Installed 4.88 Gears in my 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Oct 11, 2016.
  1. Mar 11, 2017 at 10:31 AM
    #641
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    hi all got a 4.88 gear change question . I have a 17 access cab utility 4x4 4cylinder automatic. My question is im soon going up to 255 85 16s I currently have 4.30 gears. Would going up to 4.88s from my 4.30s be enough of a jump to get back to stock. Lots of hills were im from and my commute is far so any help would be great .Thank you in advance for your time and help
  2. Mar 11, 2017 at 11:23 AM
    #642
    mark1285
    mark1285 Well-Known Member
    Mark
    2017 Tacoma TRD Off-Road
    The above excel sheet should answer all your questions!
    EDIT:
    May be easier to find the calculator here:
    https://www.tacomaworld.com/threads/transmission-gear-diff-ratio-tire-size-speed-calculator.477264/
  3. Mar 11, 2017 at 5:10 PM
    #643
    mopar2
    mopar2 Well-Known Member
    Franklin TN
  4. Mar 11, 2017 at 5:31 PM
    #644
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I still have my 4.30 ring and pinions, selling for 700 free shipping they have 8k miles on them.
  5. Mar 12, 2017 at 4:08 AM
    #645
    mopar2
    Franklin TN
  6. Mar 12, 2017 at 6:48 AM
    #646
    Kauhi
    Kauhi Well-Known Member
    Kauhi
    From Maui, Live in Portland OR
    2016 Tacoma 4x4 Off Road
    285/75/16 KO2, OME BP-51 3" Lift Kit, TRD Exhaust, TRD CAI, 30" Light Bar Grille, etc...
    mopar, whats the difference between the mini kit that's selling for 875, versus the other kit that's for 1375?
  7. Mar 12, 2017 at 9:22 AM
    #647
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    The mini and master install kits. With the mini kit you reuse some of your old bearings. With the master you get new everything. I'd spend the coin to get the master install kit.
  8. Mar 16, 2017 at 12:04 PM
    #648
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    For those that have the 4.88's installed, how does the truck's power feel at 1500 RPM (or below), say in 4th gear? With the stock gearing, it feels like I have very little power and the truck ends up downshifting to 3rd. I'm just curious if the 4.88's now make the truck noticeably more responsive in the lower RPM's that the truck likes to shift at.
  9. Mar 16, 2017 at 4:27 PM
    #649
    mark1285
    Mark
    I just picked up my truck today from the shop with 4.88 regear..... its night and day. I'm so pumped. It held 5th going over a fairly steep overpass at 40mph no problem. RPM was like 1100. Before I was downshifting. I run 33's LT Toyo's. Highway tomorrow I'll post the results.
  10. Mar 16, 2017 at 4:37 PM
    #650
    DoubleAction
    DoubleAction Well-Known Member
    :) Good to hear! Are you running automatic tranny?
  11. Mar 16, 2017 at 4:40 PM
    #651
    mark1285
    Mark
    Yes automatic transmission. I'm a big fan of re gear from an engineering perspective and the way it feels. If your even considering it, do it.
  12. Mar 22, 2017 at 5:39 PM
    #652
    Klick
    Klick Active Member
    Orange County
    2016 Tacoma trd 4x4
    Icon stage 4 kit method wheels bfgs
    Anyone in the socal area do this yet? If so where did you get it done at...
  13. Mar 24, 2017 at 8:09 PM
    #653
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    I got my 3rd rebuilt with these guys.
    http://rsoperformance.com/
    Also look them up on Instagram as @rocksolidoffroad
  14. Mar 31, 2017 at 2:43 PM
    #654
    gearguy911
    gearguy911 Well-Known Member
    Boulder, CO
    2016 Magnetic Grey Tacoma TRD OR DCLB
    Would anyone recommend doing air lockers at the same time you do the gears, if you are thinking about it. Since you would be in the diffs already?
  15. Mar 31, 2017 at 2:56 PM
    #655
    mark1285
    Mark
    Without a doubt. I have a TRD off road and I did the front. If you don't have an electric real locker I'd definately do both.
  16. Mar 31, 2017 at 3:07 PM
    #656
    Kauhi
    Kauhi
    I just installed 4.88 gear and also recommend doing front air lockers. They are awesome.
  17. Mar 31, 2017 at 3:35 PM
    #657
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    which front air lockers did you go with?
  18. Mar 31, 2017 at 4:13 PM
    #658
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    I got 4.56s at San Diego Gear and Axle. It's awesome, but I'm pretty sure if I did it all over again I'd do 4.88s and lockers. I have a Sport Auto and a lot of extra weight running 285/70/17 I never thought I'd get in a situation where I'd need lockers, but then this weekend happened. And the 4.56s are great, I just never thought people would see 2000 rpms with the 4.88s on the highway but I was wrong.
  19. Mar 31, 2017 at 4:23 PM
    #659
    Kauhi
    Kauhi
    I did ARB front lockers
  20. Mar 31, 2017 at 5:54 PM
    #660
    mopar2
    Franklin TN
    456? More info please.
