Injectors
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ambrosia, Jun 30, 2015.
  1. Jun 30, 2015 at 9:46 AM
    Ambrosia
    Ambrosia [OP] Member
    2004 tacoma 3.4 crew cab
    Toyota knows injectors short out stop working correctly. they just clean them.Do they have better injectors now?
  2. Jun 30, 2015 at 7:46 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've never heard of this problem. I have an '04 V6 with 160k and original injectors. Just dump cleaner in every oil change and use Top Tier.
  3. Jul 2, 2015 at 5:38 AM
    Ambrosia
    I have been doing that. Toyota just cleaned them and said I should have I stalled new ones after 150,000 miles. They wanted $400.00 for the injectors and $250.00 man hours. Price for a set of 6 is $200.00 online and auto stores. I get no power and have to pump the gas petal to move.
  4. Jul 2, 2015 at 5:48 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I went 300000 on my original injectors and never once added any fuel treatment or changed the fuel filter.
    Are you sure you have an injector problem? Most times when they get bad, you will have a hot start issue.
  5. Jul 2, 2015 at 5:55 AM
    Ambrosia
    Tell me more hot start?
    top tier?
    Sea foam treatment for oil?
  6. Jul 2, 2015 at 6:05 AM
    koditten
    Kirk
    Central Michigan
    When injectors start going bad, they generally leak when the vehicle motor is off. This is noticed more when the truck sits for 30-60 minutes after fully warmed up. The engine is hot, so the leaky injector fills the intake with a large amount of fuel That turns to a very rich vapor concentration. You try to start the truck and it acts like the engine is flooded, which it is. You have to crank and crank the engine to get rid of the excess fuel vapors before it will start.
    This happens because the fuel system is still under pressure. The pressure pushes against the leaky injectors, thus putting unwanted fuel into the engine when the engine is off.
    You don't notice this with cold starts because the fuel that leaked past the bad injectors has all night to evaporate.
  7. Jul 2, 2015 at 11:12 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '03 cbr600rr, '09 R1, '03 cbr954rr
    Subbed. Thinking I have leaky injectors myself. Plan on replacing them.. would leaky injectors affect mileage considerably?
  8. Jul 2, 2015 at 11:54 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Top tier gas, like chevron, shell, Costco, etc.
    Don't use seafoam. Use Chevron Techron concentrate. Lots of folks of Bob is the Oil Guy swear by it and have shown its better than seafoam.
  9. Jul 3, 2015 at 12:02 AM
    NightProwler
    Harlan
    Maricopa, Az
    Seafoam did nothing for me. Used bg44k and didn't seem to do anything either. Maybe I'll give the techron stuff a shot in the meantime before I delve deeper into my motor..I plan on purchasing some injectors on eBay as well as a bunch of other things to basically rebuild the top end while I'm in there to fix a tiny coolant leak I discovered somewheres. Anyways... what do you think about these injectors?
    http://pages.ebay.com/motors/link/?nav=item.view&id=301497414570&alt=web
  10. Jul 3, 2015 at 12:04 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I would stick with OEM parts. As far as your coolant leak, it may be a sign that the water pump needs to be replaced depending on your mileage. Might as well do the timing belt while you're in there as that is likely due as well.
  11. Jul 3, 2015 at 1:12 AM
    NightProwler
    Harlan
    Maricopa, Az
    Naw water pump kit was done a few months ago. It's leaking out of the back plate under the intake manifold by firewall. Thinks it's the bypass tube inside or a manifold gasket. So I'll just be buying everything I can since I'll tear the top end down to find that leak. It's actually not leaking lately. Saw some coolant dribbles down the backside of the motor and discovered its leaking through the foam surrounding that plate... Anyways, I kinda wanna try them injectors out as I'm on a budget. Is there a similar oem set to buy versus going thru stealership that won't cost me an arm?
  12. Jul 3, 2015 at 5:16 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    they look great but a note of caution on the seller.
    I sent her a pm about injectors a few months back asking if they were new new or new rebuilt reconditioned and she had no clue and said she had no idea, she replied "I am just reselling them and I don't know any details about them"
    lease let us know if you buy them and how they look because I might be buying a set if you can confirm they are genuine "new" and not reconditioned.
    it seams just like the timing belt, its a good idea to replace the injectors after 100k miles since they can start to leak and cause problems when they get old.
  13. Jul 3, 2015 at 9:18 AM
    Ambrosia
    At toyota now. They do not know about problem with injectors. Toyota new injectors $186.00 each. Online same part number $186.00 to $220.00 a set. Last time they cleaned the injectors. Within three weeks the problem came back. When it happens I have to pump the gas petal.
  14. Jul 3, 2015 at 1:25 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  15. Jul 3, 2015 at 2:05 PM
    Ambrosia
    Does the Tacoma have a fuel filter? and if so were is it mounted?
  16. Jul 3, 2015 at 2:09 PM
    keakar
    karl
    louisiana
    yes, on yours its under the drivers seat mounted to the frame rail, to replace it you need to loosen the fuel line brackets to allow room to separate the filter from the lines and it will leak fuel so be sure to do it after the truck has sat several hours to remove pressure in the lines and be prepared to get gas spilled on your hands while you replace it.
    on 4 cylinders its hidden way up under the intake manifold where it almost cant be seen.
  17. Jul 3, 2015 at 4:43 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Techron works for me. You can get it cheap at Costco.
  18. Jul 3, 2015 at 4:51 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
  19. Jul 17, 2015 at 12:41 PM
    Ambrosia
    Found the problem with injectors. It was the electric control for the injectors. Toyota did the whole replacement and parts, labor for free. Toyota has a warranty on this part. So if you have the problem of the engine not responding to the gas pedal. Take it in. Toyota plugged in a portable laptop and drove my Tacoma 2004 for 5 minutes and did the replacement of parts. Labor. Etc... $1,400.00 total cost. I paid zero. Repairs free for me
