Install hitch and wiring harness myself or pay someone to do?
Discussion in 'Towing' started by newfie8, May 26, 2013.
  1. May 26, 2013 at 6:11 AM
    newfie8
    newfie8 [OP] Well-Known Member
    newfoundland
    09 tacoma
    Tinted windows all around. Fog lights. Intermittent wiper switch. Skid plate. Extra D rings. Grillcraft. Color matched grill. Hella 500ff HID behind grillcraft. Rcbs204 Lighting. 5100's up front. 265/75/16 Duratracs.Firestone riderites. Bora Wheel spacers. Tinted tails. De badged. Blacked out rims.
    I try to do all my own work on my truck, Do i really need to pay someone to install the hitch and wiring harness?
  2. May 26, 2013 at 6:14 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    If you can turn a wrench and look at colors you can install it
  3. May 26, 2013 at 6:44 AM
    FrankNasti
    FrankNasti Well-Known Member
    Frank
    Anywhere the Army tells my wife to go.
    Subaru Forester
    The toddler and baby seat mod.
    If you work on your own truck, just do it yourself and save a few hundred bucks.
  4. May 26, 2013 at 12:22 PM
    Yota1
    Yota1 Well-Known Member
    Crazy easy to do.
  5. May 26, 2013 at 4:18 PM
    newfie8
    newfoundland
    09 tacoma
    Ok I think Yota1s comment sealed the deal. Ordering hitch and harness off ebay tonite!
  6. May 26, 2013 at 4:22 PM
    newfie8
    newfoundland
    09 tacoma
    Guys I'm getting the curt class 3 and this wiring harnessImageUploadedByTapatalk1369610519.178955.jpg
  7. May 26, 2013 at 4:23 PM
    newfie8
    newfoundland
    09 tacoma
    No idea about wiring harness's. will this be ok?
  8. May 26, 2013 at 4:32 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    That's a 4flat, it'll do for most minor trailers. If you need a 7 pin there is a conversion to that, it incorporates the 4flat towards the harness conversion.
  9. May 26, 2013 at 7:06 PM
    Yota1
    Disconnect harness from tail lights, connect to trailer harness, reconnect to tail light, and bolt them back in place. Done. All plug and play.
  10. May 26, 2013 at 8:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto.
    I was able to install my hitch by myself in about 30 minutes.
    Bumper ended up maybe 1/4" off center (1/8" on each side)... no big deal. I'm the only one that knows it's not lined up.
    The harness is a no-brainer as Yota said. Very simple.
    The 7-wire harness is much more involved, because it not only has the rear lighting, but also trailer brake and +12v supplies.
    Still not rocket science, but unless you need those functions, you'll likely be using a 4-flat adapter with it anyways.
  11. May 26, 2013 at 9:28 PM
    aj hank
    aj hank Well-Known Member
    AJ
    412 PA
    09 Regular cab
    Hi/lo HIDs, window tint, keyless entry
    Yea get a buddy to help or a good jack and its easy and will only cost you a few beers
  12. Sep 6, 2013 at 8:39 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Probably a dead thread but figured better than starting a new one.
    How is the curt holding up. I found it on Amazon for 103.00 shipped. And I am wanting to put a hitch on the truck to tow the jet skis and camper.
