Install cat-back exhaust - need a lift or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RingSteel, Nov 2, 2010.
  1. Nov 2, 2010 at 1:10 PM
    RingSteel
    RingSteel [OP] Member
    To replace the cat-back exhaust on '09 Pre-runner, does it require a lift to enable the factory piece to be removed?
  2. Nov 2, 2010 at 1:14 PM
    ser240z
    ser240z Well-Known Member
    Scott
    Monterey Park, CA
    '23 TRD Pro 6spd
    I have an '09 DC 4x4. I put in the TRD cat-back in my driveway no lift. I did remove the spare though. I just had to twist it around a bit to get the stock off and the TRD on. I put a trap underneath so I wouldn't scratch up the piping, like it's not going to get messed up in the dirt, but oh well.
    Hope this helps.
    Scott
  3. Nov 2, 2010 at 1:16 PM
    RingSteel
    Thanks for the replies.
    I hadn't thought of removing the spare to make more room. Thanks for the tip!
  4. Nov 2, 2010 at 2:11 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Agreed.
    Sent from my computer using my keyboard.
  5. Nov 3, 2010 at 7:37 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    What I found to work was to unbolt the exhaust, remove the hangers from either the exhaust or the truck, whichever is easiest. Then twist the exhaust 180 degrees to the driver's side (exhaust tip pointing towards the driver's side. Then pull it over the diff, being careful to guide it over the brake lines attached to the diff.
    Only other thng was to wrap the new tip such that it didn't get scratched. I also twisted/untwisted it this same way to install the new one. I.e., point tip toward driver's side, push it over the diff, then untwist it into position.
  6. Nov 3, 2010 at 7:41 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Lots of 4 letter words may emerge during this proceedure...:D
  7. Nov 3, 2010 at 7:46 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not for me, and I am prone to letting 'em go whenenver I feel the time is right. :)
    For example, I let a few go when trying to remove the TRD exhaust from the hangers. The TRD hangers appear to have a larger end than the stock hanger, which made removing it a bit more painful than the install.
  8. Nov 3, 2010 at 8:41 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Have to take the spare out for sure. Then the old one slips right out and the new one slips right in! (Thats what she said). Did mine in the driveway also with no problem. I just wrapped a towel around my trd exhaust tip so I didn't scratch that up.
  9. Nov 9, 2010 at 11:28 AM
    RingSteel
    It went without a hitch. Taking the spare out makes plenty of room. Thanks for the tips!
