Install heated seats 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thomas3ford, Apr 30, 2018.
  1. Dec 22, 2020 at 8:51 AM
    #81
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    How about an Arduino relay, might be simpler than a Pi? I thought about doing that but it seemed overkill, although getting a delay and temp conditional activation might be a worthy quick project.
    That is a good question above, maybe with the 2021 dual climate there is something in the wire harness to tap into.
  2. Dec 23, 2020 at 9:57 AM
    #82
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    Can you PM me a that wiring diagram? Just curious how it all goes together incase I need to trouble shoot it the future.
    #82
  3. Feb 10, 2021 at 11:17 AM
    #83
    ZachWalz85
    ZachWalz85 New Member
    Zach
    3rd Gen Tacoma double cab 6'
    Did I miss it in the thread or did you have a link to where you found the seat heater switches? Looks really clean and something I hope to tackle in the future.
  4. Feb 10, 2021 at 11:35 AM
    #84
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    #84
    Otto-x likes this.
  5. Feb 10, 2021 at 11:39 AM
    #85
    ZachWalz85
    Zach
    Ok, thanks! I failed to see they were part of the larger kit.
  6. Mar 12, 2021 at 9:23 AM
    #86
    TacoMan408
    TacoMan408 Well-Known Member
    CA
    2016 TRD Sport Manual
    OVTune (04B13+1.05 87 FOB), Morimoto XB Headlights, Toyota LED Fog Lights, Toyota TRD Lift Struts, Wheelers Progressive AAL, TRD Pro Tail Lights, 17" TRD Pro SEMA wheels, BFG 285/70R17, TRD Skid Plate, Bakflip MX4, OEM Audio +, Anytime Front Camera, G-Tek Fab Door Sill Protectors, WeatherTech Floormats Suntek Carbon 35% Tint
    Looks Great! I just picked up this kit and will be installing it very soon. Did you wire your switches in a specific way to dim illumination with the other switches with the lights on? I've seen other after market switches are way brighter than the stock switches, but it appears to be uniform in your night picture. Thanks!
    #86
  7. Mar 12, 2021 at 10:22 AM
    #87
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    Wired the seat heater switch so that it dims with factory switches. Tied into the dash light wiring for the cargo switch
    TacoMan408[QUOTED] likes this.
  8. Mar 12, 2021 at 11:59 AM
    #88
    TacoMan408
    CA
    Thanks! So the illumination wire from the heated seat switch tapped to the illumination wire of cargo switch (or another OEM switch). Did you do anything special with the ground wire? or just grounded to the body?
  9. Mar 12, 2021 at 12:17 PM
    #89
    VicNic3
    GA
    Ground to body
    TacoMan408 likes this.
  10. Mar 17, 2021 at 5:08 PM
    #90
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    How are the kits from wukexue2010 seller holding up? Switches still good? Wires not burning? Trying to find OEM looking kit that I won't have to redo in short order, which would suck.
    Also to confirm - the LO/HI settings activate both heaters (butt & back) and adjust heat power, correct? Apparently there are kits where the switch basically controls two modes: back only, or butt+back.
    #90
  11. Mar 17, 2021 at 5:12 PM
    #91
    unclemat
    2012 TX Baja
    Also curios if anyone has experience with this dual dial switch kit.
    It is attractive as it would require only one switch blank.
    #91
    VaToy likes this.
  12. Oct 21, 2021 at 10:54 PM
    #92
    tylerthompson21
    tylerthompson21 Well-Known Member
    Tyler
    2022 Taco TRD-OR
    Custom Hiatus Pop-Up Hard Sided Camper
    Thank you so much for the write up! Without having all of the options I want from the dealer (without getting super fancy packages) this mod is a game changer!
  13. Oct 22, 2021 at 2:03 AM
    #93
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I installed this kit under my Clazzios for almot 3 years and works great, no issues. The lights do dim when dimming the the dash, also high and low ketts both back and butt warm but at higher or lower heat. Hope this helps.
    #93
  14. Jan 6, 2022 at 4:40 AM
    #94
    Vinnybontitty
    Vinnybontitty Well-Known Member
    Vincent
    2021 TRD Off Road
    I definitely need these my ass is cold
  15. Jan 22, 2022 at 7:50 AM
    #95
    tacoshell88
    tacoshell88 Not that well known member
    Michelle
    Somewhere along the Mexican border
    2021 DC Cement TRDOF
    Do any of you know if the switches for the 4Runner will work with the clazzio kit? I prefer those switches to the Hi-Lo button ones. I’ve been shopping around and not sure if ordering the OEM parts to aftermarket and really just clueless. I would really like the option of leaving the switch on whenever I remote start my truck in the AM and warms up.
    I’m not an expert on any of this. I can do oil changes and spark plug changes lol but nothing electrical at all. Hoping the easiest pnp option. Halp.
  16. Feb 8, 2023 at 2:38 PM
    #96
    crockett8513
    crockett8513 Member
    Thank you for this write-up! I successfully followed along with little to no electrical experience lol
  17. Jun 22, 2024 at 4:55 PM
    #97
    tacomaware68
    tacomaware68 New Member
    Warren
    2023 Tacoma
    Mid Rise Leer cap, Liberty Brake controller, sleeping platform in back, nothing exciting :-)
    WOW, good work folks...glad I have heated seats already. My issue is different, heated seats work perfectly but My wife gets a rash from the bottom heated seats if on too long but her lower back needs it....is it easy to disconnect the bottom of seat and leave the back to work? Or put a switch in so I can turn bottom off when want?
