Inesshell bs and lazy af build
Discussion in '2nd Gen. Builds (2005-2015)' started by inesshell, Aug 2, 2017.
  1. Mar 2, 2019 at 7:24 AM
    #1741
    inesshell
    inesshell [OP] blah blah blah
    All stock Superwhite 10' AC
    To keep the shaft clean from debris and cutting up the seals
    OverlAnderson[QUOTED] likes this.
  2. Mar 2, 2019 at 7:31 AM
    #1742
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    I have a few questions...
    are these "true" bead locks?
    whats the purpose of putting these beads in the tire?
    will something like your rock ring fit these... will these bolts even thread out?
    thank you sorry for the bombardment of questions
  3. Mar 2, 2019 at 7:42 AM
    #1743
    inesshell
    true beadlocks, beads help dynamically balance tires out while they are rolling, they are more meant for setups that dont balance well with weights
    no you cannot bolt rings to that to make a beadlock wheel, those might not thread out from the looks of it
  4. Mar 2, 2019 at 7:59 AM
    #1744
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    lol thanks man :thumbsup:
    inesshell[QUOTED][OP] likes this.
  5. Mar 4, 2019 at 5:18 PM
    #1745
    inesshell
    been thinking of adding the honeycomb to the collection....but i dunno
    9nLQe-qDfcxlyc9QECsv1jSYO3fGPuPhQ6IQ7Xh1_e3326d096a40d0dce697b22ca8395be3ce44ecf3.jpg
    back to oem grill for a bit, the devils horns just got back from powder
    uRu4PM13QYOU9itLj2TaYFuiEJhop2a3uofCCT03_9297227d0304f73359f5c6fcd9a3e9e3c60fe035.jpg
    before
    K1GixMz4763GTInxTyuXAikGr-qufQLivohU1QwI_d580248040a201defc00a488d0ca3896396470a0.jpg
    sam swapping leds on his cluster
    a72_ruAEbyKgz7Avk9p60gVUqo-hzMQC9Gl6kVzv_6e5ed4bbfca70381ebb95c493260175991a21111.jpg
    K1XIx3SrI_sQ7UdNkhOdAAWxufPbWOQcMsC6Gved_2b308e566b9514a072414f4eb1054cb30648ab3b.jpg
    21lYFiKD4PCCX-tZ9SR6vFXaflc5t1zDyq1359js_32dc99341ca4249012cc9b828ee6e7652364e48d.jpg
    lo2hi, Nimble9 and ChadsPride like this.
  6. Mar 4, 2019 at 5:20 PM
    #1746
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    <--- All about the Champagne flavor
  7. Mar 4, 2019 at 5:20 PM
    #1747
    inesshell
    never tried
  8. Mar 4, 2019 at 5:21 PM
    #1748
    Gunshot-6A
    Conner
    Everett, WA
    That and Pina Colada are worth a try. We have an organic-y markey place right by my casa, so I gave it a go.
  9. Mar 4, 2019 at 5:25 PM
    #1749
    inesshell
    ive tried the pina, its pretty good.
    im stocked on it for a while, took me a while to finish a case
    ufjyITg4XtUEfoSff_SKZW2A8uTgWc5LbpEKAI2e_cecf0aa0a4a2f914349eaec01c89d8249915cdd9.jpg
    Gunshot-6A[QUOTED] likes this.
  10. Mar 8, 2019 at 7:23 PM
    #1750
    inesshell
    little throwback to a year ago...
    lo2hi, OverlAnderson, TaKoToy and 3 others like this.
  11. Mar 9, 2019 at 3:54 PM
    #1751
    inesshell
    doing transmission cooler things
    t2296yEJwiIXF-5w0yrzTHjeQS-SiKO-BTG3xZlW_f40c97c111b5a2016f90a0592b8043a5da5152e8.jpg
  12. Mar 13, 2019 at 7:10 AM
    #1752
    inesshell
    ChadsPride likes this.
  13. Mar 13, 2019 at 7:48 PM
    #1753
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    How was having the contractor cap + gofsr? I know the ladder racks are meant for ladders (of course) - Curious on how the welds held up on the inside reinforcement. I like the new bumper but partial to the ARB since your truck was the reason I bought mine, haha.
    fatfurious2 and inesshell[OP] like this.
  14. Mar 14, 2019 at 3:43 AM
    #1754
    OverlAnderson
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    I'm addicted to these.. best flavor?
  15. Mar 14, 2019 at 7:12 AM
    #1755
    inesshell
    Ladder rack was fine for that setup I had, for reference that cap at the time had 4 sections on the inside where it was ribbed for reinforcement and none of them bent or cracked. It stood up to for all the rears I ran the tent, the fsr actually bent from high winds and was the really only complaint/issue I faced. Depending how much weight you will have in a tent regularly, I would consider having more feet attachments on the ladder rack -- mine had 3 on each side
  16. Mar 14, 2019 at 7:13 AM
    #1756
    inesshell
    I personally like the purple guava and peach mango
  17. Mar 14, 2019 at 6:02 PM
    #1757
    inesshell
    Don’t red loctite any Allen Head bolt ever lol
    What could have been 10 seconds was much more with a angle grinder, vice grips and a heat gun
    C14AA48E-2755-4A55-B67A-BB6A8817E256.jpg 20DE5192-5F90-4965-B4BA-CE4054F658EF.jpg
  18. Mar 18, 2019 at 3:21 PM
    #1758
    inesshell
    All is left is floor and front doors ..... one step at a time 09CEDCB9-0C5F-4E20-8571-19500533AC0E.jpg06DB268B-0963-45E5-A26B-24D67ABD833A.jpg65355F9F-2EC1-466C-AE92-695259225EC3.jpg
    HIghlande2, lo2hi and ChadsPride like this.
  19. Mar 19, 2019 at 12:25 PM
    #1759
    inesshell
    front door panel removal and applying sound mat
    remove handle screw and door screw
    hsBc7MGiQi6oHoYJfBfQnbzR8sg6csMKNPt-dTFH_cb69363bde55de8d68876692b7674466db7965c9.jpgUTtlGzKZSGGFZkVBbOUKq9R4CACfWwQQL7BBkkPy_582bc94ea76cfd60f76beff5a6ca4e7c12692f59.jpg
    push pin plug with phillips near front of door
    Tl8Zcey5-gHx1cT4Re4Z9zQ-20MnGBEIa_Q6gMTk_534b0986d8e662f28f5139469427631c9d022bb5.jpg
    pull off triangle trim above tweeters
    SskpgdnTC8m-CmL5oQ98yO99hYFTFVroUcAnSCzW_58e38a791d7704585a392c3e9ea85ccf04b9fae9.jpg
    pry the window controls from the front and lift
    m8U2Bu5TXDjjDqPgYVG_9XKJtwHejgzuqjrYF78P_25b0bebadd642160db54f10d8529cc85770f7c3a.jpg
    pull panel starting from the front and work down and around to back, the window section has hooks on the panel it self to rest on
    QHm49ua5VrunR6fFwtdotnBi4URwmWNKx8pHgbDV_fe3fb48db0eaea6f4c66d07335618474d648703b.jpg
    remove plastic seal to get to the black cover with phillips and speaker with 10mm
    lGE74AxvN51gzaZMUJwsCyclxsGPaHpJbQZOzb6q_cea28b731203e9bad97301ac97e64798a15f624a.jpgsk1F6JOKq8ux-yC6zs6TqbAdIXOEVzJjYf9u5b3u_642ed5ca25a3e275a84277b7fe5eae7c64bcb1bc.jpg
    mat the backside of the black cover
    Fkqjr6WWlWrZFxTLXUR5zD3urParVJsYnIybkAbu_76afb4a584c0574b1cca494870180c3909439cf2.jpg
    mat the insides and reassemble, use small strips
    xxkYb_KN_hrncjxb-DmqJmbpXAuMkH382HON3TPb_4aeaa81eaa4acf70ee78d897955cef976b2e20c8.jpg
    dont forget to recover the white clips for the triangle trim and apply it back on the black trim before snapping back on
    wKVupNa-3WdNoSe00OEDfrq-uJSOR9cmJLKGK97h_925bce62a47101e866c3bf1908a17ab79807c239.jpg
    done
    cR1m4wkuG02tfmRvipjAvI6Dq5iCb0PHTP1ZT7DH_7c36efac161f8f6fb7649af010c2e6742554ef0d.jpg
    SonnyBones, Nimble9, lo2hi and 2 others like this.
  20. Mar 19, 2019 at 4:13 PM
    #1760
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    Just did the inner skin and not the outer??
