input needed from experienced members1!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Freewheelin88, Dec 31, 2014.
  1. Dec 31, 2014 at 11:43 AM
    Freewheelin88
    Freewheelin88 [OP] Active Member
    Alex
    San Fernando
    99' pre-runner 4cyl 2.7 auto
    Bilstein 5100. AEM Short Ram Intake
    Alright after help from some of you guys and much research. I finally got a good build idea for my tacoma. Im just looking for some input from guys that either have a set up like this or know their parts well. Here it goes.
    HAVE:
    1999 tacoma auto/2.7 2wd pre runner
    bilstein 5100s all around set at 2.5" up front
    WANT to install:
    Front 3" toytec coil spacers
    Rear 1.5" Wheelers HD Progressive Add a leaf
    Rear toytec 1" shackle lift
    Rear pro comp 1000 extended length shocks
    (lookin to spend about 500$)
    Any input if this would be a good set up would be appreciated. Thanks!
  2. Dec 31, 2014 at 12:26 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You have 2.5" in the front now? What do you have in the rear (for lift) currently?
    Why are you getting 3" coil spacers? You'll have to put the bilsteins back down to ZERO..... and you're only gaining 1/2". You can't have both.
  3. Dec 31, 2014 at 12:49 PM
    Freewheelin88
    Alex
    San Fernando
    Its currently stock in the rear. I didn't know about the front set up, thanks for the heads up. I guess my next question would be what could i do for the front to get another 1-1.5" lift out of it. Most off roading i do is hit some minor trails and cal-city whenever i get a chance.
  4. Dec 31, 2014 at 1:06 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Unless you go to a drop bracket lift, like a 6" Fabtech, you're not going to get more than 3 or 3.5" in the front. The control arm and CV axle angles get too high, and the suspension travel is shot. You end up with a shitty ride and the CV boots blow out all the time.
    You don't really need more than 3" to run 33's, and I definitely wouldn't recommend a drop bracket lift. Some people add a 1" body lift if you really want the extra clearance.
  5. Dec 31, 2014 at 1:31 PM
    JTrean
    JTrean Well-Known Member
    If you're looking to beef up your front end, I would recommend adding a pair of eibach coils to your bilstiens. You will have to run the billies at zero if you add the coils however. That will put you at or just above 3" in the front.
  6. Dec 31, 2014 at 1:32 PM
    Freewheelin88
    Alex
    San Fernando
    I've checked the fabtech one out too but around 3.5 is all I really want and need. Only other thing I've seen that will get me close to 3 is eibach coilovers made for the 5100s. I want to exclude using blocks. Just because I haven't heard great things.
  7. Dec 31, 2014 at 1:42 PM
    Freewheelin88
    Alex
    San Fernando
    That's exactly what I'm looking to do. I came up on those as well right now so that's what I'm gonna order. Still stock in the rear. If I do the 1.5" progressive AALs in the rear you think it'll look leveled or just leave it alone?
    btw thank you for helping me get somewhere with this haha
  8. Dec 31, 2014 at 1:45 PM
    JTrean
    I would definitely do the add a leaf. You would most likely have bro lean if you don't.
  9. Dec 31, 2014 at 1:48 PM
    Freewheelin88
    Alex
    San Fernando
    Yeah that's what i was thinking. With the add a leaf you think the 5100s will be good in the rear or would I need longer shocks back there?
  10. Dec 31, 2014 at 1:55 PM
    JTrean
    5100's will be just fine
  11. Dec 31, 2014 at 2:00 PM
    Freewheelin88
    Alex
    San Fernando
    Right on. So I'm gonna order up the eibach front coil overs and the wheelers 1.5" pregressive AAL. Thanks for the help man! Cant wait to slap everything on there.
