Installed D-Rings in the Bed (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Feb 27, 2009.
  1. Jun 25, 2011 at 1:26 PM
    #261
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Wow. Trying to do this right now. I'm going to need a cheater bar. I can't get those bolts out!
  2. Aug 8, 2011 at 1:31 AM
    #262
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    Anyone come up with a hook and a steel backing plate to take more pull/weight than the stock d-rings? I'm trying to find a way to make a real strong anchor for a bike lock/chain, a Kryptonite New York chain. Bullet proof chain, literally.
  3. Aug 8, 2011 at 9:36 AM
    #263
    JKD
    JKD Well-Known Member
    Not sure what you're asking here...but if you install the mil-surp D-rings to the bed bolts, you can probably put quite a lot of load on the ring.
  4. Aug 8, 2011 at 10:21 PM
    #264
    tacomtn
    I'm looking for a higher load plus stronger metal. The Kryptonite chain is 1/4" hardened steel, can't be cut with a hacksaw. So I want an anchor strong enough to take the load of tightening with rachet tie downs as well as hacksaw resistant, like a hardened steel hook, to equal the strength of the chain.
    The anchor point/plate must cover the hex nut or use a carriage bolt so it can't be removed with tools. If I can't use a carriage bolt, a hex bolt could be used to anchor the hook. Then put a plate over the hex bolt with just the hook exposed (with a slot just large enough to let the hook stick out) to attach the chain lock.
    I'm thinking this could work. But where can I get hardened steel hooks/D-rings?
  5. Aug 8, 2011 at 11:08 PM
    #265
    JKD
    I don't know what you're trying to secure to the bed, but if it is that valuable they're just going to take the truck. And even if your chain, lock, and bed anchor are all hacksaw resistant, they aren't resistant to cut-off saws with diamond blades.
    At some point, you just have to buy better insurance.
    DirtyArmor likes this.
  6. Aug 8, 2011 at 11:17 PM
    #266
    tacomtn
    mountain bikes mainly.
    sure there's always a way to steal something but i'm going to make them work for it.
    so besides the better insurance, stealing-the-whole-truck, and diamond hacksaw blades issue, i'm still thinking about the anchor. if you've other ideas for that i'm open to your creativity.
  7. Aug 8, 2011 at 11:20 PM
    #267
    FY01CPO
    FY01CPO Well-Known Member
    Jeremy
    CT
    SR5 4x4
    black tube steps, side marker turn signals, 15% tint and window strip, EGR vent shades, fighter pilot/cockpit mod, console and glove box auto on LED, anytime fog light mod, 3000k HID fogs, bed mat wing nut mod, locking bed storage bin mod, smoked tail lights, plasti-dipped rims, blacked out emblems, black tail pipe, tail gate hose clamp, rear seat utility/dog shelf with rear center console access door.
    I was thinking about doing the same thing with mine.
  8. Aug 13, 2011 at 5:52 AM
    #268
    donanoyus
    donanoyus New Member
    Scott
    De Pere, Wi
    08 Blue TRD Sport
    I love this idea of adding more tie downs to the bed. I have wanted to do this ever since I got my truck in 08. I am curious about where everyone got their d rings ( other than Toyota dealers and the army surplus site) because I'd like to do this mod today or in the next couple of days.
  9. Aug 13, 2011 at 7:25 AM
    #269
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Mini-Vans in salvage yards are full of them...
    Marc M
  10. Aug 13, 2011 at 9:59 AM
    #270
    JKD
    I would say have a slot cut in the bed so that a large loop made from about 3/4" diameter hardened steel can be welded directly to the frame.
    Or cut a large enough hole/holes to run your chain through and loop around the frame.
  11. Aug 13, 2011 at 10:31 AM
    #271
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Very nice!
  12. Sep 2, 2011 at 10:36 AM
    #272
    mikesfarm
    mikesfarm Well-Known Member
    Florida
    2025 4wd Tacoma SR5 DC
    Thanks for the part source.. I just got mine today and installed them. They look heavy duty (better than stock). I have not cut my mat yet.
  13. Sep 5, 2011 at 3:50 PM
    #273
    Allen102
    Allen102 Active Member
    I did the same thing, but I bolted the D rings right through the rubber mat, so nobody could steal it, and it looks more finished.
  14. Sep 5, 2011 at 3:56 PM
    #274
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    that's gonna make it hard if you ever need to take the mat out. I have taken my out on a couple of occasions when I've wanted things to slide. Not to mention, there' no way you can torque the bolts
  15. Sep 5, 2011 at 4:09 PM
    #275
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Will the bed rattle loose now?
  16. Sep 9, 2011 at 7:35 PM
    #276
    Dan05
    Dan05 Member
    Dan
    Little Rock, AR
    '05 V6 4x4
    I got my '05 this Spring and it wasn't very well maintained by the previous owner. At the forward end of the bed, there was enough dirt to cover and clog the drain holes. I poked a twig in the drain holes and washed the bed and mat with a garden hose. Problem solved. I'd consider doing that maybe once a year.
  17. Sep 9, 2011 at 7:43 PM
    #277
    Dan05
    Dan05 Member
    Dan
    Little Rock, AR
    '05 V6 4x4
    I'm planning to do this next weekend when the parts arrive, on my long bed. Because of the different footprint of the bed and mat, I'm planning to cut circular holes in the mat.
    I figure a circle is harder to cut (and make it look good), but it has no corners to snag and possibly tear. Will post pics.
  18. Sep 9, 2011 at 7:46 PM
    #278
    ImpulseRed008
    Susan
    SC
    I was gonna use a hole saw to cut the holes... just haven't gotten around to it yet. :eek:
  19. Sep 9, 2011 at 8:23 PM
    #279
    Dan05
    Dan05 Member
    Dan
    Little Rock, AR
    '05 V6 4x4
    I thought about that, but I'm gonna try to use my dremel before heading to the Depot.
  20. Sep 10, 2011 at 5:10 AM
    #280
    motopix
    motopix Member
    Jeff
    NoVA
    11 DCLB Sport
    Circular.
    I was thinking the same thing. Installed my rings yesterday and picked up a 3" Milwaukee holesaw that has fine teeth. It's labeled for use to install recessed lights. I had to get an arbor too so combined it was something like $40 - ouch.
    Figured a regular holesaw would tear up the rubber too much.
    Not sure 3" is the best size but I'll give it a shot and see how it goes.
