Installed D-Rings in the Bed (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Feb 27, 2009.
  1. Aug 7, 2009 at 12:06 AM
    #41
    JKD
    JKD Well-Known Member
    Very nice...tagged for later...
  2. Aug 11, 2009 at 6:18 PM
    #42
    slick_711
    slick_711 Well-Known Member
    DFW, TX
    '09 TRD Off Road
    Avid light bar w/2x Hella 4000C, Bilstein 5100s, Demello sliders
    Huh! I thought there were four, but I've only had it a week. Just looked, there are only the two. But there are holes drilled where I thought the other two should be (corners about 4-6" in from cab). Perhaps those holes are appropriately drilled and placed to accommodate additional D-rings?
  3. Aug 11, 2009 at 6:48 PM
    #43
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^No, they're drain holes.
    IMO, the most secure way is to add them to the bed bolts. I did.
  4. Aug 11, 2009 at 10:11 PM
    #44
    slick_711
    DFW, TX
    '09 TRD Off Road
    Ahh, I should have inspected more closely. I'll be following your advice then. Thank you!
  5. Aug 12, 2009 at 5:53 AM
    #45
    EricS76
    EricS76 Well-Known Member
    Central Texas
    08 DC SR5 Prerunner Black,08 AC 4x4 SR5 White
    I did this a month ago but instead of taking the washer off the bolt, I ground the washer down flat on one side so it would fit over the D-ring. I also used the cheap D-rings from here: http://www.armysurpluswarehouse.com/...r-500-3752.cfm 5 for $5 and they're good quality. Alot of other cool stuff on that site as well. I've used them a dozen times since I put them in with no bending or problems. This is a very easy and quick mod with lots of usefullness.
  6. Aug 13, 2009 at 11:56 AM
    #46
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    Posting to look up thread later, good info ^^
  7. Aug 13, 2009 at 12:02 PM
    #47
    phynyx38
    phynyx38 Believe
    San Antonio, TX
    08 Tacoma PreRunner
    Good work. D-rings look great. Can't wait to do mine.
  8. Aug 22, 2009 at 3:28 PM
    #48
    cappo
    cappo Active Member
    Redondo Beach, CA
    2008 TRD Off Road
    Just did this easy mod today. The hardest part was grinding down rings so that the washer can be removed. Thanks for the tutorial. Too bad Toyota didnt think of it.
  9. Aug 22, 2009 at 4:01 PM
    #49
    TacoSter
    TacoSter Well-Known Member
    Chicago Burbs
    Had 08 taco, in a 4runner now
  10. Aug 23, 2009 at 10:11 AM
    #50
    Endurozw
    Zach
    Birmingham, Alabama
    Yeah I just did it yesterday too....didn't have a drill bit big enough to widen the hole so I just bought that titanium grinding bit for my dremel and went in a circle for like 30 min :p I almost needed a bigger ratchet - it took quite a bit of force to get one of those bolts out. All in all extremely easy to do though. Just used that grinding stone on the dremel and the rings ground down in about a minute.
  11. Aug 23, 2009 at 10:30 AM
    #51
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I installed them to hold down my tool box.
    Here is a little more detailed writeup of what I did.
    The box I used is manufactured by Contico, it's called the Tuff Bin. I added two D-rings to each side of the box to attach the box to the truck.
    I have extra D-rings installed under the bed-bolts in the front and middle of the bed, a padlock was passed through the D-ring in the corners of the box and the front of the bed, this is all that was needed to hold the box to the bed.
    With the box loaded and sitting on the bed mat it does not move. When I went trailing I attached two tie-downs to the other D-ring mounted on the box and attached these to the extra D-rings mounted under the bed-bolts in the middle of the bed.
    I have no use for a box in my truck all of the time. When I go trailing or camping this works perfect. It holds my tools, floor jack and a small compressor. On vacation I also had all my carwash stuff in there along with all the tie-downs and bed-net I used to secure my load. Takes about two minutes to put the box in or take it out.
    Kees, superlittlebuddha and 69TACO16 like this.
  12. Aug 23, 2009 at 12:46 PM
    #52
    HoosierTacoma08
    HoosierTacoma08 Well-Known Member
    Jared
    New Castle, Indiana
    08 Taco TRD 4x4
    886's, HD Dakar's, Bestop, BHLM, BFG AT's, Grill Craft, More Junk...
    Nice write up Neubs! One of the first mods I did to my taco, also one of the most useful!
  13. Aug 23, 2009 at 4:08 PM
    #53
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Just installed the $5 armysurplus D-rings and they are great. Also looks stock.
    I ground down the ribs on the bed bolt and insterted the D-ring between the head of the bolt, and the washer (as others have done)... this way I didn't need to slice the stock washer.
    Silly that it didn't come from the factory with the extra rings.
  14. Aug 23, 2009 at 4:20 PM
    #54
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Still waiting on my army surplus rings. Very excited about this mod! I agree, it should have been standard on these trucks.
  15. Aug 23, 2009 at 8:29 PM
    #55
    Neubs
    Neubs [OP] Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    Thanks man! I love the easy mods...:D Glad the thread helped. I agree, as many have posted, that this mod should have been a standard from Toyota to begin with. Hopefully someone from Toyota is reading these boards and will make this change on future models.
  16. Aug 23, 2009 at 8:30 PM
    #56
    Neubs
    Maryland
    Nice mod! Looks great!
  17. Aug 31, 2009 at 9:10 PM
    #57
    glandnut
    glandnut Reserve Squirrel Hair
    Florida
    16' 4Runner TEP, 01' Ext cab 4x4
    secret stuff.
    I keep going through the D-ring threads and it just dawned on me- why is no one just attaching an extra pair of rails to the bed floor like the Nissan Frontier, and use the original bed cleats on the floor??
    Also, those having a hard time finding these rings, just use the new part number I just found and use it instead of the old PT785-35054, use PT278-35054.
  18. Sep 2, 2009 at 9:41 AM
    #58
    glandnut
    Florida
    secret stuff.
  19. Sep 2, 2009 at 9:43 AM
    #59
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    I like this idea.. Hmm
  20. Sep 2, 2009 at 9:48 AM
    #60
    glandnut
    Florida
    secret stuff.
    I think I even saw some deck rail kits in various lengths at trdparts4u.com in the tundra section, depending on what year model you choose, it would work with the Tacoma cleats. I might possibly do this soon. My measurements show the 5.5' kit to be perfect for a Taco longbed, the exact length of the ribs molded in the bed already. The width of my bedrails are 1 3/16" which looks to be the perfect width to slip into one of the valleys between the ribs in the bottom of the bed...
