Hammer rear leaf hangers and shackles
    BAMF Rear Shock Relocate
    Relentless u bolt flip kit
    TC U bolt flip kit
    Power Stop pads w/ slotted and drilled rotors
    Wheelers front superbumps
    Firestone airbags w/ daystar cradles
    B110 extended midtravel shocks
    StopTech 6 pistion st60 calipers with 340mm rotors
    Sequoia master cylinder upgrade with sos fittings
    Total Chaos alignment tab gussets
    Total Chaos spindle gussets
    4.88 w/ arb lock locks
    Bed:
    At The Helm - bed stiffener brackets
    ARB 2000 awning
    BAMF Bed rail molle panel
    Dometic 55/60 fridge slide
    Oregon Rack - bed corner gussets
    Bedslide 1000 pro se
    Bedslide Retro fit Traxrail Kit
    Bedslide Side kix
    Mobtown - tailgate stiffener plate
    Leer C series alumn canopy with sliding/awning windows
    Rotopax mounting plate and pax
    Eezi awn k9 rack
    FSR M55 Adventure series RTT
    FSR M55 Annex
    CVT shasta RTT
    CAMCO 6.5' awning
    1UP Mount
    Electrical:
    Alternator Boost mod
    Dual group 35 yellow top optima
    Blue Seas ML-ACR
    Noco Genius Gen 2 on board battery charger
    Noco g7200/ gb70
    ARB twin compressors with locker solenoid
    ARB Breather Kit
    ARB elements 50qt fridge
    Renogy Voyager Solar Controller with temp
    200w flex solar panel 18v
    Snowmaster classic 60L fridge
    Scanguage
    ENGO XR 10s Winch
    Lighting:
    Coming Soon:
    Camazon, Gruber1922, Tacoben and 28 others like this.
  2. Aug 2, 2017 at 6:40 AM
    inesshell
    Links to Reviews and Updates of Reviews:
    Links to Mod write-ups:
    Re-locate ML-ACR to passenger side engine bay progress 8/6/17
    Trim fenders in prep for 35s 8/24/17
    ECGS 4.88 with arb lock locks 8/31/17
    Timmed ARB front bumper to match trimmed fenders 9/6/17
    Hilux 167 snorkel install 9/6/17
    AP Expo spring install 9/15/17
    Enginaire 4-150/465 install on hilux 167 snorkel 9/28/17
    ARB Awning install 10/22/17
    Bedslide trax rail kit and Side Kix bin install 11/12/17
    Total Chaos alignment cam tabs install 1/14/18
    Dismount and mount tires on TR Beadlocks 1/19/18
    Factor 55 rope guard for flatlink 1/25/18
    Insain Fab CMC install 2/1/18
    Slider gusset install 2/3/18
    ARB Breather kit install 2/28/18
    Renogy Flex Cell solar install 2/28/18
    Flush mount install 3/10/18
    ARB turn/park indicator wire tap instructions
    Bamf Hammer Hangers and Shackles 4/7/18
    Alternator Boost mod 4/8/18
    Swingout lock brackets 4/20/18
    Mesojdm Gasshole 6/2/18
    K9 Roof Rack 6/7/18
    DIY shower/rinse kit 6/13/18
    Extended boot mod for inner cv axle 6/28/18
    Remove stuck lock cylinder in Rotopax handle 6/28/18
    Airbag mounting plate fab on ubolt flip plate 7/9/18
    Fox coil swap with king coils 7/10/18
    Swingout strut install 8/14/18
    Seat fire extinguisher mount 8/19/18
    U joint and carrier bearing removal 8/20/18
    Bamf Relocate installation 9/9/18
    Rigid Chase light installation 9/11/18
    LSK double shear installation 9/18/18
    Waterport installation 9/19/18
    Hi-lift relocate with RCI brackets 10/10/18
    Consolidated LSK product writeup 10/17/18
    RCBs204 4x4 illuminated switch install 11/3/18
    Stoptech st60 install 12/1/18
    SOS mid skid swap for ap 12/4/18
    New Bd ditch lights 1/10/19
    New rear axle seals and bearings 1/20/19
    New bd rack lights s2 work lights 1/21/19
    Unbuild front for new bumper and rebuild winch 2/6/19
    Brute force front install 2/12/19
    Prinsu install 2/24/19
    Rear door removal and sound mat 3/18/19
    Front door removal and sound mat 3/19/19
    Tom Woods drive shaft swap 3/28/19 @77k
    Hood scoop wrap 4/2/19
    Sold Bedslide for Dometic fridge slide 4/7/19
    Second coat of por 15 5/5/19 (2)
    ROSEN sunvisors install 5/19/19
    1UP Roof Mount install 6/6/19
    Replaced fuel tank evap canister 1/16/20
    Reference for later projects
    water pump filter inlet 6/16/18
    Links to photos of trips:
    Day Trip up to Hood 8/5/17
    Browns camp 8/12/17
    Sand Lake 9/10/17
    Browns camp/ sandlake 9/17/17
    Timberline - first snow of the season 9/21/17
    La Pine -> Bachelor -> Sisters 9/23/17
    National Taco Day 10/4/17
    Deschutes Ride with Abe 10/21/17
    Hood RnR 10/28/17
    High rock snow run 11/5/17
    Christmas eve highrock run 12/34/17
    Proxy Falls 1/6/18
    Trask/Stone Mountain/Sandlake 3/30/18
    BBQ at GH for Chris getting his new house 4/22/18
    Timothy lake 5/5/2018
    Expo West 2018 Trip 5/14/18
    First time camping tentless - arb awning room 6/22/18
    Lake trip with doggos 8/19/18
    Fishing/camp with Khae/Sarn 9/3/18
    Cars n Coffee 9/29/18
    Beach trip with the doggos 10/6/18
    Trip to bend to visit fam 10/19/18
    Trip to sunriver for nephews bday 1/12/19
    Trip to bend with Kanga 4/22/19
    Memorial day and Waylon's first birthday 5/27/19
    Some fun shops of the truck:
    Camazon, Tacman19, lo2hi and 9 others like this.
  3. Aug 3, 2017 at 12:34 PM
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    Bro! Get some progress going so I can steal ideas!
  4. Aug 3, 2017 at 6:52 PM
    inesshell
    Lol working on it haha.
  5. Aug 3, 2017 at 6:58 PM
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    Finally! One of my favorite builds on here
  6. Aug 3, 2017 at 7:35 PM
    inesshell
    haha appreciate the words, im hunting down photos for the show ;)
  7. Aug 4, 2017 at 7:02 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    BUILD THREAD!!!!!!!!!!!!!!!!!!!!!!!!!!:woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot::woot:
  8. Aug 4, 2017 at 7:06 AM
    Kemosabe
    Louis
  9. Aug 4, 2017 at 7:11 AM
    inesshell
  10. Aug 4, 2017 at 7:13 AM
    Kemosabe
    Louis
    Your rig is too awesome to pass undercover!:rofl:
  11. Aug 4, 2017 at 7:22 AM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
  12. Aug 4, 2017 at 7:22 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I may or may not be "in" :spy:
  13. Aug 4, 2017 at 7:23 AM
    Slow Internet
    Slow...
    Wiper Blades
    Pretty awesome truck and a wealth of knowledge, so count me in!
  14. Aug 4, 2017 at 7:26 AM
    inesshell
    :cheers: lots of cursing went into the truck, I have the body saw ready for this weekend to trim the flares......then the actual fenders
  15. Aug 4, 2017 at 7:27 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
  16. Aug 4, 2017 at 7:28 AM
    Justanotherhemi
    Rick James
    I'm here for the pictures. He could be taking pictures of a turtle for all I care, this man can shoot!
  17. Aug 4, 2017 at 7:30 AM
    Slow Internet
    Slow...
    Wiper Blades
    this is true, i can set up a picture for an hour and it still looks like a finger painting in the end
  18. Aug 4, 2017 at 7:32 AM
    inesshell
    damn....dont got any pics of those :D
    ive got poms, corgi and birds ;)
    TacoLean, IronPeak, omaguz and 3 others like this.
  19. Aug 4, 2017 at 7:34 AM
    inesshell
    nvm i lied....i remembered i lived in hawaii for a bit..
  20. Aug 4, 2017 at 7:38 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
