Installed D-Rings in the Bed (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Feb 27, 2009.
  1. Jul 23, 2014 at 6:44 PM
    #461
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    Sweet now you can ship me the other four for $22 and get yours for fwee!
  2. Jul 23, 2014 at 8:51 PM
    #462
    oceanslide
    oceanslide Well-Known Member
    Erik
    Oceanside, CA
    2006 Access Cab
    5100s, OME 885
    If I can't find another use for them, I will sell em!
  3. Jul 23, 2014 at 8:52 PM
    #463
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I need 2!
  4. Jul 24, 2014 at 4:02 PM
    #464
    oceanslide
    Erik
    Oceanside, CA
    2006 Access Cab
    5100s, OME 885
    Installing the d rings right now, some bolts are rusty, some aren't.
  5. Aug 11, 2014 at 7:38 AM
    #465
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Thanks for info...ordered the Mopar rings...tag for more info at install.
  6. Aug 11, 2014 at 7:52 AM
    #466
    Jackscon
    Jackscon Member
    10 PreRunner SR5 Double Cab
    I cleaned primed and painted mine before install.
  7. Aug 11, 2014 at 8:02 AM
    #467
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Well, it's a Toyota Tacoma, great little truck, but about the most rust prone vehicle on the road. if those bolts are rusted up, (if I were you) I would do a good check of your undercarriage, jmop
  8. Aug 11, 2014 at 8:05 AM
    #468
    Jackscon
    Jackscon Member
    I have been under my truck...good and solid! It isn't major rust.
    .nothing a wire brush won't take off. But I agree look for it since they had the frame issue.
  9. Aug 24, 2014 at 11:59 AM
    #469
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    Installed two up front. That should work for me...
    Anyone around the Portland Oregon, SW Washington area who wants a set PM me...I have two I'm not using, yours for free...
  10. Aug 28, 2014 at 4:38 PM
    #470
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    Completed the install of 4 D rings today and cut the bed mat to fit.
    I used the Mopar P/N 5104500AA, no drilling or grinding required, the bed bolt passes though them.
    I popped the washer off the bed bolt by placing the bolt head in a big socket and hammering the bolt out as recommended by another member which avoided all the Dremel BS.
    All I can add as a tip is marking the locations of the D-rings on the bed mat. I positioned the mat after the D-rings were installed. I then lifted the mat just above each bolt and colored the head of the bolt with a silver sharpie marker. I pressed the bed mat down on the wet ink which stamped the location on the bottom of the mat. Then I just cut 3" squares centered on each bolt mark. ImageUploadedByTapatalk1409269110.447908.jpg
  11. Aug 30, 2014 at 2:59 PM
    #471
    oceanslide
    Erik
    Oceanside, CA
    2006 Access Cab
    5100s, OME 885
    :thumbsup: thanks for the tip! Going to go cut my bed mat right now.
  12. Oct 10, 2014 at 5:28 PM
    #472
    YotaGuy
    YotaGuy Well-Known Member
    Cody
    Phoenix, AZ
    08 DCSB 4x4 O/R & Yota crawler
    Stuff n junk
    So in your pics it doesn't look like you used the backing plate, did you?
  13. Oct 10, 2014 at 5:56 PM
    #473
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Waiting for my Dodge d rings to come in tomrw! Can't wait to have more anchoring options. Thanks to everyone who has contributed to this thread.
  14. Oct 10, 2014 at 6:37 PM
    #474
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Those are the bed bolts. No need for the backing plate
  15. Nov 2, 2014 at 7:44 PM
    #475
    MachTac
    MachTac Well-Known Member
    Kody
    MD
    Storm Trooper in boot camp
    2'' Spacer Lift 15% Tint Thrush Turbo Muffler It's All About That Bass STICKERS!
  16. Nov 2, 2014 at 8:07 PM
    #476
    JTyfz450
    JTyfz450 Well-Known Member
    Jeryck
    SoCal
    2012 TRD Sport DCSB MGM
  17. Nov 2, 2014 at 9:16 PM
    #477
    TRD2013Chris
    TRD2013Chris Well-Known Member
    chris
    CT
    Black 2013 Tacoma TRD Sport Dbl Cab Long bed
  18. Nov 10, 2014 at 12:18 AM
    #478
    tacomtn
    tacomtn Well-Known Member
    TRD OR,OME,Deaver AAL
    Now I call these D Rings! Beefy as heck and cheap to boot. I used 3/8 (I think thats the size of the hole) carriage bolts so there's no bolt head up top. Then I cut a piece of deck anchor plate steel as a backing plate. This thing is solid! I can lock my expensive bikes even using the thick Kryptonite New York chain locks. Since there's no bolts up top, there is no way to use tools to undo the anchors.
    The bottom of the bed is thicker than the sides, so when possible I anchor there when securing heavier stuff. I also installed these anchors on the sides of the bed, again with a steel backing plate.
  19. Nov 10, 2014 at 9:52 AM
    #479
    rick20794
    rick20794 1st time Taco *****
    Rick
    Maryland
    '15 DCSB Sport
  20. Nov 29, 2014 at 6:49 AM
    #480
    webhead
    webhead Member
    Clovis, NM
    Has anyone considered replacing the OEM bolts with a regular hex stainless steel bolt?
    Wouldn't a stainless steel bolt be stronger and take out the corrosion possibility?
